path: root/include/mpc5xx.h
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-22[ppc] Fix build breakage for all non-4xx PowerPC variants.Rafal Jaworowski
- adapt to the more generic EXCEPTION_PROLOG and CRIT_EXCEPTION macros - minor 4xx cleanup
2004-01-02* Patch by Denis Peter, 8 Dec 2003wdenk
- add support for the PATI board (MPC555) - add SPI support for the MPC5xx * Patch by Anders Larsen, 08 Dec 2003: add configuration options CONFIG_SERIAL_TAG and CONFIG_REVISION_TAG to pass ATAG_SERIAL and ATAG_REVISION, resp., to the ARM target; cleanup some redundand #defines
2003-03-31* Patch by Martin Winistoerfer, 23 Mar 2003wdenk
- Add port to MPC555/556 microcontrollers - Add support for cmi customer board with Intel 28F128J3A, 28F320J3A or 28F640J3A flash. * Patch by Rick Bronson, 28 Mar 2003: - fix common/cmd_nand.c
