path: root/include/mmc.h
2016-01-13mmc: store hwpart in the block deviceStephen Warren
This will allow us to have multiple block device structs each referring to the same eMMC device, yet different HW partitions. For now, there is still a single block device per eMMC device. As before, this block device always accesses whichever HW partition was most recently selected. Clients wishing to make use of multiple block devices referring to different HW partitions can simply take a copy of this block device once it points at the correct HW partition, and use each one as they wish. This feature will be used by the next patch. In the future, perhaps get_device() could be enhanced to return a dynamically allocated block device struct, to avoid the client needing to copy it in order to maintain multiple block devices. However, this would require all users to be updated to free those block device structs at some point, which is rather a large change. Most callers of mmc_switch_part() wish to permanently switch the default MMC block device's HW partition. Enhance mmc_switch_part() so that it does this. This removes the need for callers to do this. However, common/env_mmc.c needs to save and restore the current HW partition. Make it do this more explicitly. Replace use of mmc_switch_part() with mmc_select_hwpart() in order to remove duplicate code that skips the call if that HW partition is already selected. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-12dm: Convert PCI MMC over to use DM PCI APISimon Glass
At present pci_mmc_init() does not correctly use the PCI function since the list it passes is not terminated. The array size passed to pci_mmc_init() is actually not used correctly. Fix this and adjust the pci_mmc_init() to scan all available MMC devices. Adjust this code to use the new driver model PCI API. This should move over to the new MMC uclass at some point. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-01-04mmc: update MMC_ERASE argument to match Linux kernel.Eric Nelson
Table 41 of the JEDEC standard for eMMC says that bit 31 of the command argument is obsolete when issuing the ERASE command (CMD38) on page 115 of this document: http://www.jedec.org/sites/default/files/docs/jesd84-B45.pdf The SD Card Association Physical Layer Simplified Specification also makes no mention of the use of bit 31. https://www.sdcard.org/downloads/pls/part1_410.pdf The Linux kernel distinguishes between secure (bit 31 set) and non-secure erase, and this patch copies the macro names from include/linux/mmc/core.h. Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Eric Nelson <eric@nelint.com> Tested-by: Hector Palacios <hector.palacios@digi.com>
2015-07-21dm: mmc: Add an MMC uclassSimon Glass
Add basic support for MMC, providing a uclass which can set up an MMC device. This allows MMC drivers to move to using driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-05mmc: remove the MMC_MODE_HC flagRob Herring
High capacity support is not a host capability, but a device capability that is queried via the OCR. The flag in the operating conditions request argument can just be set unconditionally. This matches the Linux implementation. [panto] Hand merged and renumbering MMC_MODE_DDR_52MHz. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
2015-05-05mmc: Fix splitting device initializationAndrew Gabbasov
Starting part of device initialization sets the init_in_progress flag only if the MMC card did not yet come to ready state and needs to continue polling. If the card is SD or if the MMC card became ready quickly, the flag is not set and (if using pre-initialization) the starting phase will be re-executed from mmc_init function. Set the init_in_progress flag in all non-error cases. Also, move flags setting statements around so that the flags are not set in error paths. Also, IN_PROGRESS return status becomes unnecessary, so get rid of it. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
2015-05-05mmc: Avoid extra duplicate entry in mmc device structureAndrew Gabbasov
The 'op_cond_response' field in mmc structure contains the response from the last SEND_OP_COND MMC command while making iterational polling of the card. Later it is copied to 'ocr' field, designed to contain the OCR register value, which is actually the same response from the same command. So, these fields have actually the same data, just in different time periods. It's easier to use the same 'ocr' field in both cases at once, without temporary using of the 'op_cond_response' field. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
2015-05-05mmc: Fix typo in MMC type checking macroAndrew Gabbasov
The version flag constant name used in IS_MMC macro is incorrect/undefined. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
2015-03-02Merge branch 'master' of git://git.denx.de/u-bootStefano Babic
2015-02-23mmc: Implement SD/MMC versioning properlyPantelis Antoniou
The SD/MMC version scheme was buggy when dealing with standard major.minor.change cases. Fix it by using something similar to the linux's kernel versioning method. Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Tested-by: Jaehoon Chung <jh80.chung@samsung.com> Reported-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-02-23mmc: fsl_esdhc: Add CMD11 support to switch to 1.8VOtavio Salvador
This adds support to switch to 1.8V in case CMD11 succeeds. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Marek Vasut <marex@denx.de>
2015-02-06x86: mmc: Move common FSP functions into a common fileSimon Glass
Since these board functions seem to be the same for all boards which use FSP, move them into a common file. We can adjust this later if future FSPs need more flexibility. This creates a generic PCI MMC device. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-19mmc: extend mmcinfo output to show partition write reliability settingsDiego Santa Cruz
This extends the mmcinfo hardware partition info output to show partitions with write reliability enabled with the "WRREL" string. If the partition does not have write reliability enabled the "WRREL" string is omitted; this is analogous to the ehhanced attribute. Example output: Device: OMAP SD/MMC Manufacturer ID: fe OEM: 14e Name: MMC16 Tran Speed: 52000000 Rd Block Len: 512 MMC version 4.41 High Capacity: Yes Capacity: 13.8 GiB Bus Width: 4-bit Erase Group Size: 8 MiB HC WP Group Size: 16 MiB User Capacity: 13.8 GiB ENH WRREL User Enhanced Start: 0 Bytes User Enhanced Size: 512 MiB Boot Capacity: 16 MiB ENH RPMB Capacity: 128 KiB ENH GP1 Capacity: 64 MiB ENH WRREL GP2 Capacity: 64 MiB ENH WRREL Signed-off-by: Diego Santa Cruz <Diego.SantaCruz@spinetix.com>
2015-01-19mmc: extend the mmc hardware partitioning API with write reliabilityDiego Santa Cruz
The eMMC partition write reliability settings are to be set while partitioning a device, as per the eMMC spec, so changes to these attributes needs to be done in the hardware partitioning API. This commit adds such support. Signed-off-by: Diego Santa Cruz <Diego.SantaCruz@spinetix.com>
2015-01-19mmc: add API to do eMMC hardware partitioningDiego Santa Cruz
This adds an API to do hardware partitioning on eMMC devices. The new mmc_hwpart_config() function does the partitioning in one go. As the different attributes and partitioning options on eMMC may be interdependent validation has to be done based on the complete partitioning configuration. The function accepts three modes: - MMC_HWPART_CONF_CHECK: just validates that the configuration is valid. - MMC_HWPART_CONF_SET: validates and sets all the fields in EXT_CSD but without setting the "partitioning completed" bit, and thus is reversible. - MMC_HWPART_CONF_COMPLETE: does everything and is thus not reversible. Signed-off-by: Diego Santa Cruz <Diego.SantaCruz@spinetix.com>
2015-01-19mmc: read the high capacity WP group size for eMMCDiego Santa Cruz
Read the eMMC high capacity write protect group size at mmc device initialization. This is useful to correctly partition an eMMC device, as partitions need to be aligned to this size. Signed-off-by: Diego Santa Cruz <Diego.SantaCruz@spinetix.com>
2015-01-19mmc: fix erase_grp_size computation with high-capacity size definitionDiego Santa Cruz
The erase_grp_size in struct mmc is to be a size in 512-byte sectors but the code used to compute it for eMMC when EXT_CSD_ERASE_GROUP_DEF is enabled computed it as bytes, leading to erase sizes and alignment much larger than what is actually required by the mmc device. Signed-off-by: Diego Santa Cruz <Diego.SantaCruz@spinetix.com>
2015-01-19mmc: read the size of eMMC enhanced user data areaDiego Santa Cruz
This modification reads the size of the eMMC enhanced user data area upon initialization of an mmc device, it will be used later by mmcinfo. Signed-off-by: Diego Santa Cruz <Diego.SantaCruz@spinetix.com>
2015-01-19mmc: extend mmcinfo to show enhanced partition attributeDiego Santa Cruz
This extends the mmcinfo command's output to show which eMMC partitions have the enhanced attribute set. Note that the eMMC spec says that if the enhanced attribute is supported then the boot and RPMB partitions are of the enhanced type. The output of mmcinfo becomes: Device: OMAP SD/MMC Manufacturer ID: fe OEM: 14e Name: MMC16 Tran Speed: 52000000 Rd Block Len: 512 MMC version 4.41 High Capacity: Yes Capacity: 13.8 GiB Bus Width: 4-bit User Capacity: 13.8 GiB ENH Boot Capacity: 16 MiB ENH RPMB Capacity: 128 KiB ENH GP1 Capacity: 64 MiB ENH GP2 Capacity: 64 MiB ENH Signed-off-by: Diego Santa Cruz <Diego.SantaCruz@spinetix.com>
2014-12-12mmc: Fix handling of bus widths and DDR card capabilitiesAndrew Gabbasov
If the MMC_MODE_DDR_52MHz flag is set in card capabilities bitmask, it is never cleared, even if switching to DDR mode fails, and if the controller driver uses this flag to check the DDR mode, it can take incorrect actions. Also, DDR related checks in mmc_startup() incorrectly handle the case when the host controller does not support some bus widths (e.g. can't support 8 bits), since the host_caps is checked for DDR bit, but not bus width bits. This fix clearly separates using of card_caps bitmask, having there the flags for the capabilities, that the card can support, and actual operation mode, described outside of card_caps (i.e. bus_width and ddr_mode fields in mmc structure). Separate host controller drivers may need to be updated to use the actual flags. Respectively, the capabilities checks in mmc_startup are made more correct and clear. Also, some clean up is made with errors handling and code syntax layout. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
2014-12-12MMC: add MMC_VERSION_5_0Markus Niebel
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
2014-12-12MMC: fix user capacity for partitioned eMMC cardMarkus Niebel
if the card claims to be high capacity and the card is partitioned the capacity shall still be read from ext_csd SEC_COUNT even if the resulting capacity is smaller than 2 GiB Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
2014-12-04mmc: Board-specific MMC power initializationsPaul Kocialkowski
Some devices may use non-standard combinations of regulators to power MMC: this allows these devices to provide a board-specific MMC power init function to set everything up in their own way. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com>
2014-10-25mmc: add prototype for mmc_get_env_addrJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-07-18mmc: prevent some warnings with make W=1Jeroen Hofstee
Add missing prototypes for global functions and make local functions static. cc: panto@antoniou-consulting.com Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-02Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-23eMMC: add support for operations in RPMB partitionPierre Aubert
This patch adds functions for read, write and authentication key programming for the Replay Protected Memory Block partition in the eMMC. Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
2014-05-23mmc: Handle switch error status bit in MMC card statusAndrew Gabbasov
MMC switch command for unsupported feature (e.g. bus width) sets a switch error bit in card status. This bit should be checked, and, if it's set, no access with new controller settings should be performed. Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
2014-05-16mmc: support the DDR mode for eMMCJaehoon Chung
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-16mmc: remove the unnecessary define and fix the wrong bit controlJaehoon Chung
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Lukasz Majeski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-05-05mmc: mmc header fixMateusz Zalega
Structure definition used type block_dev_desc_t, defined in part.h, which wasn't included in mmc.h. It worked only in circumstances when common.h, or another header using part.h was incuded in implementation files. Change-Id: I5b203928b689887e3e78beb00a378955e0553eb7 Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Minkyu Kang <mk7.kang@samsung.com>
2014-04-08Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile include/configs/trats.h include/configs/trats2.h include/mmc.h
2014-04-02mmc: Add 'mmc rst-function' sub-commandTom Rini
Some eMMC chips may need the RST_n_FUNCTION bit set to a non-zero value in order for warm reset of the system to work. Details on this being required will be part of the eMMC datasheet. Also add using this command to the dra7xx README. * Whitespace fix by panto Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-03-28blackfin: mmc: Correct mmc_host_is_spi and bfin_sdh.cTom Rini
In the recent mmc cleanup, the mmc_host_is_spi macro was broken and bfin_sdh.c had mmc->bus_width turned into mmc_bus_width(mmc), both of which were incorrect. Signed-off-by: Tom Rini <trini@ti.com>
2014-03-24mmc: Split mmc struct, rework mmc initialization (v2)Pantelis Antoniou
The way that struct mmc was implemented was a bit of a mess; configuration and internal state all jumbled up in a single structure. On top of that the way initialization is done with mmc_register leads to a lot of duplicated code in drivers. Typically the initialization got something like this in every driver. struct mmc *mmc = malloc(sizeof(struct mmc)); memset(mmc, 0, sizeof(struct mmc); /* fill in fields of mmc struct */ /* store private data pointer */ mmc_register(mmc); By using the new mmc_create call one just passes an mmc config struct and an optional private data pointer like this: struct mmc = mmc_create(&cfg, priv); All in tree drivers have been updated to the new form, and expect mmc_register to go away before long. Changes since v1: * Use calloc instead of manually calling memset. * Mark mmc_register as deprecated. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-03-24mmc: Convert mmc struct's name array to a pointerPantelis Antoniou
Using an array is pointless; even more pointless (and scary) is using sprintf to fill it without a format string. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-03-24mmc: Remove ops from struct mmc and put in mmc_opsPantelis Antoniou
Remove the in-structure ops and put them in mmc_ops with a constant pointer to it. This makes the mmc structure smaller as well as conserving code space (in theory). All in-tree drivers are converted as well; this is done in a single patch in order to not break git bisect. Changes since V1: Fix compilation b0rked issue on omap platforms where OMAP_GPIO was not set. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-03-05Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
2014-03-05mmc: Add a prototype for board_mmc_init()Fabio Estevam
Fixes the following sparse warning: wandboard.c:137:5: warning: symbol 'board_mmc_init' was not declared. Should it be static? Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-02-07cmd_mmc.c: Drop open/close mmc sub-commandsTom Rini
The open and close mmc sub-commands implement a hard-coded set of values specific to the SMDK5250 platform. Remove these commands as what they did can be done instead with a series of mmc dev / bootpart / bootbus commands instead now. Cc: Amar <amarendra.xt@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07cmd_mmc.c: Add bootbus mmc sub-commandTom Rini
Add a bootbus sub-command to the mmc command to allow for setting the boot_bus_width, reset_boot_bus_width and boot_mode fields of BOOT_BUS_WIDTH (EXT_CSD[177]). Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07cmd_mmc.c: Add 'partconf' command to mmcTom Rini
Add a partconf sub-command to the mmc command to allow for setting the boot_ack, boot_partition and partition_access fields of PARTITION_CONFIG (formerly BOOT_CONFIG, EXT_CSD[179]). Part of this requires changing the check for 'part' from an strncmp to a strcmp, like the rest of the sub-commands. Cc: Andy Fleming <afleming@gmail.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-01-09mmc: add setdsr supportMarkus Niebel
The eMMC and the SD-Card specifications describe the optional SET_DSR command. During measurements at our lab we found that some cards implementing this feature having really strong driver strengts per default. This can lead to voltage peaks above the specification of the host on signal edges for data sent from a card to the host. Since availability of a given card type may be shorter than the time a certain hardware will be produced it is useful to have support for this command (Alternative would be changing termination resistors and adapting the driver strength of the host to the used card.) Following proposal for an implementation: - new field that reflects CSD field DSR_IMP in struct mmc - new field for design specific DSR value in struct mmc - board code can set DSR value in mmc struct just after registering an controller - mmc_startup sends the the stored DSR value before selecting a card, if DSR_IMP is set Additionally the mmc command is extended to make is possible to play around with different DSR values. The concept was tested on a i.MX53 based platform using a Micron eMMC card where the default DSR is 0x0400 (12mA) but in our design 0x0100 (0x0100) were enough. To use this feature for instance on a mx53loco one have to add a call to mmc_set_dsr() in board_mmc_init() after calling fsl_esdhc_initialize() for the eMMC. Signed-off-by: Markus Niebel <Markus.Niebel@tqs.de> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-01-08include/mmc.h: Remove declaration for spl_mmc_load()Lad, Prabhakar
The spl_mmc_load() was removed while converting to CONFIG_SPL_FRAMEWORK usage the definition was removed but the declaration was missed. This patch removes this declaration. Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-10-31mmc: Fix erase_grp_size for partitioned cardOliver Metz
EXT_CSD_ERASE_GROUP_DEF is lost every time after a reset or power off. Set it if device has enhanced partitions. Signed-off-by: Oliver Metz <oliver@freetz.org> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-09-17mmc: size optimization when !CONFIG_MMC_SPIPaul Burton
When CONFIG_MMC_SPI is not enabled, the MMC_MODE_SPI capability can never be set. However there is code in mmc.c which uses the mmc_host_is_spi macro to check that capability & act accordingly. If we expand that macro to 0 when CONFIG_MMC_SPI is not set (since it will always be 0 at runtime anyway) then the compiler can optimize away the SPI-specific code paths in mmc.c. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-06-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-06-19Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: spl/Makefile
2013-06-13mmc: report capacity for the selected partitionStephen Warren
Enhance the MMC core to calculate the size of each MMC partition, and update mmc->capacity whenever a partition is selected. This causes: mmc dev 0 1 ; mmcinfo ... to report the size of the currently selected partition, rather than always reporting the size of the user partition. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
