path: root/include/mmc.h
2019-02-16mmc: Downgrade SD/MMC from UHS/HS200/HS400 modes before bootMarek Vasut
Older kernel versions or systems which do not connect eMMC reset line properly may not be able to handle situations where either the eMMC is left in HS200/HS400 mode or SD card in UHS modes by the bootloader and may misbehave. Downgrade the eMMC to HS/HS52 mode and/or SD card to non-UHS mode before booting the kernel to allow such older kernels to work with modern U-Boot. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2019-01-17env: fix allow to build multiple environmentsRajesh Bhagat
Patch fixes build error when enabling CONFIG_ENV_IS_IN_SPI_FLAS and CONFIG_ENV_IS_IN_MMC at the same time mentioned issue in below link: Refer: https://lists.denx.de/pipermail/u-boot/2018-February/319565.html build error when enabling CONFIG_ENV_IS_IN_SPI_FLASH and CONFIG_ENV_IS_IN_MMC at the same time. Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-10-07mmc: rpmb: add mmc_rpmb_route_frames()Jens Wiklander
Adds mmc_rpmb_route_frames() to route RPMB data frames from/to an external entity. Tested-by: Igor Opaniuk <igor.opaniuk@linaro.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-10mmc: add HS400 supportPeng Fan
Add HS400 support. Selecting HS400 needs first select HS200 according to spec, so use a dedicated function for HS400. Add HS400 related macros. Remove the restriction of only using the low 6 bits of EXT_CSD_CARD_TYPE, using all the 8 bits. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Jean-Jacques Hiblot <jjhiblot@ti.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Kishon Vijay Abraham I <kishon@ti.com> Cc: Faiz Abbas <faiz_abbas@ti.com> Cc: Marek Vasut <marex@denx.de> Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-07-23mmc: break out get_op_cond code to its own functionJon Nettleton
This code is useful for testing the existance of devices that do not have card detect capabilities. This breaks out the core functionality and leaves the actual init logic and error reporting in mmc_start_init(). Signed-off-by: Jon Nettleton <jon@solid-run.com> Signed-off-by: Baruch Siach <baruch@tkos.co.il> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-07-23mmc: drop mention of IN_PROGRESS statusBaruch Siach
The IN_PROGRESS macro has been removed in commit bd47c13583f (mmc: Fix splitting device initialization). Remove it from the mmc_start_init() function description. Signed-off-by: Baruch Siach <baruch@tkos.co.il>
2018-05-08mmc: add the MMC_CLK_ENABLE/DISABLE macro in mmc.hJaehoon Chung
mmc_set_clock() function has the disable argument as bool type. When mmc_set_clock is called, it might be passed to "true" or "false". But it's too confusion whether clock is enabled or disabled with only "true" and "false". To prevent the confusion, replace to MMC_CLK_ENABLE/DISABLE macro from true/false. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2018-02-19mmc: fix bug in mmc_startup_v4()Jean-Jacques Hiblot
The correspondence between mmc versions as used in u-boot and the version numbers reported in register EXT_CSD_REV is wrong for versions above and including MMC_VERSION_4_41. All those versions were shifted by one: real 4.5 hardware appeared to be MMC_VERSION_5_0. Fix this by adding the missing version in the correspondence table. Reported-by: eil Eilmsteiner Heribert <eil@keba.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Sam Protsenko <semen.protsenko@linaro.org>
2018-01-12mmc: remove hc_wp_grp_size from struct mmc if not neededJean-Jacques Hiblot
hc_wp_grp_size is needed only if hardware partitionning is used. On ARM removing it saves about 30 bytes of code space. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: don't read the size of eMMC enhanced user data area in SPLJean-Jacques Hiblot
This information is only used by the "mmc info" command. On ARM removing this information from SPL saves about 140 of code space. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: compile out erase and write mmc commands if write operations are not ↵Jean-Jacques Hiblot
enabled Also remove erase_grp_size and write_bl_len from struct mmc as they are not used anymore. On ARM, removing them saves about 100 bytes of code space in SPL. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: read ssr only if MMC write support is enabledJean-Jacques Hiblot
The content of ssr is useful only for erase operations. on ARM, removing sd_read_ssr() saves around 300 bytes. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: make UHS and HS200 optionalJean-Jacques Hiblot
Supporting USH and HS200 increases the code size as it brings in IO voltage control, tuning and fatter data structures. Use Kconfig configuration to select which of those features should be built in. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12dm: mmc: update mmc_of_parse()Jean-Jacques Hiblot
* convert to livetree API * don't fail because of an invalid bus-width, instead default to 1-bit. * recognize 1.2v DDR and 1.2v HS200 flags Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12dm: mmc: Add a library function to parse generic dt bindingKishon Vijay Abraham I
Add a new function to parse host controller dt node and set mmc_config. This function can be used by mmc controller drivers to set the generic mmc_config. This function can be extended to set other UHS mode caps once UHS mode support is added. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: add a library function to send tuning commandJean-Jacques Hiblot
HS200/SDR104 requires tuning command to be sent to the card. Add a simple function to send tuning command and to read and compare the received data with the tuning block pattern. This function can be used by platform driver to perform DLL tuning. This patch is similar to commit 996903de92f0 ("mmc: core: add core-level function for sending tuning commands") added in linux kernel. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: use the right voltage level for MMC DDR and HS200 modesJean-Jacques Hiblot
HS200 only supports 1.2v and 1.8v signal voltages. DDR52 supports 3.3v/1.8v or 1.2v signal voltages. Select the lowest voltage available when using those modes. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: Retry some MMC cmds on failureKishon Vijay Abraham I
With certain SD cards like Kingston 8GB/16GB UHS card, it is seen that MMC_CMD_ALL_SEND_CID cmd fails on first attempt, but succeeds subsequently. Therefore, retry MMC_CMD_ALL_SEND_CID cmd a few time as done in Linux kernel. Similarly, it is seen that MMC_CMD_SET_BLOCKLEN may fail on first attempt, therefore retry this cmd a few times as done in kernel. To make it clear that those are optionnal workarounds, a new Kconfig option 'MMC_QUIRKS' is added (enabled by default). Signed-off-by: Vignesh R <vigneshr@ti.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: Change mode when switching to a boot partitionJean-Jacques Hiblot
Boot partitions do not support HS200. Changing to a lower performance mode is required to access them. mmc_select_mode_and_width() and sd_select_mode_and_width() are modified to make it easier to call them outside of the initialization context. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-12mmc: disable UHS modes if Vcc cannot be switched on and offJean-Jacques Hiblot
If a power cycle cannot be done on Vcc, it is safer not to try the UHS modes because we wouldn't be able to recover from an error occurring during the UHS initialization. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: Add support for UHS modesJean-Jacques Hiblot
Add UHS modes to the list of supported modes, get the UHS capabilites of the SDcard and implement the procedure to switch the voltage (UHS modes use 1v8 IO lines) During the voltage switch procedure, DAT0 is used by the card to signal when it's ready. The optional card_busy() callback can be used to get this information from the host driver. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-12mmc: add HS200 support in MMC coreKishon Vijay Abraham I
Add HS200 to the list of supported modes and introduce tuning in the MMC startup process. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-12mmc: Add a execute_tuning() callback to the mmc operations.Kishon Vijay Abraham I
Tuning is a mandatory step in the initialization of SDR104 and HS200 modes. This callback execute the tuning process. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: add a new mmc parameter to disable mmc clockKishon Vijay Abraham I
mmc clock has to be disabled in certain cases like during the voltage switch sequence. Modify mmc_set_clock function to take disable as an argument that signifies if the clock has to be enabled or disabled. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: Add a new callback function to perform the 74 clocks cycle sequenceJean-Jacques Hiblot
Add a new callback function *send_init_stream* which start a sequence of at least 74 clock cycles. The mmc core uses *mmc_send_init_stream* in order to invoke the callback function. This will be used during power cycle where the specification requires such a sequence after power up. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: Enable signal voltage to be selected from mmc coreKishon Vijay Abraham I
Add a new function *mmc_set_signal_voltage* in mmc core which can be used during mmc initialization to select the signal voltage. Platform driver should use the set_ios callback function to select the signal voltage. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: make mmc_set_ios() return statusKishon Vijay Abraham I
set_ios callback has a return value of 'int' but the mmc_set_ios() function ignore this. Modify mmc_set_ios() and the callers of mmc_set_ios() to to return the error status. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-12mmc: refactor MMC startup to make it easier to support new modesJean-Jacques Hiblot
The MMC startup process currently handles 4 modes. To make it easier to add support for more modes, let's make the process more generic and use a list of the modes to try. The major functional change is that when a mode fails we try the next one. Not all modes are tried, only those supported by the card and the host. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-12mmc: refactor SD startup to make it easier to support new modesJean-Jacques Hiblot
The SDcard startup process currently handles only 2 modes. To make it easier to add support for more modes, let's make the process more generic and use a list of the modes to try. The major functional change is that when a mode fails we try the next one. Not all modes are tried, only those supported by the card and the host. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-12mmc: Add a function to dump the mmc capabilitiesJean-Jacques Hiblot
This adds a simple helper function to display information (bus width and mode) based on a capability mask. Useful for debug. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-01-12mmc: introduce mmc modesJean-Jacques Hiblot
no functionnal changes. In order to add the support for the high speed SD and MMC modes, it is useful to track this information. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-12mmc: make ext_csd part of struct mmcJean-Jacques Hiblot
The ext csd is used for comparison many times. Keep a reference content of the ext csd in the struct mmc to avoid reading multiple times Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-12mmc: dm: get the IO-line and main voltage regulators from the dtsJean-Jacques Hiblot
Get a reference to the regulator devices from the dts and store them in the struct mmc for later use. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2017-08-17cmd: mmc: add mmc partconf read capabilityAngelo Dureghello
This patch allows to show the EXT_CSD[179] partition_config register info, just by specifying the dev param: U-Boot> mmc partconf 0 EXT_CSD[179], PARTITION_CONFIG: BOOT_ACK: 0x0 BOOT_PARTITION_ENABLE: 0x0 PARTITION_ACCESS: 0x0 Signed-off-by: Angelo Dureghello <angelo@sysam.it> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2017-08-17dm: mmc: Drop CONFIG_DM_MMC_OPSSimon Glass
All boards which use DM_MMC have now been converted to use DM_MMC_OPS. Drop the option and good riddance. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-01Merge git://git.denx.de/u-boot-x86Tom Rini
2017-08-01x86: Convert MMC to driver modelSimon Glass
Convert the pci_mmc driver over to driver model and migrate all x86 boards that use it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: remove DM_MMC from edison_defconfig] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-01dm: mmc: Allow disabling driver model in SPLSimon Glass
At present if U-Boot proper uses driver model for MMC, then SPL has to also. While this is desirable, it places a significant barrier to moving to driver model in some cases. For example, with a space-constrained SPL it may be necessary to enable CONFIG_SPL_OF_PLATDATA which involves adjusting some drivers. Add new SPL versions of the options for DM_MMC, DM_MMC_OPS and BLK. By default these follow their non-SPL versions, but this can be changed by boards which need it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-27Revert "x86: Convert MMC to driver model"Bin Meng
This reverts commit ddb3ac3c716f56cead695444e65a7ba7b0946555. With MMC converted to driver model, SCSI driver is broken due to zero address access at (ops->read) in block_dread() function. The fix (SCSI driver converted to DM) is ready in u-boot-dm branch, but it is too late for this relese to get that in. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-29mmc: Change 'part_config' to be a u8 not char.Tom Rini
In some places we check if part_config is set to MMCPART_NOAVAILABLE (0xff). With part_config being a char this is always false. We should be using a u8 to store this value instead, after a quick consultation with the Linux Kernel. Reported by clang-3.8. Cc: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-17x86: Convert MMC to driver modelSimon Glass
2017-01-11mmc: change the set_ios return type from void to intJaehoon Chung
To maintain consistency, set_ios type of legacy mmc_ops changed to int. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-01mmc: Tinification of the mmc codeMarek Vasut
Add new configuration option CONFIG_MMC_TINY which strips away all memory allocation within the MMC code and code for handling multiple cards. This allows extremely space-constrained SPL code use the MMC framework. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-01mmc: add bkops-enable commandTomas Melin
Add new command that provides possibility to enable the background operations handshake functionality (BKOPS_EN, EXT_CSD byte [163]) on eMMC devices. This is an optional feature of eMMCs, the setting is write-once. The command must be explicitly taken into use with CONFIG_CMD_BKOPS_ENABLE. Signed-off-by: Tomas Melin <tomas.melin@vaisala.com>
2016-09-20mmc: sd: extracting erase related information from sd statusPeng Fan
Add function to read SD_STATUS information. According to the information, get erase_timeout/erase_size/erase_offset. Add a structure sd_ssr to include the erase related information. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Stefan Wahren <stefan.wahren@i2se.com> Cc: Clemens Gruber <clemens.gruber@pqgruber.com> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Eric Nelson <eric@nelint.com> Cc: Stephen Warren <swarren@nvidia.com>
2016-08-05mmc: use the generic error numberJaehoon Chung
Use the generic error number instead of specific error number. If use the generic error number, it can debug more easier. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-07-31mmc-uclass: correct the device numberKever Yang
Not like the mmc-legacy which the devnum starts from 1, it starts from 0 in mmc-uclass, so the device number should be (devnum + 1) in get_mmc_num(). Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-07-11dm: mmc: Add a way to use driver model for MMC operationsSimon Glass
The driver model conversion for MMC has moved in small steps. The first step was to have an MMC device (CONFIG_DM_MMC). The second was to use a child block device (CONFIG_BLK). The final one is to use driver model for MMC operations (CONFIG_DM_MMC_OP). Add support for this. The immediate priority is to make all boards that use DM_MMC also use those other two options. This will allow them to be removed. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-20mmc: add MMC_VERSION_5_1Stefan Wahren
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
