path: root/include/miiphy.h
2011-12-07Revert "mii: miiphy register address width change"Wolfgang Denk
This reverts commit 5c45a22b9203351a32aec4600514341b91175542. It causes a lot of "incompatible pointer type" warnings for a large number of Ethernet drivers, which are not really worth fixing especially as this patch was only supposed to help the old, deprecated miiphy API. Instead of adding more efforts to a lost case we rather revert it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-06mii: miiphy register address width changeChandan Nath
This patch is added for PHY whose register offset value exceeds 0xFF and cannot be used with "unsigned char" datatype in miiphy_read, miiphy_write and miiphy_register functions. Datatype of register offset is changed to unsigned short instead of unsigned char so that offset value greater then 0xFF can be used. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-04-20Create PHY Lib for U-BootAndy Fleming
Extends the mii_dev structure to participate in a full-blown MDIO and PHY driver scheme. The mii_dev structure and miiphy calls are modified in such a way to allow the original mii command and miiphy infrastructure to work as before, but also to support a new set of APIs which allow (among other things) sharing of PHY driver code and 10G support The mii command will continue to support normal PHY management functions (Clause 22 of 802.3), but will not be changed to support 10G (Clause 45). The basic design is similar to PHY Lib from Linux, but simplified for U-Boot's network and driver infrastructure. We now have MDIO drivers and PHY drivers An MDIO driver provides: read write reset A PHY driver provides: (optionally): probe config - initial setup, starting of auto-negotiation startup - waiting for AN, and reading link state shutdown - any cleanup needed The ethernet drivers interact with the PHY Lib using these functions: phy_connect() phy_config() phy_startup() phy_shutdown() Each PHY driver can be configured separately, or all at once using config_phylib_all_drivers.h (added in the patch which adds the drivers) We also provide generic drivers for Clause 22 (10/100/1000), and Clause 45 (10G) PHYs. We also implement phy_reset(), and call it in phy_connect(). Because phy_reset() is essentially the same as miiphy_reset, but: a) must support 10G PHYs, and b) should use the phylib primitives, we implement miiphy_reset, using phy_reset(), but only when CONFIG_PHYLIB is set. Otherwise, we just use the old version. In this way, we save on compile size, even if we don't manage to save code size. Pulled ethtool.h and mdio.h from: git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6 782d640afd15af7a1faf01cfe566ca4ac511319d With many, many deletions so as to enable compilation under u-boot Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-20miiphy: Fix some formatting issuesAndy Fleming
Mostly putting a space between function name and "(", and doing return (foo) Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-09miiphy: constify device nameMike Frysinger
The driver name does not need to be writable, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-10Rewrite the miiphybb (Bit-banged MII bus driver) in order to support an ↵Luigi 'Comio' Mantellini
arbitrary number of mii buses. This feature is useful when your board uses different mii buses for different phys and all (or a part) of these buses are implemented via bit-banging mode. The driver requires that the following macros should be defined into the board configuration file: CONFIG_BITBANGMII - Enable the miiphybb driver CONFIG_BITBANGMII_MULTI - Enable the multi bus support If the CONFIG_BITBANGMII_MULTI is not defined, the board's config file needs to define at least the following macros: MII_INIT - Generic code to enable the MII bus (optional) MDIO_DECLARE - Declaration needed to access to the MDIO pin (optional) MDIO_ACTIVE - Activate the MDIO pin as out pin MDIO_TRISTATE - Activate the MDIO pin as input/tristate pin MDIO_READ - Read the MDIO pin MDIO(v) - Write v on the MDIO pin MDC_DECLARE - Declaration needed to access to the MDC pin (optional) MDC(v) - Write v on the MDC pin The previous macros make the driver compatible with the previous version (that didn't support the multi-bus). When the CONFIG_BITBANGMII_MULTI is also defined, the board code needs to fill the bb_miiphy_buses[] array with a record for each required bus and declare the bb_miiphy_buses_num variable with the number of mii buses. The record (struct bb_miiphy_bus) has the following fields/callbacks (see miiphy.h for details): char name[] - The symbolic name that must be equal to the MII bus registered name int (*init)() - Initialization function called at startup time (just before the Ethernet initialization) int (*mdio_active)() - Activate the MDIO pin as output int (*mdio_tristate)() - Activate the MDIO pin as input/tristate pin int (*set_mdio)() - Write the MDIO pin int (*get_mdio)() - Read the MDIO pin int (*set_mdc)() - Write the MDC pin int (*delay)() - Delay function void *priv - Private data used by board specific code The board code will look like: struct bb_miiphy_bus bb_miiphy_buses[] = { { .name = miibus#1, .init = b1_init, .mdio_active = b1_mdio_active, ... }, { .name = miibus#2, .init = b2_init, .mdio_active = b2_mdio_active, ... }, ... int bb_miiphy_buses_num = sizeof(bb_miiphy_buses) / sizeof(bb_miiphy_buses[0]); Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-09Dual-license IBM code contributionsJosh Boyer
It was brought to our attention that U-Boot contains code derived from the IBM OpenBIOS source code originally provided with some of the older PowerPC 4xx development boards. As a result, the original license of this code has been carried in the various files for a number of years in the U-Boot project. IBM is dual-licensing the IBM code contributions already present in U-Boot under either the terms of the GNU General Public License version 2, or the original code license already present. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-11-06NET: Add Ethernet 1000BASE-X support for PPC4xxLarry Johnson
This patch adds support for 1000BASE-X to functions "miiphy_speed ()" and "miiphy_duplex()". It also adds function "miiphy_is_1000base_x ()", which returns non-zero iff the PHY registers are configured for 1000BASE-X. The "mii info" command is modified to distinguish between 1000BASE-T and -X. Signed-off-by: Larry Johnson <lrj@acm.org> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-11-06NET: Cosmetic changesLarry Johnson
2005-11-30Fix miiphy global data initialization (problem on 4xx boards when noMarian Balakowicz
ethaddr is assigned). Initialization moved from miiphy_register() to eth_initialize(). Based on initial patch for 4xx platform by Matthias Fuchs.
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2004-04-25* Patch by John Kerl, 19 Apr 2004:wdenk
Use U-boot's miiphy.h for PHY register names, rather than introducing a new header file. * Update pci_ids.h from linux-2.4.26 * Patch by Masami Komiya, 19 Apr 2004: Fix problem cause by VLAN function on little endian architecture without VLAN environment
2004-03-14* Patches by Travis Sawyer, 12 Mar 2004:wdenk
- Fix Gigabit Ethernet support for 440GX - Add Gigabit Ethernet Support to MII PHY utilities * Patch by Brad Kemp, 12 Mar 2004: Fixes for drivers/cfi_flash.c: - Better support for x8/x16 implementations - Added failure for AMD chips attempting to use CFG_FLASH_USE_BUFFER_WRITE - Added defines for AMD command and address constants * Patch by Leon Kukovec, 12 Mar 2004: Fix get_dentfromdir() to correctly handle deleted dentries * Patch by George G. Davis, 11 Mar 2004: Remove hard coded network settings in TI OMAP1610 H2 default board config * Patch by George G. Davis, 11 Mar 2004: add support for ADS GraphicsClient+ board.
2003-10-08* Patch by Sangmoon Kim, 23 Sep 2003:wdenk
fix pll_pci_to_mem_multiplier table for MPC8245 * Patch by Anders Larsen, 22 Sep 2003: enable timed autoboot on PXA * Patch by David Müller, 22 Sep 2003: - add $(CFLAGS) to "-print-libgcc-filename" so compiler driver returns correct libgcc file path - "latency" reduction of busy-loop waiting to improve "U-Boot" boot time on s3c24x0 systems * Patch by Jon Diekema, 19 Sep 2003: - Add CFG_FAULT_ECHO_LINK_DOWN option to echo the inverted Ethernet link state to the fault LED. - In NetLoop, make the Fault LED reflect the link status. The link status gets updated on entry, and on timeouts.
2003-09-18* Patch by Rune Torgersen, 17 Sep 2003:wdenk
- Fixes for MPC8266 default config - Allow eth_loopback_test() on 8260 to use a subset of the FCC's
2001-10-08Initial revisionwdenk
