path: root/include/mc13783.h
2012-02-12mc13783.h: create and add regulator mode 0 and 1Helmut Raiger
Add bit definitions for register 32 and 33 of Freescale MC13783. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
