path: root/include/mailbox-uclass.h
2017-06-01dm: mailbox: Update uclass to support livetreeSimon Glass
Update the mailbox uclass to support livetree. Fix the xlate() method in all callers. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-19mailbox: rename headersStephen Warren
Rename mailbox*.h to match the naming convention requested during review of the new reset subsystem. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
