path: root/include/lmb.h
2019-02-02lmb: handle more than one DRAM BANKSimon Goldschmidt
This fixes the automatic lmb initialization and reservation for boards with more than one DRAM bank. This fixes the CVE-2018-18439 and -18440 fixes that only allowed to load files into the firs DRAM bank from fs and via tftp. Found-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-26lib: lmb: rename lmb_get_unreserved_size to lmb_get_free_sizeSimon Goldschmidt
As a follow-up, change the name of the newly introduced function 'lmb_get_unreserved_size' to 'lmb_get_free_size', which is more appropriate. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fix test/lib/lmb.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-01-16lmb: remove unused extern declarationSimon Goldschmidt
lmb.h includes an extern declaration of "struct lmb lmb;" which is not used anywhere, so remove it. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-01-16fs: prevent overwriting reserved memorySimon Goldschmidt
This fixes CVE-2018-18440 ("insufficient boundary checks in filesystem image load") by using lmb to check the load size of a file against reserved memory addresses. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-16lib: lmb: extend lmb for checks at load timeSimon Goldschmidt
This adds two new functions, lmb_alloc_addr and lmb_get_unreserved_size. lmb_alloc_addr behaves like lmb_alloc, but it tries to allocate a pre-specified address range. Unlike lmb_reserve, this address range must be inside one of the memory ranges that has been set up with lmb_add. lmb_get_unreserved_size returns the number of bytes that can be used up to the next reserved region or the end of valid ram. This can be 0 if the address passed is reserved. Added test for these new functions. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2013-05-14image: Add device tree setup to image librarySimon Glass
This seems to be a common function for several architectures, so create a common function rather than duplicating the code in each arch. Also make an attempt to avoid introducing #ifdefs in the new code, partly by removing useless #ifdefs around function declarations in the image.h header. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-06-19lmb: do not export anything without CONFIG_LMBMike Frysinger
2010-01-21lmb: only force on arches that use itMike Frysinger
2008-07-10Fix LMB type issuesAndy Fleming
The LMB code now uses phys_addr_t and phys_size_t. Also, there were a couple of casting problems in the bootm code that called the LMB functions. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-03lmb: fix "implicit declaration of function 'lmb_free'" warningWolfgang Denk
2008-06-12Change lmb to use phys_size_t/phys_addr_tBecky Bruce
This updates the lmb code to use phys_size_t and phys_addr_t instead of unsigned long. Other code which interacts with this code, like getenv_bootm_size() is also updated. Booted on MPC8641HPCN, build-tested ppc, arm, mips. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-02-29[new uImage] Introduce lmb from linux kernel for memory mgmt of boot imagesKumar Gala
Introduce the LMB lib used on PPC in the kernel as a clean way to manage the memory spaces used by various boot images and structures. This code will allow us to simplify the code in bootm and its support functions. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
