path: root/include/lmb.h
2012-06-19lmb: do not export anything without CONFIG_LMBMike Frysinger
2010-01-21lmb: only force on arches that use itMike Frysinger
2008-07-10Fix LMB type issuesAndy Fleming
The LMB code now uses phys_addr_t and phys_size_t. Also, there were a couple of casting problems in the bootm code that called the LMB functions. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-03lmb: fix "implicit declaration of function 'lmb_free'" warningWolfgang Denk
2008-06-12Change lmb to use phys_size_t/phys_addr_tBecky Bruce
This updates the lmb code to use phys_size_t and phys_addr_t instead of unsigned long. Other code which interacts with this code, like getenv_bootm_size() is also updated. Booted on MPC8641HPCN, build-tested ppc, arm, mips. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-02-29[new uImage] Introduce lmb from linux kernel for memory mgmt of boot imagesKumar Gala
Introduce the LMB lib used on PPC in the kernel as a clean way to manage the memory spaces used by various boot images and structures. This code will allow us to simplify the code in bootm and its support functions. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
