Previous patch "MLK-21885 lmb: Handle the overlap case for lmb reserve" adds
the overlap support to lmb reserve. However, u-boot has some places to use the
lmb_reserve when allocating memory in loading images. If we allowed overlap
in this function, it means images loading address can overlap each other and
cause the address check mechanism not work.
So add another function to allow overlap and only use it for fdt reserved-memory
nodes. The FDT reserved-memory is ok to merge with other reserved memory, since
this won't break image loading address check.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit 2109dc2a4da592003ec62820f5bdfb6bd0899805)
This fixes the automatic lmb initialization and reservation for boards
with more than one DRAM bank.
This fixes the CVE-2018-18439 and -18440 fixes that only allowed to load
files into the firs DRAM bank from fs and via tftp.
Found-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
As a follow-up, change the name of the newly introduced function
'lmb_get_unreserved_size' to 'lmb_get_free_size', which is more
appropriate.
[trini: Fix test/lib/lmb.c]
lmb.h includes an extern declaration of "struct lmb lmb;" which
is not used anywhere, so remove it.
This fixes CVE-2018-18440 ("insufficient boundary checks in filesystem
image load") by using lmb to check the load size of a file against
reserved memory addresses.
This adds two new functions, lmb_alloc_addr and
lmb_get_unreserved_size.
lmb_alloc_addr behaves like lmb_alloc, but it tries to allocate a
pre-specified address range. Unlike lmb_reserve, this address range
must be inside one of the memory ranges that has been set up with
lmb_add.
lmb_get_unreserved_size returns the number of bytes that can be
used up to the next reserved region or the end of valid ram. This
can be 0 if the address passed is reserved.
Added test for these new functions.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
[trini: Fixup common/cmd_io.c]
This seems to be a common function for several architectures, so create
a common function rather than duplicating the code in each arch.
Also make an attempt to avoid introducing #ifdefs in the new code, partly
by removing useless #ifdefs around function declarations in the image.h
header.
The LMB code now uses phys_addr_t and phys_size_t. Also, there were a couple
of casting problems in the bootm code that called the LMB functions.
Signed-off-by: Andy Fleming <afleming@freescale.com>
This updates the lmb code to use phys_size_t
and phys_addr_t instead of unsigned long. Other code
which interacts with this code, like getenv_bootm_size()
is also updated.
Booted on MPC8641HPCN, build-tested ppc, arm, mips.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Introduce the LMB lib used on PPC in the kernel as a clean way to manage
the memory spaces used by various boot images and structures. This code
will allow us to simplify the code in bootm and its support functions.
