A recurrent issue is that certain C level constructs like sizeof() or
offsetof() cannot be used in assembler files, which is inconvenient
when such constructs are used in the definition of macro names etc.
To avoid duplication of such definitions (and thus another cause of
problems), we adapt the Linux way to automatically generate the
respective definitions from the respective C header files.
In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and
arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36
kernel tree.
We also copy the concept of the include/generated/ directory which can
be used to hold other automatically generated files as well.
We start with an architecture-independent lib/asm-offsets.c which
generates include/generated/generic-asm-offsets.h (included by
include/asm-offsets.h, which is what will be referred to in the actual
source code). Later this may be extended by architecture-specific
arch/*/lib/asm-offsets.c files that will generate a
include/generated/asm-offsets.h.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
[port of linux 2.6.34 commit 6a9ee8af344e3bd7dbd61e67037096cdf7f83289]
This patch adds the Numonyx manufacturer code (0x20) to
onenand manufacturers.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by: Steve Sakoman <steve.sakoman@linaro.org>
Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
The logic to 'spread' mtd partitions needs to calculate the length in
the mtd device, including bad blocks.
This patch introduces a new function, mtd_get_len_incl_bad that can
return both the length including bad blocks and whether that length
was truncated on the device. This new function will be used by the
mtdparts spread command later in this series. The definition of the
function is #ifdef'd out in configurations that do not use the new
'mtdparts spread' command.
Signed-off-by: Ben Gardiner<bengardiner@nanometrics.ca>
CC: Scott Wood <scottwood@freescale.com>
Get rid of the several "#if 0" sections that were keeping around Linux
code that isn't relevant to U-Boot. Besides cluttering the code, these
sections make tracking upstream changes harder, rather than easier.
It's easy to discard obviously irrelevant diff hunks that patch rejects,
but it's not as easy to notice hunks that apply cleanly to the #if 0
section, but *are* relevant to U-Boot and require modification elsewhere.
Also remove suspend/resume, as this is not applicable to U-Boot. Removal
saves 232 bytes on powerpc.
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
Fixes most of checkpatch warnings and errors in USB gadget stack.
The most frequently encountered problems are:
1) "(foo*)", "foo * bar", "foo* bar"
2) C99 // comments
3) No spaces before/after/around '?', ':', '=', '==', ',', '&', '('
4) Spaces before '['
5) Spaces between function names and '('
6) Block braces in wrong places
7) Spaces before tabs
8) Macros with complex values not enclosed in parenthesis
9) Multiline comments start just after /*
Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
Derived from Linux kernel 2.6.27
Signed-off-by: Thomas Smits <ts.smits@gmail.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Add support for newer (up to 2.6.33) kernels
Add zboot command which takes the address of a bzImage as its first
argument and (optionally) the size of the bzImage as the second argument
(the second argument is needed for older kernels which do not include
the bzImage size in the header)
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
This is needed for jffs2 support.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
the macros likely and unlikely were defined in include/linux/mtd/compat.h,
but used in code not related to MTD. moved the macro definitions to compiler.h
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
Add lzop decompression support to the existing lzo bitstream handling
(think gzip versus zlib), and support it for uImage decompression if
CONFIG_LZO is enabled.
Lzop doesn't compress as good as gzip (~10% worse), but decompression
is very fast (~0.7s faster here on a slow ppc). The lzop decompression
code is based on Albin Tonnerre's recent ARM Linux lzo support patch.
Cc: albin.tonnerre@free-electrons.com
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
NANDs with page size of lesser than and equal to 2K are
reaching EOL. They are bing replaced with NANDs of
page size 4K and above.
To support this we have to extend the eccpos field
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
This patch adds support for Flex-OneNAND devices.
Signed-off-by: Rohit Hagargundgi <h.rohit@samsung.com>
Signed-off-by: Amul Kumar Saha <amul.saha@samsung.com>
This patch adds support for NANDs greater than 2 GB.
Patch is based on the MTD NAND driver in the kernel.
The asm-arm/unaligned.h includes linux/unaligned/access_ok.h
This file is unsafe to be used on ARM, since it does an unaligned memory
accesses which fails on ARM.
Lookin at Linux the basic difference seems to be the header
"include/asm-arm/unaligned.h". The Linux version of "unaligned.h"
does *not* include "access_ok.h" at all. It includes "le_byteshift.h"
and "be_byteshift.h" instead.
include/asm-arm/unaligned.h | 3 -
include/linux/unaligned/be_byteshift.h | 70 +++++++++++++++++++++++++++++++++
include/linux/unaligned/le_byteshift.h | 70 +++++++++++++++++++++++++++++++++
3 files changed, 142 insertions(+), 1 deletion(-)
create mode 100644 include/linux/unaligned/be_byteshift.h
create mode 100644 include/linux/unaligned/le_byteshift.h
fix the following compile warnings
warning: dereferencing type-punned pointer will break strict-aliasing rules
This patch includes the onenand driver for s5pc100
Commits
02f99901ed1c9d828e3ea117f94ce2264bf8389e
52d61227b66d4099b39c8309ab37cb67ee09a405
introduced a regression where platform-specific ffs/fls implementations
were defined away. This patch corrects that by using PLATFORM_xxx
instead of the name itself.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
UBIFS requires fls(), which is not defined for arm (and some other
architectures) and this patch adds it. The implementation is taken from
Linux and is generic. ffs() is also defined for those that miss it.
__set_bit and __clear_bit are defined in ubifs.h as well as in
asm/include/bitops.h for some architectures. This patch moves
the generic implementation to include/linux/bitops.h and uses
that unless it's defined by the architecture.
This patch adds the new mode NAND_ECC_HW_OOB_FIRST in the nand code to
support 4-bit ECC on TI DaVinci devices with large page (up to 2K) NAND
chips. This ECC mode is similar to NAND_ECC_HW, with the exception of
read_page API that first reads the OOB area, reads the data in chunks,
feeds the ECC from OOB area to the ECC hw engine and perform any
correction on the data as per the ECC status reported by the engine.
This patch has been accepted by Andrew Morton and can be found at
http://userweb.kernel.org/~akpm/mmotm/broken-out/mtd-nand-add-new-ecc-mode-ecc_hw_oob_first.patch
Signed-off-by: Sneha Narnakaje <nsnehaprabha@ti.com>
This patch adds a new "page" parameter to all NAND read_page/read_page_raw
APIs. The read_page API for the new mode ECC_HW_OOB_FIRST requires the
page information to send the READOOB command and read the OOB area before
the data area.
http://userweb.kernel.org/~akpm/mmotm/broken-out/mtd-nand-add-page-parameter-to-all-read_page-read_page_raw-apis.patch
WE would like this to become part of the u-boot GIT as well
Remove unused read_spareram and add unlock_all as kernel does
In the process, also remove backward-compatiblity macros BIN_TO_BCD and
BCD_TO_BIN and update the sole board using them to use the new bin2bcd
and bcd2bin instead
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Acked-by: Detlev Zundel <dzu@denx.de>
Legacy NAND had been scheduled for removal. Any boards that use this
were already not building in the previous release due to an #error.
The disk on chip code in common/cmd_doc.c relies on legacy NAND,
and it has also been removed. There is newer disk on chip code
in drivers/mtd/nand; someone with access to hardware and sufficient
time and motivation can try to get that working, but for now disk
on chip is not supported.
This is needed for the MPC512x NAND driver (fsl_nfc_nand.c) which already
defines such a 4k plus 218 bytes ECC layout.
Cc: Scott Wood <scottwood@freescale.com>
This patch brings the U-Boot MTD infrastructure in sync with the current
Linux MTD version (2.6.30-rc3). Biggest change is the 64bit device size
support and a resync of the mtdpart.c file which has seen multiple fixes
meanwhile.
Cc: Kyungmin Park <kmpark@infradead.org>
This patch adds concatenation support to the U-Boot MTD infrastructure.
By enabling CONFIG_MTD_CONCAT this MTD CFI wrapper will concatenate
all found NOR devices into one single MTD device. This can be used by
e.g by UBI to access a partition that spans over multiple NOR chips.
The NAND flash on the TQM8548_BE modules requires a short delay after
running the UPM pattern like the MPC8360ERDK board does. The TQM8548_BE
requires a further short delay after writing out a buffer. Normally the
R/B pin should be checked, but it's not connected on the TQM8548_BE.
The corresponding Linux FSL UPM driver uses similar delay points at the
same locations. To manage these extra delays in a more general way, I
introduced the "wait_flags" field allowing the board-specific driver to
specify various types of extra delay.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
For the NAND chips on the TQM8548 modules, a special chip-select logic is
used. It uses dedicated address lines to be set via UPM machine address
register (mar). This patch adds such support to the FSL-UPM driver.
This patch adds support for multi-chip NAND devices to the FSL-UPM
driver. The "dev_ready" callback of the "struct fsl_upm_nand" is now
called with the argument "chip_nr" to allow testing the proper chip
select line. The NAND support of the MPC8360ERDK is updated as well.
No other boards are currently using the FSL UPM driver.
The U-Boot UBIFS implementation is largely a direct copy from the current
Linux version (2.6.29-rc6). As already done in the UBI version we have an
"abstraction layer" to redefine or remove some OS calls (e.g. mutex_lock()
...). This makes it possible to use the original Linux code with very
little changes. And by this we can better update to later Linux versions.
I removed some of the Linux features that are not used in the U-Boot
version (e.g. garbage-collection, write support).
CC: Artem Bityutskiy <dedekind@infradead.org>
CC: Adrian Hunter <ext-Adrian.Hunter@nokia.com>
This patch adds LZO decompression support to U-Boot. It is needed for
the upcoming UBIFS support, since UBIFS uses LZO as default compressor/
decompressor. Since we only support read-only in UBIFS, only the
decompressor is needed.
All this is copied with minor changes from the current Linux kernel
version (2.6.28-rc8).
This patch only implements this LZO decompressor support for PPC.
Other platforms using UBIFS will have to add the required
"include/asm/unaligned.h" as well. It should be fairly easy to copy this
from the Linux source tree as I have done it for PPC in this patch.
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and
changes the default from 8 to 1 for the legacy and the new MTD
NAND layer. This allows to remove all NAND_MAX_CHIPS definitions
in the board config files because none of the boards use multi
chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440
define
#define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE
but that's bogus and did not work anyhow.
- Add subpage write support
- Add onenand_oob_64/32 ecclayout
This has been missing and without it UBI has some incompatibilies issues
with the current (>= 2.6.27) Linux kernel version. vid_hdr_offset is
placed differently (2048 instead of 512) without this fix.
Sync with OneNAND kernel codes
This patch adds basic UBI (Unsorted Block Image) support to U-Boot.
It's based on the Linux UBI version and basically has a "OS"
translation wrapper that defines most Linux specific calls
(spin_lock() etc.) into no-ops. Some source code parts have been
uncommented by "#ifdef UBI_LINUX". This makes it easier to compare
this version with the Linux version and simplifies future UBI
ports/bug-fixes from the Linux version.
This removes in nand.h code that is verbatim duplicated from bbm.h,
including directly bbm.h in nand.h. The previous state of affairs
prevented compiling code for a board hosting both NAND and OneNAND chips.
Reported-by: Scott Wood <scottwood@freescale.com>
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
This brings the core NAND code up to date with the Linux kernel.
Since there were several drivers in Linux as of the last update that are
not in u-boot, I'm not bringing over new drivers that have been added
since in the absence of an interested party.
I did not update OneNAND since it was recently synced by Kyungmin Park,
and I'm not sure exactly what the common ancestor is.
Now it's used at UBI module. Of course other modules can use it.
If you want to use it, please define CONFIG_RBTREE
Also sync with kernel OneNAND codes
