path: root/include/linux
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2014-01-09add weak entry definitionDavid Feng
Signed-off-by: David Feng <fenghua@phytium.com.cn>
2014-01-08Add crc8 routineSimon Glass
Add an implementation of the CRC8 algorithm. This is required by the TPM emulation, but is probably useful to U-Boot in general. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-11-21mtd: move & update nand_ecclayout structure (plus board changes)Prabhakar Kushwaha
nand_ecclayout is present in mtd.h at Linux. Move this structure to mtd.h to comply with Linux. Also, increase the ecc placement locations to 640 to suport device having writesize/oobsize of 8KB/640B. This means that the maximum oobsize has gone up to 640 bytes and consequently the maximum ecc placement locations have also gone up to 640. Changes from Prabhabkar's version (squashed into one patch to preserve bisectability): - Added _LARGE to MTD_MAX_*_ENTRIES This makes the names match current Linux source, and resolves a conflict between http://patchwork.ozlabs.org/patch/280488/ and http://patchwork.ozlabs.org/patch/284513/ The former was posted first and is closer to matching Linux, but unlike Linux it does not add _LARGE to the names. The second adds _LARGE to one of the names, and depends on it in a subsequent patch (http://patchwork.ozlabs.org/patch/284512/). - Made max oobfree/eccpos configurable, and used this on tricorder, alpr, ASH405, T4160QDS, and T4240QDS (these boards failed to build for me without doing so, due to a size increase). On tricorder SPL, this saves 2576 bytes (and makes the SPL build again) versus the new default of 640 eccpos and 32 oobfree, and saves 336 bytes versus the old default of 128 eccpos and 8 oobfree. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> CC: Vipin Kumar <vipin.kumar@st.com> [scottwood@freescale.com: changes as described above] Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Thomas Weber <weber@corscience.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Stefan Roese <sr@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Stefan Roese <sr@denx.de>
2013-11-08include: delete include/linux/config.hMasahiro Yamada
Linux Kernel abolished include/linux/config.h long time ago. (around version v2.6.18..v2.6.19) We don't need to provide Linux copatibility any more. This commit deletes include/linux/config.h and fixes source files not to include this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-20usb: am437x: Add support for am437x xhci USB hostDan Murphy
Add the support for the am437x xhci usb host. The xHCI host on AM437 is connected to a usb2 phy so need to add support to enable those clocks. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-10-20usb: dra7xx: Add support for dra7xx xhci USB hostDan Murphy
Add the support for the dra7xx xhci usb host. dra7xx does not contain an EHCI controller so the headers can be removed from the board file. The xHCI host on dra7xx is connected to a usb2 phy so need to add support to enable those clocks. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-10-20usb: omap: Move the usb phy code to the usb/phy directoryDan Murphy
Moving the usb/phy code from xhci-omap to the usb/phy directory and moving the associated phy code over to the new file. Newer TI processors adding xHCI support will have different PHY configurations so therefore abstracting this code away will prevent messing around with the xhci-omap file itself. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-10-20usb: omap: Move the xhci-omap header file to common locationDan Murphy
Moving the xhci-omap header to a more global location so that other code can reference this code. Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-10-20USB: XHCI: Add xHCI host controller support for Exynos5Vivek Gautam
This adds driver layer for xHCI controller in Samsung's exynos5 soc. This interacts with xHCI host controller stack. Signed-off-by: Vikas C Sajjan <vikas.sajjan@samsung.com> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Julius Werner <jwerner@chromium.org> Cc: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Dan Murphy <dmurphy@ti.com> Cc: Marek Vasut <marex@denx.de>
2013-10-09mtd: driver _read() returns max_bitflips; mtd_read() returns -EUCLEANPaul Burton
Linux modified the MTD driver interface in commit edbc4540 (with the same name as this commit). The effect is that calls to mtd_read will not return -EUCLEAN if the number of ECC-corrected bit errors is below a certain threshold, which defaults to the strength of the ECC. This allows -EUCLEAN to stop indicating "some bits were corrected" and begin indicating "a large number of bits were corrected, the data held in this region of flash may be lost soon". UBI makes use of this and when -EUCLEAN is returned from mtd_read it will move data to another block of flash. Without adopting this interface change UBI on U-boot attempts to move data between blocks every time a single bit is corrected using the ECC, which is a very common occurance on some devices. For some devices where bit errors are common enough, UBI can get stuck constantly moving data around because each block it attempts to use has a single bit error. This condition is hit when wear_leveling_worker attempts to move data from one PEB to another in response to an -EUCLEAN/UBI_IO_BITFLIPS error. When this happens ubi_eba_copy_leb is called to perform the data copy, and after the data is written it is read back to check its validity. If that read returns UBI_IO_BITFLIPS (in response to an MTD -EUCLEAN) then ubi_eba_copy_leb returns 1 to wear_leveling worker, which then proceeds to schedule the destination PEB for erasure. This leads to erase_worker running on the PEB, and following a successful erase wear_leveling_worker is called which begins this whole cycle all over again. The end result is that (without UBI debug output enabled) the boot appears to simply hang whilst in reality U-boot busily works away at destroying a block of the NAND flash. Debug output from this situation: UBI DBG: ensure_wear_leveling: schedule scrubbing UBI DBG: wear_leveling_worker: scrub PEB 1027 to PEB 4083 UBI DBG: ubi_io_read_vid_hdr: read VID header from PEB 1027 UBI DBG: ubi_io_read: read 4096 bytes from PEB 1027:4096 UBI DBG: ubi_eba_copy_leb: copy LEB 0:0, PEB 1027 to PEB 4083 UBI DBG: ubi_eba_copy_leb: read 1040384 bytes of data UBI DBG: ubi_io_read: read 1040384 bytes from PEB 1027:8192 UBI: fixable bit-flip detected at PEB 1027 UBI DBG: ubi_io_write_vid_hdr: write VID header to PEB 4083 UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:4096 UBI DBG: ubi_io_read_vid_hdr: read VID header from PEB 4083 UBI DBG: ubi_io_read: read 4096 bytes from PEB 4083:4096 UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:8192 UBI DBG: ubi_io_read: read 4096 bytes from PEB 4083:8192 UBI: fixable bit-flip detected at PEB 4083 UBI DBG: schedule_erase: schedule erasure of PEB 4083, EC 55, torture 0 UBI DBG: erase_worker: erase PEB 4083 EC 55 UBI DBG: sync_erase: erase PEB 4083, old EC 55 UBI DBG: do_sync_erase: erase PEB 4083 UBI DBG: sync_erase: erased PEB 4083, new EC 56 UBI DBG: ubi_io_write_ec_hdr: write EC header to PEB 4083 UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:0 UBI DBG: ensure_wear_leveling: schedule scrubbing UBI DBG: wear_leveling_worker: scrub PEB 1027 to PEB 4083 ... This patch adopts the interface change as in Linux commit edbc4540 in order to avoid such situations. Given that none of the drivers under drivers/mtd return -EUCLEAN, this should only affect those using software ECC. I have tested that it works on a board which is currently out of tree, but which I hope to be able to begin upstreaming soon. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Stefan Roese <sr@denx.de>
2013-10-07include/linux/fb.h: Add a missing include for 'list.h'Otavio Salvador
The modelist data uses the list definition but the 'list.h' header were not being included. The build failure is bellow: ,---- | In file included from yyyy.c:16:0: | .../u-boot/include/linux/fb.h:503:19: error: field 'modelist' has incomplete type | struct list_head modelist; /* mode list */ | ^ | make[1]: *** [yyyy.o] Error 1 | make[1]: Leaving directory `.../u-boot/board/xxx/yyyy' | make: *** [board/xxx/yyyy/libyyyy.o] Error 2 `---- Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-09-24usb:gadget:Remove redundant #includes for USB composite gadget and its functionsLukasz Majewski
Only the <linux/usb/gadget.h> requires error.h include. Hence, several includes of error.h at USB gadget functions are not needed. Moreover unnecessary malloc.h includes were also removed. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-09-24USB: gadget: add atmel usba udc driverBo Shen
Add atmel usba udc driver support, porting from Linux kernel The original code in Linux Kernel information is as following commit e01ee9f509a927158f670408b41127d4166db1c7 Author: Jingoo Han <jg1.han@samsung.com> Date: Tue Jul 30 17:00:51 2013 +0900 usb: gadget: use dev_get_platdata() Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2013-09-06Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-06compiler_gcc: do not redefine __gnu_attributesJeroen Hofstee
gcc allows extensions to be non compiler specific by defining __* macros for the attributes supported by gcc. Having a different definition causes many warnings during the build (cdefs.h on FreeBSD uses __attribute((__pure__)) where u-boot uses __attribute__((pure)) for example). Do not redefine these macros to suppress these warnings. This patch ignores the checkpatch warning: WARNING: __packed is preferred over __attribute__((packed)) Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-08-22linux/compat.h: move dev_err, dev_info and dev_dbg from usb driver to compat.hWu, Josh
Since kernel code current use many dev_xxx() instead of using printk. To compatible, move those dev_xxx from usb driver to linux/compat.h. Then all driver code can use dev_err, dev_info and dev_vdbg. This patch also removed duplicated macro definitions in usb driver. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-06-30usb: fix unaligned access in device_qual()Heiko Schocher
while playing with dfu, I tapped in an unaligned access when doing on the host side a "lsusb -d [vendornr]: -v" I get on the board: GADGET DRIVER: usb_dnl_dfu data abort MAYBE you should read doc/README.arm-unaligned-accesses pc : [<8ff71db8>] lr : [<8ff75aec>] sp : 8ef40d18 ip : 00000005 fp : 00000000 r10: 00000000 r9 : 47401410 r8 : 8ef40f38 r7 : 8ef4aae8 r6 : 0000000a r5 : 8ef4ab28 r4 : 8ef4ab80 r3 : 0000000a r2 : 00000006 r1 : 00000006 r0 : 8ef4aae8 Flags: Nzcv IRQs off FIQs on Mode SVC_32 Resetting CPU ... reason is that in the "struct usb_composite_dev" the "struct usb_device_descriptor desc;" is on an odd address, and this struct gets accessed in drivers/usb/gadget/composite.c device_qual() Fix it, by align this var "struct desc" fix to an aligned address. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Samuel Egli <samuel.egli@siemens.com>
2013-06-24add support for Xilinx 1000BASE-X phy (GTX)Charles Coldwell
commit 39695029bc15041c809df3db4ba19bd729c447fa Author: Charles Coldwell <coldwell@ll.mit.edu> Date: Tue Feb 19 08:27:33 2013 -0500 Changes to support the Xilinx 1000BASE-X phy (GTX/MGT) Signed-off-by: Charles Coldwell <coldwell@ll.mit.edu>
2013-06-12usb: Use get_unaligned() in usb_endpoint_maxp() for wMaxPacketSizeVivek Gautam
Use unaligned access to fetch wMaxPacketSize in usb_endpoint_maxp() api. In its absence we see following data abort message: ============================================================== data abort MAYBE you should read doc/README.arm-unaligned-accesses pc : [<bf794e24>] lr : [<bf794e1c>] sp : bf37c7b0 ip : 0000002f fp : 00000000 r10: 00000000 r9 : 00000002 r8 : bf37fecc r7 : 00000001 r6 : bf7d8931 r5 : bf7d891c r4 : bf7d8800 r3 : bf7d65b0 r2 : 00000002 r1 : bf7d65b4 r0 : 00000027 Flags: nZCv IRQs off FIQs off Mode SVC_32 Resetting CPU ... resetting ... ============================================================== Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Ilya Yanok <ilya.yanok@cogentembedded.com> Cc: Marek Vasut <marex@denx.de>
2013-05-31Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2013-05-05mtd: nand: add driver for diskonchip g4 nand flashMike Dunn
This patch adds a driver for the diskonchip G4 nand flash device. It is based on the driver from the linux kernel. This also includes a separate SPL driver. A separate SPL driver is used because the device operates in a different mode (reliable mode) when loading a boot image, and also because the storage format of the boot image is different from normal data (pages are stored redundantly). The SPL driver basically mimics how a typical IPL reads data from the device. The special operating mode and storage format are used to compensate for the fact that the IPL does not contain the BCH ecc decoding algorithm (due to size constraints). Although the u-boot SPL *could* use ecc, it operates like an IPL for the sake of simplicity and uniformity, since the IPL and SPL share the task of loading the u-boot image. As a side benefit, the SPL driver is very small. [port from linux kernel 3.4 commit 570469f3bde7f71cc1ece07a18d54a05b6a8775d] Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-05-05lib: import bitrev library from the linux kernelMike Dunn
This patch adds the bitrev library from the linux kernel. This is a simple algorithm that uses an 8 bit look-up table to reverse the bits in data types of 8, 16, or 32 bit widths. The docg4 nand flash driver uses it. [port from linux kernel v3.9 commit 7ee32a6d30d1c8a3b7a07a6269da8f0a08662927] [originally added: v2.6.20 by commit a5cfc1ec58a07074dacb6aa8c79eff864c966d12] Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2012-12-13Make linux kernel string funcs available to toolsJoe Hershberger
isspace() and strim() are not in the typical user-mode string.h, so put them in a separate compilation unit so that they can be built into tools that need them independent of the other common string functions. This allows code shared by u-boot and the linux user-mode tools to link. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-11Add strcasecmp() and strncasecmp()Simon Glass
strncasecmp() is present as strnicmp() but disabled. Make it available and define strcasecmp() also. There is a only a small performance penalty to having strcasecmp() call strncasecmp(), so do this instead of a standalone function, to save code space. Update the prototype in arch-specific headers as needed to avoid warnings. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-30include/linux/byteorder: Always defines __fswab64, __swab64p and __swab64sNobuhiro Iwamatsu
When __BYTEORDER_HAS_U64__ is not defined, we got warning following: ----- /tmp/include/linux/byteorder/little_endian.h: In function ‘__cpu_to_be64p’: /tmp/include/linux/byteorder/little_endian.h:71:2: warning: implicit declaration of function ‘__swab64p’ [-Wimplicit-function-declaration] ----- Usually, __arch__swab64* required for __fswab64, __swab64p and __swab64s is defined. Therefore, __BYTEORDER_HAS_U64__ is unnecessary. This removes __BYTEORDER_HAS_U64__. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Kim Phillips <kim.phillips@freescale.com> Reviewed-by: Kim Phillips <kim.phillips@freescale.com>
2012-11-26Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2012-11-26nand: Move the sub-page read support enable to a flagJoe Hershberger
Use a flag instead of a hard-coded macro so that sub-page reads can be enabled in other cases (such as on-die ecc). This is the same as a5ff4f102937a3492bca4a9ff0c341d78813414c in Linux Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-11-20musb-new: port of Linux musb driverIlya Yanok
Existing U-Boot musb driver has no support for the new gadget framework and also seems to have other limitations. As gadget framework is ported from Linux it seems pretty natural to port musb gadget driver as well. This driver supports both host and peripheral modes. This is not a replacement for current musb driver (at least now) as there are still some consumers of the old UDC interface. No DMA operation support included, CONFIG_MUSB_PIO_ONLY should be defined. Virtual root hub device is not implemented. Known problems: with no devices connected usb_lowlevel_start() fails. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
2012-11-20linux/usb/ch9.h: update with the version from Linux treeIlya Yanok
2012-11-04include/linux/stddef.h: avoid 'warning: preprocessor token offsetof redefined'Kim Phillips
hack to avoid: /opt/gcc-4.6.3-nolibc/powerpc-linux/bin/../lib/gcc/powerpc-linux/4.6.3/include/stddef.h:413:9: warning: preprocessor token offsetof redefined u-boot/include/linux/stddef.h:20:9: this was the original definition tried protecting with __KERNEL__, and #including compiler.h first. Even tried include dir reordering to no avail: +++ b/config.mk @@ -194,7 +194,11 @@ OBJCFLAGS += --gap-fill=0xff gccincdir := $(shell $(CC) -print-file-name=include) CPPFLAGS := $(DBGFLAGS) $(OPTFLAGS) $(RELFLAGS) \ - -D__KERNEL__ + -D__KERNEL__ \ + -I $(gccincdir) \ + -nostdinc + +# -isystem $(gccincdir) \ # Enable garbage collection of un-used sections for SPL ifeq ($(CONFIG_SPL_BUILD),y) @@ -227,8 +231,7 @@ CPPFLAGS += -I$(OBJTREE)/include2 -I$(OBJTREE)/include endif CPPFLAGS += -I$(TOPDIR)/include -CPPFLAGS += -fno-builtin -ffreestanding -nostdinc \ - -isystem $(gccincdir) -pipe $(PLATFORM_CPPFLAGS) +CPPFLAGS += -fno-builtin -ffreestanding -pipe $(PLATFORM_CPPFLAGS) Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-11-04include/linux/unaligned/generic.h: fix warning: preprocessor token __force ↵Kim Phillips
redefined include/linux/unaligned/generic.h:5:9: warning: preprocessor token __force redefined include/linux/compiler.h:10:10: this was the original definition fixup __force definitions in compat.h code appears to be placed there as a cover up from a code import from linux when u-boot didn't yet have a compiler.h, introduced by commit b1b4e89a0f3b75854c39a62cae41bad56d210adf "Add LZO decompressor support". Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-11-04include/linux/compat.h: fix warning: preprocessor token {__iomem, __user} ↵Kim Phillips
redefined include/linux/compat.h:4:9: warning: preprocessor token __user redefined include/linux/compiler.h:7:10: this was the original definition include/linux/compat.h:5:9: warning: preprocessor token __iomem redefined include/linux/compiler.h:12:10: this was the original definition fixup __iomem, __user definitions in compat.h code appears to be placed there as a cover up from a code import from linux when u-boot didn't yet have a compiler.h, introduced by commit 932394ac43e2e778e664eeb6e456fecd0fae6e59 "Rewrite of NAND code based on what is in 2.6.12 Linux kernel". Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-11-04include/linux/byteorder: import latest endian definitions from linuxKim Phillips
u-boot's byteorder headers did not contain endianness attributions for use with sparse, causing a lot of false positives. Import the kernel's latest definitions, and enable them by including compiler.h and types.h. They come with 'const' added for some swab functions, so fix those up, too: include/linux/byteorder/big_endian.h:46:2: warning: passing argument 1 of '__swab64p' discards 'const' qualifier from pointer target type [enabled by default] Also, note: u-boot's historic __BYTE_ORDER definition has been preserved (for the time being at least). We also remove ad-hoc barrier() definitions, since we're including compiler.h in files that hadn't in the past: macb.c:54:0: warning: "barrier" redefined [enabled by default] In addition, including compiler.h in byteorder changes the 'noinline' definition to expand to __attribute__((noinline)). This fixes arch/powerpc/lib/bootm.c: bootm.c:329:16: error: attribute '__attribute__': unknown attribute bootm.c:329:16: error: expected ')' before '__attribute__' bootm.c:329:25: error: expected identifier or '(' before ')' token powerpc sparse builds yield: include/common.h:356:22: error: marked inline, but without a definition the unknown-reason inlining without a definition is considered obsolete given it was part of the 2002 initial commit, and no arm version was 'fixed.' also fixed: ydirectenv.h:60:0: warning: "inline" redefined [enabled by default] and: Configuring for devconcenter - Board: intip, Options: DEVCONCENTER make[1]: *** [4xx_ibm_ddr2_autocalib.o] Error 1 make: *** [arch/powerpc/cpu/ppc4xx/libppc4xx.o] Error 2 powerpc-fsl-linux-size: './u-boot': No such file 4xx_ibm_ddr2_autocalib.c: In function 'DQS_autocalibration': include/asm/ppc4xx-sdram.h:1407:13: sorry, unimplemented: inlining failed in call to 'ppc4xx_ibm_ddr2_register_dump': function body not available 4xx_ibm_ddr2_autocalib.c:1243:32: sorry, unimplemented: called from here and: In file included from crc32.c:50:0: crc32table.h:4:1: warning: implicit declaration of function '___constant_swab32' [-Wimplicit-function-declaration] crc32table.h:4:1: error: initializer element is not constant crc32table.h:4:1: error: (near initialization for 'crc32table_le[0]') Signed-off-by: Kim Phillips <kim.phillips@freescale.com> [trini: Remove '#endif' in include/common.h around setenv portion] Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15COMMON: Add __stringify() functionMarek Vasut
Copied from Linux kernel: commit 8f7c2c37319a81ef4c2bfdec67b1ccd5744d97e4 Date: Wed Apr 8 16:58:57 2009 +0800 Pull in the __stringify() macro from Linux kernel. This macro is usually used to convert numbers to strings at preprocessor level, yet it is not limited only to that. This is useful as it allows higher usage of puts() in favour of printf(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-09-21Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-09-17mtd: nand: allow NAND_NO_SUBPAGE_WRITE to be set from driverMarek Vasut
This is based on Linux kernel -next: commit 14f44abf1dafc20ba42ce8616a8fc8fbd1b3712b Author: Brian Norris <computersforpeace@gmail.com> Date: Fri Jul 13 09:28:24 2012 -0700 mtd: nand: allow NAND_NO_SUBPAGE_WRITE to be set from driver The NAND_CHIPOPTIONS_MSK has limited utility and is causing real bugs. It silently masks off at least one flag that might be set by the driver (NAND_NO_SUBPAGE_WRITE). This breaks the GPMI NAND driver and possibly others. Really, as long as driver writers exercise a small amount of care with NAND_* options, this mask is not necessary at all; it was only here to prevent certain options from accidentally being set by the driver. But the original thought turns out to be a bad idea occasionally. Thus, kill it. Note, this patch fixes some major gpmi-nand breakage. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Brian Norris <computersforpeace@gmail.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Fabio Estevam <festevam@gmail.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-09-17nand: consolidate duplicated constantsJoe Hershberger
NAND_CMD_ constants for lock/unlock should be in the header Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2012-09-07nand: Try to align the default buffersSimon Glass
The NAND layer needs to use cache-aligned buffers by default. Towards this goal. align the default buffers and their members according to the minimum DMA alignment defined for the architecture. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Scott Wood <scottwood@freescale.com>
2012-07-07st_smi: Change SMI timeout valuesAmit Virdi
Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07st_smi: Add support for SPEAr SMI driverVipin KUMAR
SMI is the serial memory interface controller provided by ST. Earlier, a driver exists in the u-boot source code for the SMI IP. However, it was specific to spear platforms. This commit converts the same driver to a more generic driver. As a result, the driver files are renamed to st_smi.c and st_smi.h and moved into drivers/mtd folder for reusability by other platforms using smi controller peripheral. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de>
2012-07-07mtd/NAND: Add FSMC driver supportVipin KUMAR
Flexible static memory controller is a peripheral provided by ST, which controls the access to NAND chips along with many other memory device chips eg NOR, SRAM. This patch adds the driver support for FSMC controller interfacing with NAND memory. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Scott Wood <scottwood@freescale.com>
2012-05-20Merge branch 'master' of git://git.denx.de/u-boot-usbWolfgang Denk
* 'master' of git://git.denx.de/u-boot-usb: USB: S5P: Add ehci support usb:udc:samsung Add functions for storing private gadget data in UDC driver usb:gadget:composite: Support for composite at gadget.h usb:gadget:composite USB composite gadget support usb:udc:samsung:cleanup Replace DEBUG_* macros with debug_cond() calls usb:udc: Remove duplicated USB definitions from include/linux/usb/ch9.h file USB: Document the QH and qTD antics in EHCI-HCD USB: Drop cache flush bloat in EHCI-HCD USB: Drop ehci_alloc/ehci_free in ehci-hcd USB: Align buffers at cacheline usb: use noinline define
2012-05-20usb:gadget:composite: Support for composite at gadget.hLukasz Majewski
Add device data pointer to the USB gadget's device struct. Wrapper for extracting usb_gadget from Linux's usb device Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de>
2012-05-20usb:gadget:composite USB composite gadget supportLukasz Majewski
USB Composite gadget implementation for u-boot. It builds on top of USB UDC drivers. This commit is based on following files from Linux Kernel v2.6.36: ./include/linux/usb/composite.h ./drivers/usb/gadget/composite.c SHA1: d187abb9a83e6c6b6e9f2ca17962bdeafb4bc903 Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de>
2012-05-20usb:udc: Remove duplicated USB definitions from include/linux/usb/ch9.h fileLukasz Majewski
Remove the repeated USB descriptor code and use usbdescriptors.h file. ch9.h file has been copied from linux and is needed for USB gadget related work. Now usbdescriptors.h and ch9.h shall be used together. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de>
2012-05-15input: Add linux/input.h for key code supportSimon Glass
We want to able to decode Linux fdt keymaps, so bring part of this enormous header file over to U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
