path: root/include/linux
2009-03-23Add wait flags to support board/chip specific delaysWolfgang Grandegger
The NAND flash on the TQM8548_BE modules requires a short delay after running the UPM pattern like the MPC8360ERDK board does. The TQM8548_BE requires a further short delay after writing out a buffer. Normally the R/B pin should be checked, but it's not connected on the TQM8548_BE. The corresponding Linux FSL UPM driver uses similar delay points at the same locations. To manage these extra delays in a more general way, I introduced the "wait_flags" field allowing the board-specific driver to specify various types of extra delay. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-23Add support for TQM-specific chip select logic to FSL-UPMWolfgang Grandegger
For the NAND chips on the TQM8548 modules, a special chip-select logic is used. It uses dedicated address lines to be set via UPM machine address register (mar). This patch adds such support to the FSL-UPM driver. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-23Add multi chip support to the FSL-UPM driverWolfgang Grandegger
This patch adds support for multi-chip NAND devices to the FSL-UPM driver. The "dev_ready" callback of the "struct fsl_upm_nand" is now called with the argument "chip_nr" to allow testing the proper chip select line. The NAND support of the MPC8360ERDK is updated as well. No other boards are currently using the FSL UPM driver. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-20UBIFS: Implement read-only UBIFS support in U-BootStefan Roese
The U-Boot UBIFS implementation is largely a direct copy from the current Linux version (2.6.29-rc6). As already done in the UBI version we have an "abstraction layer" to redefine or remove some OS calls (e.g. mutex_lock() ...). This makes it possible to use the original Linux code with very little changes. And by this we can better update to later Linux versions. I removed some of the Linux features that are not used in the U-Boot version (e.g. garbage-collection, write support). Signed-off-by: Stefan Roese <sr@denx.de> CC: Artem Bityutskiy <dedekind@infradead.org> CC: Adrian Hunter <ext-Adrian.Hunter@nokia.com>
2009-03-20Add LZO decompressor supportStefan Roese
This patch adds LZO decompression support to U-Boot. It is needed for the upcoming UBIFS support, since UBIFS uses LZO as default compressor/ decompressor. Since we only support read-only in UBIFS, only the decompressor is needed. All this is copied with minor changes from the current Linux kernel version (2.6.28-rc8). This patch only implements this LZO decompressor support for PPC. Other platforms using UBIFS will have to add the required "include/asm/unaligned.h" as well. It should be fairly easy to copy this from the Linux source tree as I have done it for PPC in this patch. Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-01-23OneNAND: Additional sync with 2.6.27Stefan Roese
- Add subpage write support - Add onenand_oob_64/32 ecclayout This has been missing and without it UBI has some incompatibilies issues with the current (>= 2.6.27) Linux kernel version. vid_hdr_offset is placed differently (2048 instead of 512) without this fix. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-01-23Sync with 2.6.27Kyungmin Park
Sync with OneNAND kernel codes Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-12-16Coding style cleanup, update CHANGELOG.Wolfgang Denk
2008-11-19UBI: Add basic UBI support to U-Boot (Part 8/8)Kyungmin Park
This patch adds basic UBI (Unsorted Block Image) support to U-Boot. It's based on the Linux UBI version and basically has a "OS" translation wrapper that defines most Linux specific calls (spin_lock() etc.) into no-ops. Some source code parts have been uncommented by "#ifdef UBI_LINUX". This makes it easier to compare this version with the Linux version and simplifies future UBI ports/bug-fixes from the Linux version. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-19UBI: Add basic UBI support to U-Boot (Part 7/8)Kyungmin Park
2008-11-19UBI: Add basic UBI support to U-Boot (Part 6/8)Kyungmin Park
2008-10-31NAND: Allow NAND and OneNAND to coexistAlessandro Rubini
This removes in nand.h code that is verbatim duplicated from bbm.h, including directly bbm.h in nand.h. The previous state of affairs prevented compiling code for a board hosting both NAND and OneNAND chips. Reported-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alessandro Rubini <rubini@unipv.it> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-10-29NAND: sync with 2.6.27Scott Wood
This brings the core NAND code up to date with the Linux kernel. Since there were several drivers in Linux as of the last update that are not in u-boot, I'm not bringing over new drivers that have been added since in the absence of an interested party. I did not update OneNAND since it was recently synced by Kyungmin Park, and I'm not sure exactly what the common ancestor is. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-10-18Add Red Black Tree supportKyungmin Park
Now it's used at UBI module. Of course other modules can use it. If you want to use it, please define CONFIG_RBTREE Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-09-13Coding style cleanup, update CHANGELOGWolfgang Denk
2008-08-31update linux/listJean-Christophe PLAGNIOL-VILLARD
2008-08-21Fix OneNAND read_oob/write_oob functions compatabilityKyungmin Park
Also sync with kernel OneNAND codes Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-14Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-08-14Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2008-08-13Fix OneNAND build breakKyungmin Park
Since page size field is changed from oobblock to writesize. But OneNAND is not updated. - fix bufferram management at erase operation This patch includes the NAND/OneNAND state filed too. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-12NAND: Scan bad blocks lazily.Ilya Yanok
Rather than scanning on boot, scan upon the first attempt to check the badness of a block. This speeds up boot when not using NAND, and reduces the likelihood of needing to reflash via JTAG if NAND becomes nonfunctional. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12nand: fsl_upm: convert to updated MTD NAND infrastructureAnton Vorontsov
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Remove white space at end.William Juul
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-09NAND: Rename DEBUG to MTDDEBUG to avoid namespace pollution.Scott Wood
This is particularly problematic now that non-NAND-specific code is including <nand.h>, and thus all debugging code is being compiled regardless of whether it was requested, as reported by Scott McNutt <smcnutt@psyent.com>. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-06-11NAND: Added support for 128-bit OOB, adaptedSergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2008-06-10NAND FSL UPM: driver re-write using the hwcontrol callbackWolfgang Grandegger
This is a re-write of the NAND FSL UPM driver using the more universal hwcontrol callback (instead of the cmdfunc callback). Here is a brief list of furher modifications: - For the time being, the UPM setup writing the UPM array has been removed from the driver and must now be done by the board specific code. - The bus width definition in "struct fsl_upm_nand" is now in bits to comply with the corresponding Linux driver and 8, 16 and 32 bit accesses are supported. - chip->dev_read is only set if fun->dev_ready != NULL, which is required for boards not connecting the R/B pin. - A few issue have been fixed with MxMR bit manipulation like in the corresponding Linux driver. Note: I think the "io_addr" field of "struct fsl_upm" could be removed as well, because the address is already determined by "nand->IO_ADDR_[RW]", but I'm not 100% sure. This patch has been tested on a TQM8548 modules with the NAND chip Micron MT29F8G08FABWP. This patch is based on the following patches posted to this list a few minutes ago: PPC: add accessor macros to clear and set bits in one shot 83xx/85xx/86xx: add more MxMR local bus definitions Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-05-28NAND: Provide a sane default for NAND_MAX_CHIPS.Scott Wood
This allows the header to be included regardless of whether a board's config file provides NAND-related defininitions. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-03-28sh: Add support stat structure and stat.hNobuhiro Iwamatsu
2008-01-16nand: FSL UPM NAND driverAnton Vorontsov
2008-01-09fix various commentsMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2007-09-17OneNAND support (take #2)Kyungmin Park
[PATCH 3/3] OneNAND support (take #2) OneNAND support at U-Boot Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2007-05-24[PATCH][NAND] Define the Vendor Id for Micron NAND FlashUlf Samuelsson
Signed-off-by: Ulf Samuelsson <ulf@atmel.com> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Stefan Roese <sr@denx.de>
2007-05-08Merge git://www.denx.de/git/u-bootMichal Simek
Conflicts: include/asm-microblaze/microblaze_intc.h include/linux/stat.h
2007-04-24[PATCH] MTD partition support, JFFS2 supportMichal Simek
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-avr32; code cleanup.Wolfgang Denk
2007-04-14Import <linux/mii.h> from the Linux kernelHaavard Skinnemoen
Instead of creating yet another set of MII register definitions in the macb driver, here's a complete set of definitions for everyone to use. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-14AVR32: Provide a definition of struct statHaavard Skinnemoen
Copy the definition of struct stat from the Linux kernel. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-03-09[Blackfin][PATCH-2/2] Common files changed to support bf533 platformAubrey.Li
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2006-07-21Code cleanupWolfgang Denk
2006-05-03Scheduled for removal: strnicmp() which is unusedWolfgang Denk
2006-04-05Remove dependencies between DoC code and old legacy NAND driver.Marian Balakowicz
Necessary defines and data structures were copied to DoC specific files so that legacy NAND code could be entirely removed from u-boot tree in the near future.
2006-03-12Add ADI Blackfin supportWolfgang Denk
- add support for Analog Devices Blackfin BF533 CPU - add support for the ADI BF533 Stamp uClinux board - add support for the ADI BF533 EZKit board Patches by Richard Klingler, June 11th 2005:
2006-03-06Minor code cleanupWolfgang Denk
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
