path: root/include/linux
2015-08-25mtd: nand: Increase max sizes of OOB and Page sizeSiva Durga Prasad Paladugu
Increase max sizes for OOB, Page size and eccpos to suit for Micron MT29F32G08 part Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
2015-08-25nand: Sync with Linux v4.1Scott Wood
Update the NAND code to match Linux v4.1. The previous sync was from Linux v3.15 in commit 4e67c57125290b25. CONFIG_SYS_NAND_RESET_CNT is removed, as the upstream Linux code now has its own timeout. Plus, CONFIG_SYS_NAND_RESET_CNT was undocumented and not selected by any board. Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-08-25mtd: Introduce mtd_block_isreserved()Ezequiel Garcia
In addition to mtd_block_isbad(), which checks if a block is bad or reserved, it's needed to check if a block is reserved only (but not bad). This commit adds an MTD interface for it, in a similar fashion to mtd_block_isbad(). While here, fix mtd_block_isbad() so the out-of-bounds checking is done before the callback check. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Pekon Gupta <pekon@ti.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com> [scottwood: Cherry-picked from Linux 8471bb73ba10ed67] Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-08-25nand: Remove __UBOOT__ ifdefsScott Wood
I didn't approve the patch that added them. Get them out of the way before doing a sync. Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-08-18linux/kconfig.h: add CPP macros useful for per-image config optionsMasahiro Yamada
The previous commit introduced a useful macro used in makefiles, in order to reference to different variables (CONFIG_... or CONFIG_SPL_...) depending on the build context. Per-image config option control is a PITA in C sources, too. Here are some macros useful in C/CPP expressions. CONFIG_IS_ENABLED(FOO) can be used as a shorthand for (!defined(CONFIG_SPL_BUILD) && defined(CONFIG_FOO)) || \ (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_FOO)) For example, it is useful to describe C code as follows, #if CONFIG_IS_ENABLED(OF_CONTROL) (device tree code) #else (board file code) #endif The ifdef conditional above is switched by CONFIG_OF_CONTROL during the U-Boot proper building (CONFIG_SPL_BUILD is not defined), and by CONFIG_SPL_OF_CONTROL during SPL building (CONFIG_SPL_BUILD is defined). The macro can be used in C context as well, so you can also write the equivalent code as follows: if (CONFIG_IS_ENABLED(OF_CONTROL)) { (device tree code) } else { (board file code) } Another useful macro is CONFIG_VALUE(). CONFIG_VALUE(FOO) is expanded into CONFIG_FOO if CONFIG_SPL_BUILD is undefined, and into CONFIG_SPL_FOO if CONFIG_SPL_BUILD is defined. You can write as follows: text_base = CONFIG_VALUE(TEXT_BASE); instead of: #ifdef CONFIG_SPL_BUILD text_base = CONFIG_SPL_TEXT_BASE; #else text_base = CONFIG_TEXT_BASE; #endif This commit also adds slight hacking on fixdep so that it can output a correct list of fixed dependencies. If the fixdep finds CONFIG_IS_ENABLED(FOO) in a source file, we want $(wildcard include/config/foo.h) in the U-boot proper building context, while we want $(wildcard include/config/spl/foo.h) in the SPL build context. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-08-05Bring in __aligned_u64 and friends to linux/types.hSimon Glass
These will be used for efi.h both for U-Boot running as an EFI application and as a payload. They come from Linux 4.1. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-24Merge git://git.denx.de/u-boot-usbTom Rini
2015-07-22linux_compat: handle __GFP_ZERO in kmalloc()Masahiro Yamada
Currently, kzalloc() returns zero-filled memory, while kmalloc() simply ignores the second argument and never fills the memory area with zeros. I want kmalloc(size, __GFP_ZERO) to behave as kzalloc() does, which will make it easier to add more memory allocator variants. With the introduction of __GFP_ZERO flag, going forward, kzmalloc() variants can fall back to kmalloc() enabling the __GFP_ZERO flag. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-07-22linux_compat: move vzalloc() to header file as an inline functionMasahiro Yamada
The vzalloc(size) is equivalent to kzalloc(size, 0). Move it to include/linux/compat.h as an inline function in order to avoid the function call overhead. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-22linux_compat: remove cpu_relax() defineMasahiro Yamada
The macro cpu_relax() is defined by several headers in different ways. arch/{arm,avr32,mips}/include/asm/processor.h defines it as follows: #define cpu_relax() barrier() On the other hand, include/linux/compat.h defines it as follows: #define cpu_relax() do {} while (0) If both headers are included from the same source file, the warning warning: "cpu_relax" redefined [enabled by default] is displayed. It effectively makes it impossible to include <linux/compat.h> from some sources. Drop the latter. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-07-22include: usb: Map USB controller base addresses for LS2085ANikhil Badola
Map USB XHCI controller base addresses for LS2085A SOC Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com>
2015-07-22include: usb: Move USB controller base address mappingNikhil Badola
Move USB controller Base address mapping from ls102xa immap to fsl xhci header. This is required to remove any warnings when controller base addresses are mapped for multiple platforms in their respective files. Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com>
2015-07-22drivers: usb: fsl: Implement Erratum A-009116 for XHCI controllerNikhil Badola
This adjusts (micro)frame length to appropriate value thus avoiding USB devices to time out over a longer run Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com>
2015-07-22usb: fsl: Add XHCI driver supportRamneek Mehresh
Add xhci driver support for all FSL socs Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2015-07-22usb: dwc3: Add DWC3 controller driver supportRamneek Mehresh
Add support for DWC3 XHCI controller driver Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2015-07-10mtd: fix false positive "Offset exceeds device limit" errorMasahiro Yamada
Since commit 09c3280754f8 (mtd, nand: Move common functions from cmd_nand.c to common place), NAND commands would not work at all on large devices. => nand read 80000000 10000 10000 NAND read: Offset exceeds device limit => nand erase 100000 100000 NAND erase: Offset exceeds device limit The type of the "size" of "struct mtd_info" is uint64_t, while mtd_arg_off_size() and mtd_arg_off() treat chipsize as int type. The chipsize is wrapped around if the argument is given with 2GB or larger. Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-30mtd, nand: Move common functions from cmd_nand.c to common placeHeiko Schocher
Move common functions from cmd_nand.c (for calculating offset and size from cmdline paramter) to common place, so they could used from other commands which use mtd partitions. For onenand the arg_off_size() is left in common/cmd_onenand.c. It should use now the common arg_off() function, but as I could not test onenand I let it there ... Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2015-05-28include: introduce include/linux/io.h as a wrapper of asm/io.hMasahiro Yamada
In the latest Linux coding style, <linux/io.h> should be included rather than <asm/io.h>. To follow this standard also in U-Boot, add include/linux/io.h. Currently, it just includes <asm/io.h>. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-13tegra124: video: Add full link training for eDPSimon Glass
Add full link training as a fallback in case the fast link training fails. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13video: Add drm_dp_helper.hSimon Glass
This file (from Linux 3.17) provides defines for display port. Use it so that our naming is consistent with Linux. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-04-21QE/DeepSleep: add QE deepsleep support for mpc85xxZhao Qiang
Muram will power off during deepsleep, and the microcode of qe in muram will be lost, it should be reload when resume. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-18dm: usb: Add a generic descriptor structSimon Glass
This is useful for creating lists of descriptors, and is better than using void * for this purpose. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Move struct usb_string to a common placeSimon Glass
This is needed for sandbox USB device emulation, so move it to a place where it can be found by things other than gadgets. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-14usb: modify usb_gadget_handle_interrupts to take controller indexKishon Vijay Abraham I
Since we support multiple dwc3 controllers to be existent at the same time, in order to handle the interrupts of a particular dwc3 controller usb_gadget_handle_interrutps should take controller index as an argument. Hence the API of usb_gadget_handle_interrupts is modified to take controller index as an argument and made the corresponding changes to all the usb_gadget_handle_interrupts calls. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14usb: dwc3: dwc3-omap: make dwc3-omap build in ubootKishon Vijay Abraham I
*) Changed the included header files to that used in u-boot. *) Removed extcon_* APIs *) Removed regulator_* APIs *) Fixed other misc warnings *) Added dwc3-omap.h to include the definitions of UTMI modes. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14include: usb: composite: add USB_GADGET_DELAYED_STATUS to avoid compilation ↵Kishon Vijay Abraham I
error Added USB_GADGET_DELAYED_STATUS to avoid the following compilation error. error: ‘USB_GADGET_DELAYED_STATUS’ undeclared (first use in this function) while compiling dwc3/ep0.c While this is been added only to avoid compilation error, the complete fix should be something like the one added in linux kernel. The complete fix will be ported once we have the composite driver in u-boot look similar to the one in linux kernel. commit 1b9ba000177ee47bcc5b44c7c34e48e735f5f9b1 Author: Roger Quadros <roger.quadros@nokia.com> Date: Mon May 9 13:08:06 2011 +0300 usb: gadget: composite: Allow function drivers to pause control transfers Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14usb: dwc3: gadget: make dwc3 gadget build in ubootKishon Vijay Abraham I
Did a bunch of things to get dwc3/gadget.c compile in u-boot without build errors and warnings *) Changed the included header files to that used in u-boot. *) Used dma_alloc_coherent and dma_free_coherent APIs of u-boot *) removed sg support *) remove jiffies and used a simple while loop *) removed irq support and added a function to call these interrupt handler. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14usb: dwc3: fix dwc3 header filesKishon Vijay Abraham I
Changed the header files included in core.h and io.h to the u-boot header files so that these files can be included in other dwc3 source files and be compiled in uboot. Also added otg.h which has the defines for dr_mode. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14include: usb: modify gadget.h to include udc supportKishon Vijay Abraham I
Made changes in gadget.h that is required after adding udc-core.c except changes that might break other platforms. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-03-30nand: Remove CONFIG_MTD_NAND_VERIFY_WRITEPeter Tyser
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some time and a more generic method of NAND verification now exists in U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-03-05use ASM_NL instead of '; ' for assembler new line character in the macroChen Gang
For some assemblers, they use another character as newline in a macro (e.g. arc uses '`'), so for generic assembly code, need use ASM_NL (a macro) instead of ';' for it. Basically this is the same patch as applied to Linux kernel - http://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/include/linux/linkage.h?id=9df62f054406992ce41ec4558fca6a0fa56fffeb but modified a bit to fit in U-Boot. Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com>
2015-02-11Add linux/compiler-gcc5.h to fix builds with gcc5Hans de Goede
Add linux/compiler-gcc5/h from the kernel sources at: commit 5631b8fba640a4ab2f8a954f63a603fa34eda96b Author: Steven Noonan <steven@uplinklabs.net> Date: Sat Oct 25 15:09:42 2014 -0700 compiler/gcc4+: Remove inaccurate comment about 'asm goto' miscompiles Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-28ubifs: Import atomic_long operations from LinuxAnton Habegger
This commit is a preperation for a subsequent UBIFS commit which needs atomic_long operations. Therefor "include/asm-generic/atomic-long.h" is imported from 1860e37 Linux 3.15 Signed-off-by: Anton Habegger <anton.habegger@gmail.com>
2015-01-13mtd: OMAP: Enable GPMC prefetch modeDaniel Mack
Enable GPMC's prefetch feature for NAND access. This speeds up NAND read access a lot by pre-fetching contents in the background and reading them through the FIFO address. The current implementation has two limitations: a) it only works in 8-bit mode b) it only supports read access Both is easily fixable by someone who has hardware to implement it. Note that U-Boot code uses non word-aligned buffers to read data into, and request read lengths that are not multiples of 4, so both partial buffers (head and tail) have to be addressed. Tested on AM335x hardware. Tested-by: Guido Martínez <guido@vanguardiasur.com.ar> Reviewed-by: Guido Martínez <guido@vanguardiasur.com.ar> Signed-off-by: Daniel Mack <zonque@gmail.com> [trini: Make apply again, use 'cs' fix pointed out by Guido] Signed-off-by: Tom Rini <trini@ti.com>
2014-12-15x86: move arch-specific asmlinkage to <asm/linkage.h>Masahiro Yamada
Commit 65dd74a674d6 (x86: ivybridge: Implement SDRAM init) introduced x86-specific asmlinkage into arch/x86/include/asm/config.h. Commit ed0a2fbf14f7 (x86: Add a definition of asmlinkage) added the same macro define again, this time, into include/common.h. (Please do not add arch-specific stuff to include/common.h any more; it is already too cluttered.) The generic asmlinkage is defined in <linux/linkage.h>. If you want to override it with an arch-specific one, the best way is to add it to <asm/linkage.h> like Linux Kernel. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-12-11lib: string: move strlcpy() to a common placeMasahiro Yamada
Move strlcpy() definition from drivers/usb/gadget/ether.c to lib/string.c because it is a very useful function. Let's add the prototype to include/linux/string.h too. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-08Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-12-08linux/compat.h: remove redundant macro definesMasahiro Yamada
__user and __iomem are defined in include/linux/compiler.h. MAX_ERRNO is defined in include/linux/err.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-04arm: omap: add support for am57xx devicesFelipe Balbi
just add a few ifdefs around because this device is very similar to dra7xxx. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-25Fix SIZE_MAX compiler warning when using stdint.hSimon Glass
This new symbol may be defined by the compiler. If it is, avoid a compiler warning when USE_STDINT is defined. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-20linux/kernel.h: add typechecking to roundup macroMasahiro Yamada
This commit replaces roundup macro with the one from Linux Kernel. DEFINE_ALIGN_BUFFER must be fixed because typechecking can not be used in this context. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-20linux/kernel.h: import more macrosMasahiro Yamada
These macros seem to be useful for U-Boot too (or at least harmless). Imported from Linux 3.18-rc2. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-20include: move various macros to include/linux/kernel.hMasahiro Yamada
U-Boot has imported various utility macros from Linux scattering them to various places without consistency. In include/common.h are min, max, min3, max3, ARRAY_SIZE, ALIGN, container_of, DIV_ROUND_UP, etc. In include/linux/compat.h are min_t, max_t, round_up, round_down, etc. We also have duplicated defines of min_t in some *.c files. Moreover, we are suffering from too cluttered include/common.h. This commit moves various macros that originate in include/linux/kernel.h of Linux to their original position. Note: This commit simply moves the macros; the macros roundup, min, max, min2, max3, ARRAY_SIZE are different from those of Linux at this point. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-10-27Provide option to avoid defining a custom version of uintptr_t.Gabe Black
There's a definition in stdint.h (provided by gcc) which will be more correct if available. Define CONFIG_USE_STDINT to use this feature, or USE_STDINT=1 on the 'make' commmand. This adjusts the settings for x86 and sandbox, with both have 64-bit options. Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-by: Gabe Black <gabeblack@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org> Reviewed-by: Bill Richardson <wfrichar@google.com> Rewritten to be an option, since stdint.h is often available only in glibc. Changed to preserve a clear boundary between stdint and non-stdint Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-27Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-10-26arm: debug: replace license blocks with SPDXMasahiro Yamada
2014-10-26arm: debug: import debug files from Linux 3.16Masahiro Yamada
U-Boot does not have arch/arm/kernel, include/uapi directories, This commit copies files as follows: Location in Linux -> Location in U-Boot arch/arm/kernel/debug.S -> arch/arm/lib/debug.S arch/arm/include/debug/8250.S -> arch/arm/include/debug/8250.S include/uapi/linux/serial_reg.h -> include/linux/serial_reg.h Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-26Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
