Add a prototype for board_video_skip() in order to fix the following sparse
warning:
wandboard.c:227:5: warning: symbol 'board_video_skip' was not declared. Should it be static?
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be
added to include/configs/exynos5-dt.h now.
include/configs/exynos5250-dt.h
Signed-off-by: David Feng <fenghua@phytium.com.cn>
Add an implementation of the CRC8 algorithm. This is required by the TPM
emulation, but is probably useful to U-Boot in general.
nand_ecclayout is present in mtd.h at Linux.
Move this structure to mtd.h to comply with Linux.
Also, increase the ecc placement locations to 640 to suport device having
writesize/oobsize of 8KB/640B. This means that the maximum oobsize has gone
up to 640 bytes and consequently the maximum ecc placement locations have
also gone up to 640.
Changes from Prabhabkar's version (squashed into one patch to preserve
bisectability):
- Added _LARGE to MTD_MAX_*_ENTRIES
This makes the names match current Linux source, and resolves
a conflict between
http://patchwork.ozlabs.org/patch/280488/
and
http://patchwork.ozlabs.org/patch/284513/
The former was posted first and is closer to matching Linux, but
unlike Linux it does not add _LARGE to the names. The second adds
_LARGE to one of the names, and depends on it in a subsequent patch
(http://patchwork.ozlabs.org/patch/284512/).
- Made max oobfree/eccpos configurable, and used this on tricorder,
alpr, ASH405, T4160QDS, and T4240QDS (these boards failed to build
for me without doing so, due to a size increase).
On tricorder SPL, this saves 2576 bytes (and makes the SPL build
again) versus the new default of 640 eccpos and 32 oobfree, and
saves 336 bytes versus the old default of 128 eccpos and 8 oobfree.
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
CC: Vipin Kumar <vipin.kumar@st.com>
[scottwood@freescale.com: changes as described above]
Cc: Thomas Weber <weber@corscience.de>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Stefan Roese <sr@denx.de>
Cc: York Sun <yorksun@freescale.com>
Cc: Tom Rini <trini@ti.com>
Linux Kernel abolished include/linux/config.h long time ago.
(around version v2.6.18..v2.6.19)
We don't need to provide Linux copatibility any more.
This commit deletes include/linux/config.h
and fixes source files not to include this.
Add the support for the am437x xhci usb host.
The xHCI host on AM437 is connected to a usb2 phy so need to
add support to enable those clocks.
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Add the support for the dra7xx xhci usb host.
dra7xx does not contain an EHCI controller so the headers
can be removed from the board file.
The xHCI host on dra7xx is connected to a usb2 phy so need to
Moving the usb/phy code from xhci-omap to the usb/phy directory
and moving the associated phy code over to the new file.
Newer TI processors adding xHCI support will have different PHY configurations
so therefore abstracting this code away will prevent messing around with the
xhci-omap file itself.
Moving the xhci-omap header to a more global location so that
other code can reference this code.
This adds driver layer for xHCI controller in Samsung's
exynos5 soc. This interacts with xHCI host controller stack.
Signed-off-by: Vikas C Sajjan <vikas.sajjan@samsung.com>
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
Cc: Julius Werner <jwerner@chromium.org>
Cc: Dan Murphy <dmurphy@ti.com>
Linux modified the MTD driver interface in commit edbc4540 (with the
same name as this commit). The effect is that calls to mtd_read will
not return -EUCLEAN if the number of ECC-corrected bit errors is below
a certain threshold, which defaults to the strength of the ECC. This
allows -EUCLEAN to stop indicating "some bits were corrected" and begin
indicating "a large number of bits were corrected, the data held in
this region of flash may be lost soon". UBI makes use of this and when
-EUCLEAN is returned from mtd_read it will move data to another block
of flash. Without adopting this interface change UBI on U-boot attempts
to move data between blocks every time a single bit is corrected using
the ECC, which is a very common occurance on some devices.
For some devices where bit errors are common enough, UBI can get stuck
constantly moving data around because each block it attempts to use has
a single bit error. This condition is hit when wear_leveling_worker
attempts to move data from one PEB to another in response to an
-EUCLEAN/UBI_IO_BITFLIPS error. When this happens ubi_eba_copy_leb is
called to perform the data copy, and after the data is written it is
read back to check its validity. If that read returns UBI_IO_BITFLIPS
(in response to an MTD -EUCLEAN) then ubi_eba_copy_leb returns 1 to
wear_leveling worker, which then proceeds to schedule the destination
PEB for erasure. This leads to erase_worker running on the PEB, and
following a successful erase wear_leveling_worker is called which
begins this whole cycle all over again. The end result is that (without
UBI debug output enabled) the boot appears to simply hang whilst in
reality U-boot busily works away at destroying a block of the NAND
flash. Debug output from this situation:
UBI DBG: ensure_wear_leveling: schedule scrubbing
UBI DBG: wear_leveling_worker: scrub PEB 1027 to PEB 4083
UBI DBG: ubi_io_read_vid_hdr: read VID header from PEB 1027
UBI DBG: ubi_io_read: read 4096 bytes from PEB 1027:4096
UBI DBG: ubi_eba_copy_leb: copy LEB 0:0, PEB 1027 to PEB 4083
UBI DBG: ubi_eba_copy_leb: read 1040384 bytes of data
UBI DBG: ubi_io_read: read 1040384 bytes from PEB 1027:8192
UBI: fixable bit-flip detected at PEB 1027
UBI DBG: ubi_io_write_vid_hdr: write VID header to PEB 4083
UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:4096
UBI DBG: ubi_io_read_vid_hdr: read VID header from PEB 4083
UBI DBG: ubi_io_read: read 4096 bytes from PEB 4083:4096
UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:8192
UBI DBG: ubi_io_read: read 4096 bytes from PEB 4083:8192
UBI: fixable bit-flip detected at PEB 4083
UBI DBG: schedule_erase: schedule erasure of PEB 4083, EC 55, torture 0
UBI DBG: erase_worker: erase PEB 4083 EC 55
UBI DBG: sync_erase: erase PEB 4083, old EC 55
UBI DBG: do_sync_erase: erase PEB 4083
UBI DBG: sync_erase: erased PEB 4083, new EC 56
UBI DBG: ubi_io_write_ec_hdr: write EC header to PEB 4083
UBI DBG: ubi_io_write: write 4096 bytes to PEB 4083:0
This patch adopts the interface change as in Linux commit edbc4540 in
order to avoid such situations. Given that none of the drivers under
drivers/mtd return -EUCLEAN, this should only affect those using
software ECC. I have tested that it works on a board which is
currently out of tree, but which I hope to be able to begin
upstreaming soon.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
The modelist data uses the list definition but the 'list.h' header
were not being included. The build failure is bellow:
| In file included from yyyy.c:16:0:
| .../u-boot/include/linux/fb.h:503:19: error: field 'modelist' has incomplete type
| struct list_head modelist; /* mode list */
| make[1]: *** [yyyy.o] Error 1
| make[1]: Leaving directory `.../u-boot/board/xxx/yyyy'
| make: *** [board/xxx/yyyy/libyyyy.o] Error 2
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Only the <linux/usb/gadget.h> requires error.h include. Hence, several
includes of error.h at USB gadget functions are not needed.
Moreover unnecessary malloc.h includes were also removed.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Add atmel usba udc driver support, porting from Linux kernel
The original code in Linux Kernel information is as following
commit e01ee9f509a927158f670408b41127d4166db1c7
Author: Jingoo Han <jg1.han@samsung.com>
Date: Tue Jul 30 17:00:51 2013 +0900
usb: gadget: use dev_get_platdata()
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
gcc allows extensions to be non compiler specific by defining
__* macros for the attributes supported by gcc. Having a
different definition causes many warnings during the build
(cdefs.h on FreeBSD uses __attribute((__pure__)) where u-boot
uses __attribute__((pure)) for example). Do not redefine
these macros to suppress these warnings.
This patch ignores the checkpatch warning:
WARNING: __packed is preferred over __attribute__((packed))
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Since kernel code current use many dev_xxx() instead of using printk. To
compatible, move those dev_xxx from usb driver to linux/compat.h. Then all
driver code can use dev_err, dev_info and dev_vdbg.
This patch also removed duplicated macro definitions in usb driver.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Acked-by: Scott Wood <scottwood@freescale.com>
[trini: Fixup common/cmd_io.c]
while playing with dfu, I tapped in an unaligned access
when doing on the host side a "lsusb -d [vendornr]: -v"
I get on the board:
GADGET DRIVER: usb_dnl_dfu
data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<8ff71db8>] lr : [<8ff75aec>]
sp : 8ef40d18 ip : 00000005 fp : 00000000
r10: 00000000 r9 : 47401410 r8 : 8ef40f38
r7 : 8ef4aae8 r6 : 0000000a r5 : 8ef4ab28 r4 : 8ef4ab80
r3 : 0000000a r2 : 00000006 r1 : 00000006 r0 : 8ef4aae8
Flags: Nzcv IRQs off FIQs on Mode SVC_32
Resetting CPU ...
reason is that in the "struct usb_composite_dev" the
"struct usb_device_descriptor desc;" is on an odd address,
and this struct gets accessed in
drivers/usb/gadget/composite.c device_qual()
Fix it, by align this var "struct desc" fix to an aligned
address.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Samuel Egli <samuel.egli@siemens.com>
commit 39695029bc15041c809df3db4ba19bd729c447fa
Author: Charles Coldwell <coldwell@ll.mit.edu>
Date: Tue Feb 19 08:27:33 2013 -0500
Changes to support the Xilinx 1000BASE-X phy (GTX/MGT)
Signed-off-by: Charles Coldwell <coldwell@ll.mit.edu>
Use unaligned access to fetch wMaxPacketSize in usb_endpoint_maxp()
api.
In its absence we see following data abort message:
data abort
pc : [<bf794e24>] lr : [<bf794e1c>]
sp : bf37c7b0 ip : 0000002f fp : 00000000
r10: 00000000 r9 : 00000002 r8 : bf37fecc
r7 : 00000001 r6 : bf7d8931 r5 : bf7d891c r4 : bf7d8800
r3 : bf7d65b0 r2 : 00000002 r1 : bf7d65b4 r0 : 00000027
Flags: nZCv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
resetting ...
Cc: Ilya Yanok <ilya.yanok@cogentembedded.com>
This patch is essentially an update of u-boot MTD subsystem to
the state of Linux-3.7.1 with exclusion of some bits:
- the update is concentrated on NAND, no onenand or CFI/NOR/SPI
flashes interfaces are updated EXCEPT for API changes.
- new large NAND chips support is there, though some updates
have got in Linux-3.8.-rc1, (which will follow on top of this patch).
To produce this update I used tag v3.7.1 of linux-stable repository.
The update was made using application of relevant patches,
with changes relevant to U-Boot-only stuff sticked together
to keep bisectability. Then all changes were grouped together
to this patch.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
[scottwood@freescale.com: some eccstrength and build fixes]
This patch adds a driver for the diskonchip G4 nand flash device. It is based
on the driver from the linux kernel.
This also includes a separate SPL driver. A separate SPL driver is used because
the device operates in a different mode (reliable mode) when loading a boot
image, and also because the storage format of the boot image is different from
normal data (pages are stored redundantly). The SPL driver basically mimics how
a typical IPL reads data from the device. The special operating mode and
storage format are used to compensate for the fact that the IPL does not contain
the BCH ecc decoding algorithm (due to size constraints). Although the u-boot
SPL *could* use ecc, it operates like an IPL for the sake of simplicity and
uniformity, since the IPL and SPL share the task of loading the u-boot image.
As a side benefit, the SPL driver is very small.
[port from linux kernel 3.4 commit 570469f3bde7f71cc1ece07a18d54a05b6a8775d]
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
This patch adds the bitrev library from the linux kernel. This is a simple
algorithm that uses an 8 bit look-up table to reverse the bits in data types of
8, 16, or 32 bit widths. The docg4 nand flash driver uses it.
[port from linux kernel v3.9 commit 7ee32a6d30d1c8a3b7a07a6269da8f0a08662927]
[originally added: v2.6.20 by commit a5cfc1ec58a07074dacb6aa8c79eff864c966d12]
'bool' is defined in random places. This patch consolidates them into a
single header file include/linux/types.h, using stdbool.h introduced in C99.
All other #define, typedef and enum are removed. They are all consistent with
true = 1, false = 0.
Replace FALSE, False with false. Replace TRUE, True with true.
Skip *.py, *.php, lib/* files.
Signed-off-by: York Sun <yorksun@freescale.com>
isspace() and strim() are not in the typical user-mode string.h, so
put them in a separate compilation unit so that they can be built into
tools that need them independent of the other common string functions.
This allows code shared by u-boot and the linux user-mode tools to link.
strncasecmp() is present as strnicmp() but disabled. Make it available
and define strcasecmp() also. There is a only a small performance penalty
to having strcasecmp() call strncasecmp(), so do this instead of a
standalone function, to save code space.
Update the prototype in arch-specific headers as needed to avoid warnings.
When __BYTEORDER_HAS_U64__ is not defined, we got warning following:
/tmp/include/linux/byteorder/little_endian.h: In function ‘__cpu_to_be64p’:
/tmp/include/linux/byteorder/little_endian.h:71:2: warning: implicit declaration of function ‘__swab64p’
[-Wimplicit-function-declaration]
Usually, __arch__swab64* required for __fswab64, __swab64p and __swab64s
is defined. Therefore, __BYTEORDER_HAS_U64__ is unnecessary.
This removes __BYTEORDER_HAS_U64__.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
CC: Kim Phillips <kim.phillips@freescale.com>
Reviewed-by: Kim Phillips <kim.phillips@freescale.com>
Use a flag instead of a hard-coded macro so that sub-page reads can be
enabled in other cases (such as on-die ecc).
This is the same as a5ff4f102937a3492bca4a9ff0c341d78813414c in Linux
Existing U-Boot musb driver has no support for the new gadget framework
and also seems to have other limitations. As gadget framework is ported
from Linux it seems pretty natural to port musb gadget driver as well.
This driver supports both host and peripheral modes.
This is not a replacement for current musb driver (at least now) as
there are still some consumers of the old UDC interface.
No DMA operation support included, CONFIG_MUSB_PIO_ONLY should be
defined.
Virtual root hub device is not implemented.
Known problems: with no devices connected usb_lowlevel_start() fails.
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
hack to avoid:
/opt/gcc-4.6.3-nolibc/powerpc-linux/bin/../lib/gcc/powerpc-linux/4.6.3/include/stddef.h:413:9: warning: preprocessor token offsetof redefined
u-boot/include/linux/stddef.h:20:9: this was the original definition
tried protecting with __KERNEL__, and #including compiler.h first.
Even tried include dir reordering to no avail:
+++ b/config.mk
@@ -194,7 +194,11 @@ OBJCFLAGS += --gap-fill=0xff
gccincdir := $(shell $(CC) -print-file-name=include)
CPPFLAGS := $(DBGFLAGS) $(OPTFLAGS) $(RELFLAGS) \
- -D__KERNEL__
+ -D__KERNEL__ \
+ -I $(gccincdir) \
+ -nostdinc
+# -isystem $(gccincdir) \
# Enable garbage collection of un-used sections for SPL
ifeq ($(CONFIG_SPL_BUILD),y)
@@ -227,8 +231,7 @@ CPPFLAGS += -I$(OBJTREE)/include2 -I$(OBJTREE)/include
endif
CPPFLAGS += -I$(TOPDIR)/include
-CPPFLAGS += -fno-builtin -ffreestanding -nostdinc \
- -isystem $(gccincdir) -pipe $(PLATFORM_CPPFLAGS)
+CPPFLAGS += -fno-builtin -ffreestanding -pipe $(PLATFORM_CPPFLAGS)
redefined
include/linux/unaligned/generic.h:5:9: warning: preprocessor token __force redefined
include/linux/compiler.h:10:10: this was the original definition
fixup __force definitions in compat.h code appears to be placed
there as a cover up from a code import from linux when u-boot didn't yet
have a compiler.h, introduced by commit
b1b4e89a0f3b75854c39a62cae41bad56d210adf "Add LZO decompressor support".
redefined
include/linux/compat.h:4:9: warning: preprocessor token __user redefined
include/linux/compiler.h:7:10: this was the original definition
include/linux/compat.h:5:9: warning: preprocessor token __iomem redefined
include/linux/compiler.h:12:10: this was the original definition
fixup __iomem, __user definitions in compat.h code appears to be placed
932394ac43e2e778e664eeb6e456fecd0fae6e59 "Rewrite of NAND code based on
what is in 2.6.12 Linux kernel".
u-boot's byteorder headers did not contain endianness attributions
for use with sparse, causing a lot of false positives. Import the
kernel's latest definitions, and enable them by including compiler.h
and types.h. They come with 'const' added for some swab functions, so
fix those up, too:
include/linux/byteorder/big_endian.h:46:2: warning: passing argument 1 of '__swab64p' discards 'const' qualifier from pointer target type [enabled by default]
Also, note: u-boot's historic __BYTE_ORDER definition has been
preserved (for the time being at least).
We also remove ad-hoc barrier() definitions, since we're including
compiler.h in files that hadn't in the past:
macb.c:54:0: warning: "barrier" redefined [enabled by default]
In addition, including compiler.h in byteorder changes the 'noinline'
definition to expand to __attribute__((noinline)). This fixes
arch/powerpc/lib/bootm.c:
bootm.c:329:16: error: attribute '__attribute__': unknown attribute
bootm.c:329:16: error: expected ')' before '__attribute__'
bootm.c:329:25: error: expected identifier or '(' before ')' token
powerpc sparse builds yield:
include/common.h:356:22: error: marked inline, but without a definition
the unknown-reason inlining without a definition is considered obsolete
given it was part of the 2002 initial commit, and no arm version was
'fixed.'
also fixed:
ydirectenv.h:60:0: warning: "inline" redefined [enabled by default]
and:
Configuring for devconcenter - Board: intip, Options: DEVCONCENTER
make[1]: *** [4xx_ibm_ddr2_autocalib.o] Error 1
make: *** [arch/powerpc/cpu/ppc4xx/libppc4xx.o] Error 2
powerpc-fsl-linux-size: './u-boot': No such file
4xx_ibm_ddr2_autocalib.c: In function 'DQS_autocalibration':
include/asm/ppc4xx-sdram.h:1407:13: sorry, unimplemented: inlining failed in call to 'ppc4xx_ibm_ddr2_register_dump': function body not available
4xx_ibm_ddr2_autocalib.c:1243:32: sorry, unimplemented: called from here
and:
In file included from crc32.c:50:0:
crc32table.h:4:1: warning: implicit declaration of function '___constant_swab32' [-Wimplicit-function-declaration]
crc32table.h:4:1: error: initializer element is not constant
crc32table.h:4:1: error: (near initialization for 'crc32table_le[0]')
[trini: Remove '#endif' in include/common.h around setenv portion]
Copied from Linux kernel:
commit 8f7c2c37319a81ef4c2bfdec67b1ccd5744d97e4
Date: Wed Apr 8 16:58:57 2009 +0800
Pull in the __stringify() macro from Linux kernel. This macro is usually used to
convert numbers to strings at preprocessor level, yet it is not limited only to
that. This is useful as it allows higher usage of puts() in favour of printf().
This is based on Linux kernel -next:
commit 14f44abf1dafc20ba42ce8616a8fc8fbd1b3712b
Author: Brian Norris <computersforpeace@gmail.com>
Date: Fri Jul 13 09:28:24 2012 -0700
mtd: nand: allow NAND_NO_SUBPAGE_WRITE to be set from driver
The NAND_CHIPOPTIONS_MSK has limited utility and is causing real bugs. It
silently masks off at least one flag that might be set by the driver
(NAND_NO_SUBPAGE_WRITE). This breaks the GPMI NAND driver and possibly
others.
Really, as long as driver writers exercise a small amount of care with
NAND_* options, this mask is not necessary at all; it was only here to
prevent certain options from accidentally being set by the driver. But the
original thought turns out to be a bad idea occasionally. Thus, kill it.
Note, this patch fixes some major gpmi-nand breakage.
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Scott Wood <scottwood@freescale.com>
NAND_CMD_ constants for lock/unlock should be in the header
The NAND layer needs to use cache-aligned buffers by default. Towards this
goal. align the default buffers and their members according to the minimum
DMA alignment defined for the architecture.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Signed-off-by: Amit Virdi <amit.virdi@st.com>
SMI is the serial memory interface controller provided by ST.
Earlier, a driver exists in the u-boot source code for the SMI IP. However, it
was specific to spear platforms. This commit converts the same driver to a more
generic driver. As a result, the driver files are renamed to st_smi.c and
st_smi.h and moved into drivers/mtd folder for reusability by other platforms
using smi controller peripheral.
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
Flexible static memory controller is a peripheral provided by ST,
which controls the access to NAND chips along with many other
memory device chips eg NOR, SRAM.
This patch adds the driver support for FSMC controller interfacing
with NAND memory.
* 'master' of git://git.denx.de/u-boot-usb:
USB: S5P: Add ehci support
usb:udc:samsung Add functions for storing private gadget data in UDC driver
usb:gadget:composite: Support for composite at gadget.h
usb:gadget:composite USB composite gadget support
usb:udc:samsung:cleanup Replace DEBUG_* macros with debug_cond() calls
usb:udc: Remove duplicated USB definitions from include/linux/usb/ch9.h file
USB: Document the QH and qTD antics in EHCI-HCD
USB: Drop cache flush bloat in EHCI-HCD
USB: Drop ehci_alloc/ehci_free in ehci-hcd
USB: Align buffers at cacheline
usb: use noinline define
Add device data pointer to the USB gadget's device struct.
Wrapper for extracting usb_gadget from Linux's usb device
USB Composite gadget implementation for u-boot. It builds on top
of USB UDC drivers.
This commit is based on following files from Linux Kernel v2.6.36:
./include/linux/usb/composite.h
./drivers/usb/gadget/composite.c
SHA1: d187abb9a83e6c6b6e9f2ca17962bdeafb4bc903
