path: root/include/linux
2010-05-06x86: Fix support for booting bzImageGraeme Russ
Add support for newer (up to 2.6.33) kernels Add zboot command which takes the address of a bzImage as its first argument and (optionally) the size of the bzImage as the second argument (the second argument is needed for older kernels which do not include the bzImage size in the header) Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-04-02nios2: add struct stat support in linux/stat.hThomas Chou
This is needed for jffs2 support. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-01-18move definition of macros likely and unlikely to compiler.hMatthias Kaehlcke
the macros likely and unlikely were defined in include/linux/mtd/compat.h, but used in code not related to MTD. moved the macro definitions to compiler.h Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
2009-12-05add lzop decompression supportPeter Korsgaard
Add lzop decompression support to the existing lzo bitstream handling (think gzip versus zlib), and support it for uImage decompression if CONFIG_LZO is enabled. Lzop doesn't compress as good as gzip (~10% worse), but decompression is very fast (~0.7s faster here on a slow ppc). The lzop decompression code is based on Albin Tonnerre's recent ARM Linux lzo support patch. Cc: albin.tonnerre@free-electrons.com Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
2009-11-18NAND:Extending the nand_ecclayout structureSandeep Paulraj
NANDs with page size of lesser than and equal to 2K are reaching EOL. They are bing replaced with NANDs of page size 4K and above. To support this we have to extend the eccpos field Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-11-15Merge branch 'master' into nextWolfgang Denk
2009-11-13Flex-OneNAND driver supportAmul Kumar Saha
This patch adds support for Flex-OneNAND devices. Signed-off-by: Rohit Hagargundgi <h.rohit@samsung.com> Signed-off-by: Amul Kumar Saha <amul.saha@samsung.com>
2009-11-13NAND: Update to support 64 bit device sizeSandeep Paulraj
This patch adds support for NANDs greater than 2 GB. Patch is based on the MTD NAND driver in the kernel. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-11-07ARM: Use Linux version for unaligned access codeRemy Bohmer
The asm-arm/unaligned.h includes linux/unaligned/access_ok.h This file is unsafe to be used on ARM, since it does an unaligned memory accesses which fails on ARM. Lookin at Linux the basic difference seems to be the header "include/asm-arm/unaligned.h". The Linux version of "unaligned.h" does *not* include "access_ok.h" at all. It includes "le_byteshift.h" and "be_byteshift.h" instead. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Stefan Roese <sr@denx.de> -- include/asm-arm/unaligned.h | 3 - include/linux/unaligned/be_byteshift.h | 70 +++++++++++++++++++++++++++++++++ include/linux/unaligned/le_byteshift.h | 70 +++++++++++++++++++++++++++++++++ 3 files changed, 142 insertions(+), 1 deletion(-) create mode 100644 include/linux/unaligned/be_byteshift.h create mode 100644 include/linux/unaligned/le_byteshift.h
2009-10-24s5pc1xx: SMDKC100: fix compile warningsMinkyu Kang
fix the following compile warnings warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-10-13s5pc1xx: support onenand driverMinkyu Kang
This patch includes the onenand driver for s5pc100 Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-09-17Correct ffs/fls regression for PowerPC etcSimon Kagstrom
Commits 02f99901ed1c9d828e3ea117f94ce2264bf8389e 52d61227b66d4099b39c8309ab37cb67ee09a405 introduced a regression where platform-specific ffs/fls implementations were defined away. This patch corrects that by using PLATFORM_xxx instead of the name itself. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de>
2009-09-15Define ffs/fls for all architecturesSimon Kagstrom
UBIFS requires fls(), which is not defined for arm (and some other architectures) and this patch adds it. The implementation is taken from Linux and is generic. ffs() is also defined for those that miss it. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2009-09-15Move __set/clear_bit from ubifs.h to bitops.hSimon Kagstrom
__set_bit and __clear_bit are defined in ubifs.h as well as in asm/include/bitops.h for some architectures. This patch moves the generic implementation to include/linux/bitops.h and uses that unless it's defined by the architecture. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2009-08-26MTD:NAND: ADD new ECC mode NAND_ECC_HW_OOB_FIRSTSandeep Paulraj
This patch adds the new mode NAND_ECC_HW_OOB_FIRST in the nand code to support 4-bit ECC on TI DaVinci devices with large page (up to 2K) NAND chips. This ECC mode is similar to NAND_ECC_HW, with the exception of read_page API that first reads the OOB area, reads the data in chunks, feeds the ECC from OOB area to the ECC hw engine and perform any correction on the data as per the ECC status reported by the engine. This patch has been accepted by Andrew Morton and can be found at http://userweb.kernel.org/~akpm/mmotm/broken-out/mtd-nand-add-new-ecc-mode-ecc_hw_oob_first.patch Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sneha Narnakaje <nsnehaprabha@ti.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-08-26NAND: ADD page Parameter to all read_page/read_page_raw API'sSandeep Paulraj
This patch adds a new "page" parameter to all NAND read_page/read_page_raw APIs. The read_page API for the new mode ECC_HW_OOB_FIRST requires the page information to send the READOOB command and read the OOB area before the data area. This patch has been accepted by Andrew Morton and can be found at http://userweb.kernel.org/~akpm/mmotm/broken-out/mtd-nand-add-page-parameter-to-all-read_page-read_page_raw-apis.patch WE would like this to become part of the u-boot GIT as well Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sneha Narnakaje <nsnehaprabha@ti.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-08-26OneNAND: Remove unused read_spareramKyungmin Park
Remove unused read_spareram and add unlock_all as kernel does Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-08-25Replace BCD2BIN and BIN2BCD macros with inline functionsAlbin Tonnerre
In the process, also remove backward-compatiblity macros BIN_TO_BCD and BCD_TO_BIN and update the sole board using them to use the new bin2bcd and bcd2bin instead Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2009-07-16Remove legacy NAND and disk on chip code.Scott Wood
Legacy NAND had been scheduled for removal. Any boards that use this were already not building in the previous release due to an #error. The disk on chip code in common/cmd_doc.c relies on legacy NAND, and it has also been removed. There is newer disk on chip code in drivers/mtd/nand; someone with access to hardware and sufficient time and motivation can try to get that working, but for now disk on chip is not supported. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-16nand: Change NAND_MAX_OOBSIZE to 218 as needed for some 4k page devicesStefan Roese
This is needed for the MPC512x NAND driver (fsl_nfc_nand.c) which already defines such a 4k plus 218 bytes ECC layout. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-07Coding style cleanup; update CHANGELOGWolfgang Denk
2009-06-12mtd: Update MTD infrastructure to support 64bit device sizeStefan Roese
This patch brings the U-Boot MTD infrastructure in sync with the current Linux MTD version (2.6.30-rc3). Biggest change is the 64bit device size support and a resync of the mtdpart.c file which has seen multiple fixes meanwhile. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Kyungmin Park <kmpark@infradead.org>
2009-06-12mtd: Add MTD concat support to concatenate multiple MTD NOR devicesStefan Roese
This patch adds concatenation support to the U-Boot MTD infrastructure. By enabling CONFIG_MTD_CONCAT this MTD CFI wrapper will concatenate all found NOR devices into one single MTD device. This can be used by e.g by UBI to access a partition that spans over multiple NOR chips. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-23Add wait flags to support board/chip specific delaysWolfgang Grandegger
The NAND flash on the TQM8548_BE modules requires a short delay after running the UPM pattern like the MPC8360ERDK board does. The TQM8548_BE requires a further short delay after writing out a buffer. Normally the R/B pin should be checked, but it's not connected on the TQM8548_BE. The corresponding Linux FSL UPM driver uses similar delay points at the same locations. To manage these extra delays in a more general way, I introduced the "wait_flags" field allowing the board-specific driver to specify various types of extra delay. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-23Add support for TQM-specific chip select logic to FSL-UPMWolfgang Grandegger
For the NAND chips on the TQM8548 modules, a special chip-select logic is used. It uses dedicated address lines to be set via UPM machine address register (mar). This patch adds such support to the FSL-UPM driver. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-23Add multi chip support to the FSL-UPM driverWolfgang Grandegger
This patch adds support for multi-chip NAND devices to the FSL-UPM driver. The "dev_ready" callback of the "struct fsl_upm_nand" is now called with the argument "chip_nr" to allow testing the proper chip select line. The NAND support of the MPC8360ERDK is updated as well. No other boards are currently using the FSL UPM driver. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-20UBIFS: Implement read-only UBIFS support in U-BootStefan Roese
The U-Boot UBIFS implementation is largely a direct copy from the current Linux version (2.6.29-rc6). As already done in the UBI version we have an "abstraction layer" to redefine or remove some OS calls (e.g. mutex_lock() ...). This makes it possible to use the original Linux code with very little changes. And by this we can better update to later Linux versions. I removed some of the Linux features that are not used in the U-Boot version (e.g. garbage-collection, write support). Signed-off-by: Stefan Roese <sr@denx.de> CC: Artem Bityutskiy <dedekind@infradead.org> CC: Adrian Hunter <ext-Adrian.Hunter@nokia.com>
2009-03-20Add LZO decompressor supportStefan Roese
This patch adds LZO decompression support to U-Boot. It is needed for the upcoming UBIFS support, since UBIFS uses LZO as default compressor/ decompressor. Since we only support read-only in UBIFS, only the decompressor is needed. All this is copied with minor changes from the current Linux kernel version (2.6.28-rc8). This patch only implements this LZO decompressor support for PPC. Other platforms using UBIFS will have to add the required "include/asm/unaligned.h" as well. It should be fairly easy to copy this from the Linux source tree as I have done it for PPC in this patch. Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-01-23OneNAND: Additional sync with 2.6.27Stefan Roese
- Add subpage write support - Add onenand_oob_64/32 ecclayout This has been missing and without it UBI has some incompatibilies issues with the current (>= 2.6.27) Linux kernel version. vid_hdr_offset is placed differently (2048 instead of 512) without this fix. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-01-23Sync with 2.6.27Kyungmin Park
Sync with OneNAND kernel codes Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-12-16Coding style cleanup, update CHANGELOG.Wolfgang Denk
2008-11-19UBI: Add basic UBI support to U-Boot (Part 8/8)Kyungmin Park
This patch adds basic UBI (Unsorted Block Image) support to U-Boot. It's based on the Linux UBI version and basically has a "OS" translation wrapper that defines most Linux specific calls (spin_lock() etc.) into no-ops. Some source code parts have been uncommented by "#ifdef UBI_LINUX". This makes it easier to compare this version with the Linux version and simplifies future UBI ports/bug-fixes from the Linux version. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-19UBI: Add basic UBI support to U-Boot (Part 7/8)Kyungmin Park
2008-11-19UBI: Add basic UBI support to U-Boot (Part 6/8)Kyungmin Park
2008-10-31NAND: Allow NAND and OneNAND to coexistAlessandro Rubini
This removes in nand.h code that is verbatim duplicated from bbm.h, including directly bbm.h in nand.h. The previous state of affairs prevented compiling code for a board hosting both NAND and OneNAND chips. Reported-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Alessandro Rubini <rubini@unipv.it> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-10-29NAND: sync with 2.6.27Scott Wood
This brings the core NAND code up to date with the Linux kernel. Since there were several drivers in Linux as of the last update that are not in u-boot, I'm not bringing over new drivers that have been added since in the absence of an interested party. I did not update OneNAND since it was recently synced by Kyungmin Park, and I'm not sure exactly what the common ancestor is. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-10-18Add Red Black Tree supportKyungmin Park
Now it's used at UBI module. Of course other modules can use it. If you want to use it, please define CONFIG_RBTREE Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-09-13Coding style cleanup, update CHANGELOGWolfgang Denk
2008-08-31update linux/listJean-Christophe PLAGNIOL-VILLARD
2008-08-21Fix OneNAND read_oob/write_oob functions compatabilityKyungmin Park
Also sync with kernel OneNAND codes Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-14Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-08-14Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2008-08-13Fix OneNAND build breakKyungmin Park
Since page size field is changed from oobblock to writesize. But OneNAND is not updated. - fix bufferram management at erase operation This patch includes the NAND/OneNAND state filed too. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-12NAND: Scan bad blocks lazily.Ilya Yanok
Rather than scanning on boot, scan upon the first attempt to check the badness of a block. This speeds up boot when not using NAND, and reduces the likelihood of needing to reflash via JTAG if NAND becomes nonfunctional. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12nand: fsl_upm: convert to updated MTD NAND infrastructureAnton Vorontsov
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Remove white space at end.William Juul
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
