path: root/include/linux
2011-04-20Create PHY Lib for U-BootAndy Fleming
Extends the mii_dev structure to participate in a full-blown MDIO and PHY driver scheme. The mii_dev structure and miiphy calls are modified in such a way to allow the original mii command and miiphy infrastructure to work as before, but also to support a new set of APIs which allow (among other things) sharing of PHY driver code and 10G support The mii command will continue to support normal PHY management functions (Clause 22 of 802.3), but will not be changed to support 10G (Clause 45). The basic design is similar to PHY Lib from Linux, but simplified for U-Boot's network and driver infrastructure. We now have MDIO drivers and PHY drivers An MDIO driver provides: read write reset A PHY driver provides: (optionally): probe config - initial setup, starting of auto-negotiation startup - waiting for AN, and reading link state shutdown - any cleanup needed The ethernet drivers interact with the PHY Lib using these functions: phy_connect() phy_config() phy_startup() phy_shutdown() Each PHY driver can be configured separately, or all at once using config_phylib_all_drivers.h (added in the patch which adds the drivers) We also provide generic drivers for Clause 22 (10/100/1000), and Clause 45 (10G) PHYs. We also implement phy_reset(), and call it in phy_connect(). Because phy_reset() is essentially the same as miiphy_reset, but: a) must support 10G PHYs, and b) should use the phylib primitives, we implement miiphy_reset, using phy_reset(), but only when CONFIG_PHYLIB is set. Otherwise, we just use the old version. In this way, we save on compile size, even if we don't manage to save code size. Pulled ethtool.h and mdio.h from: git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6 782d640afd15af7a1faf01cfe566ca4ac511319d With many, many deletions so as to enable compilation under u-boot Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-01NAND: add support for reading ONFI page tableFlorian Fainelli
This patch adds support for reading an ONFI page parameter from a NAND device supporting it. If this is the case, struct nand_chip onfi_version member contains the supported ONFI version, 0 otherwise. This allows NAND drivers past nand_scan_ident to set the best timings for the NAND chip. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-02-19USB: Add USB RNDIS gadget protocolVitaly Kuzmichev
Port USB gadget RNDIS protocol support from linux-2.6.26 (.27 gadget stack actually has composite drivers). Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2011-02-19USB-CDC: Port struct net_device_statsVitaly Kuzmichev
Port struct net_device_stats and statistics collecting needed for RNDIS protocol. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2011-01-18lib: add crc7 from LinuxThomas Chou
Crc7 is used to compute mmc spi command packet checksum. Copy from linux-2.6 lib/crc7.c include/linux/crc7.h commit ad241528c4919505afccb022acbab3eeb0db4d80 Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2011-01-12mtd: nand: Allow caller to pass alternative ID table to nand_scan_ident()Lei Wen
This patch sync with David's patch on Linux for handling nand_scan_ident. commit 5e81e88a4c140586d9212999cea683bcd66a15c6 Author: David Woodhouse <David.Woodhouse@intel.com> Date: Fri Feb 26 18:32:56 2010 +0000 mtd: nand: Allow caller to pass alternative ID table to nand_scan_ident() Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Lei Wen <leiwen@marvell.com>
2010-12-22Merge branch 'next' of ../nextWolfgang Denk
2010-12-17NAND: add NAND_CMD_PARAM (0xec) definitionFlorian Fainelli
This command is used to read the device ONFI parameters page. Signed-off-by: Florian Fainelli <florian@openwrt.org>
2010-12-17nand: constify id/manu tablesMike Frysinger
These id tables need not be writable. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-12-17Coding style (white space) cleanup.Wolfgang Denk
2010-12-16Merge branch 'master' of ../master into nextWolfgang Denk
2010-12-09include/linux/mii.h: update for supporting GEMacpaul Lin
This file has been synced (copy) from Linux source code. This commit was based on kernel 2.6.32. It updates gigabit related phy registers and basic definitions. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2010-11-28ctype: constify lookup tableMike Frysinger
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-26include/asm-offsets.h: automatically generate assembler constantsWolfgang Denk
A recurrent issue is that certain C level constructs like sizeof() or offsetof() cannot be used in assembler files, which is inconvenient when such constructs are used in the definition of macro names etc. To avoid duplication of such definitions (and thus another cause of problems), we adapt the Linux way to automatically generate the respective definitions from the respective C header files. In Linux, this is implemented in include/linux/kbuild.h, Kbuild, and arch/*/kernel/asm-offsets.c; we adapt the code from the Linux v2.6.36 kernel tree. We also copy the concept of the include/generated/ directory which can be used to hold other automatically generated files as well. We start with an architecture-independent lib/asm-offsets.c which generates include/generated/generic-asm-offsets.h (included by include/asm-offsets.h, which is what will be referred to in the actual source code). Later this may be extended by architecture-specific arch/*/lib/asm-offsets.c files that will generate a include/generated/asm-offsets.h. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22Add linux framebuffer header include/linux/fb.hStefano Babic
[port of linux 2.6.34 commit 6a9ee8af344e3bd7dbd61e67037096cdf7f83289] Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-11mtd: OneNAND: add support for OneNAND manufactured by NumonyxEnric Balletbo i Serra
This patch adds the Numonyx manufacturer code (0x20) to onenand manufacturers. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Steve Sakoman <steve.sakoman@linaro.org> Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
2010-10-11mtd: add an mtd method for get_len_incl_bad()Ben Gardiner
The logic to 'spread' mtd partitions needs to calculate the length in the mtd device, including bad blocks. This patch introduces a new function, mtd_get_len_incl_bad that can return both the length including bad blocks and whether that length was truncated on the device. This new function will be used by the mtdparts spread command later in this series. The definition of the function is #ifdef'd out in configurations that do not use the new 'mtdparts spread' command. Signed-off-by: Ben Gardiner<bengardiner@nanometrics.ca> CC: Scott Wood <scottwood@freescale.com>
2010-10-11nand: remove dead code and suspend/resumeScott Wood
Get rid of the several "#if 0" sections that were keeping around Linux code that isn't relevant to U-Boot. Besides cluttering the code, these sections make tracking upstream changes harder, rather than easier. It's easy to discard obviously irrelevant diff hunks that patch rejects, but it's not as easy to notice hunks that apply cleanly to the #if 0 section, but *are* relevant to U-Boot and require modification elsewhere. Also remove suspend/resume, as this is not applicable to U-Boot. Removal saves 232 bytes on powerpc. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2010-09-20USB-CDC: Fix coding style issuesVitaly Kuzmichev
Fixes most of checkpatch warnings and errors in USB gadget stack. The most frequently encountered problems are: 1) "(foo*)", "foo * bar", "foo* bar" 2) C99 // comments 3) No spaces before/after/around '?', ':', '=', '==', ',', '&', '(' 4) Spaces before '[' 5) Spaces between function names and '(' 6) Block braces in wrong places 7) Spaces before tabs 8) Macros with complex values not enclosed in parenthesis 9) Multiline comments start just after /* Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2010-09-20Integrate USB gadget layer and USB CDC driver layerRemy Bohmer
Derived from Linux kernel 2.6.27 Signed-off-by: Thomas Smits <ts.smits@gmail.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2010-05-06x86: Fix support for booting bzImageGraeme Russ
Add support for newer (up to 2.6.33) kernels Add zboot command which takes the address of a bzImage as its first argument and (optionally) the size of the bzImage as the second argument (the second argument is needed for older kernels which do not include the bzImage size in the header) Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-04-02nios2: add struct stat support in linux/stat.hThomas Chou
This is needed for jffs2 support. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-01-18move definition of macros likely and unlikely to compiler.hMatthias Kaehlcke
the macros likely and unlikely were defined in include/linux/mtd/compat.h, but used in code not related to MTD. moved the macro definitions to compiler.h Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
2009-12-05add lzop decompression supportPeter Korsgaard
Add lzop decompression support to the existing lzo bitstream handling (think gzip versus zlib), and support it for uImage decompression if CONFIG_LZO is enabled. Lzop doesn't compress as good as gzip (~10% worse), but decompression is very fast (~0.7s faster here on a slow ppc). The lzop decompression code is based on Albin Tonnerre's recent ARM Linux lzo support patch. Cc: albin.tonnerre@free-electrons.com Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
2009-11-18NAND:Extending the nand_ecclayout structureSandeep Paulraj
NANDs with page size of lesser than and equal to 2K are reaching EOL. They are bing replaced with NANDs of page size 4K and above. To support this we have to extend the eccpos field Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-11-15Merge branch 'master' into nextWolfgang Denk
2009-11-13Flex-OneNAND driver supportAmul Kumar Saha
This patch adds support for Flex-OneNAND devices. Signed-off-by: Rohit Hagargundgi <h.rohit@samsung.com> Signed-off-by: Amul Kumar Saha <amul.saha@samsung.com>
2009-11-13NAND: Update to support 64 bit device sizeSandeep Paulraj
This patch adds support for NANDs greater than 2 GB. Patch is based on the MTD NAND driver in the kernel. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-11-07ARM: Use Linux version for unaligned access codeRemy Bohmer
The asm-arm/unaligned.h includes linux/unaligned/access_ok.h This file is unsafe to be used on ARM, since it does an unaligned memory accesses which fails on ARM. Lookin at Linux the basic difference seems to be the header "include/asm-arm/unaligned.h". The Linux version of "unaligned.h" does *not* include "access_ok.h" at all. It includes "le_byteshift.h" and "be_byteshift.h" instead. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Stefan Roese <sr@denx.de> -- include/asm-arm/unaligned.h | 3 - include/linux/unaligned/be_byteshift.h | 70 +++++++++++++++++++++++++++++++++ include/linux/unaligned/le_byteshift.h | 70 +++++++++++++++++++++++++++++++++ 3 files changed, 142 insertions(+), 1 deletion(-) create mode 100644 include/linux/unaligned/be_byteshift.h create mode 100644 include/linux/unaligned/le_byteshift.h
2009-10-24s5pc1xx: SMDKC100: fix compile warningsMinkyu Kang
fix the following compile warnings warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-10-13s5pc1xx: support onenand driverMinkyu Kang
This patch includes the onenand driver for s5pc100 Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-09-17Correct ffs/fls regression for PowerPC etcSimon Kagstrom
Commits 02f99901ed1c9d828e3ea117f94ce2264bf8389e 52d61227b66d4099b39c8309ab37cb67ee09a405 introduced a regression where platform-specific ffs/fls implementations were defined away. This patch corrects that by using PLATFORM_xxx instead of the name itself. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de>
2009-09-15Define ffs/fls for all architecturesSimon Kagstrom
UBIFS requires fls(), which is not defined for arm (and some other architectures) and this patch adds it. The implementation is taken from Linux and is generic. ffs() is also defined for those that miss it. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2009-09-15Move __set/clear_bit from ubifs.h to bitops.hSimon Kagstrom
__set_bit and __clear_bit are defined in ubifs.h as well as in asm/include/bitops.h for some architectures. This patch moves the generic implementation to include/linux/bitops.h and uses that unless it's defined by the architecture. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2009-08-26MTD:NAND: ADD new ECC mode NAND_ECC_HW_OOB_FIRSTSandeep Paulraj
This patch adds the new mode NAND_ECC_HW_OOB_FIRST in the nand code to support 4-bit ECC on TI DaVinci devices with large page (up to 2K) NAND chips. This ECC mode is similar to NAND_ECC_HW, with the exception of read_page API that first reads the OOB area, reads the data in chunks, feeds the ECC from OOB area to the ECC hw engine and perform any correction on the data as per the ECC status reported by the engine. This patch has been accepted by Andrew Morton and can be found at http://userweb.kernel.org/~akpm/mmotm/broken-out/mtd-nand-add-new-ecc-mode-ecc_hw_oob_first.patch Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sneha Narnakaje <nsnehaprabha@ti.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-08-26NAND: ADD page Parameter to all read_page/read_page_raw API'sSandeep Paulraj
This patch adds a new "page" parameter to all NAND read_page/read_page_raw APIs. The read_page API for the new mode ECC_HW_OOB_FIRST requires the page information to send the READOOB command and read the OOB area before the data area. This patch has been accepted by Andrew Morton and can be found at http://userweb.kernel.org/~akpm/mmotm/broken-out/mtd-nand-add-page-parameter-to-all-read_page-read_page_raw-apis.patch WE would like this to become part of the u-boot GIT as well Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sneha Narnakaje <nsnehaprabha@ti.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-08-26OneNAND: Remove unused read_spareramKyungmin Park
Remove unused read_spareram and add unlock_all as kernel does Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-08-25Replace BCD2BIN and BIN2BCD macros with inline functionsAlbin Tonnerre
In the process, also remove backward-compatiblity macros BIN_TO_BCD and BCD_TO_BIN and update the sole board using them to use the new bin2bcd and bcd2bin instead Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2009-07-16Remove legacy NAND and disk on chip code.Scott Wood
Legacy NAND had been scheduled for removal. Any boards that use this were already not building in the previous release due to an #error. The disk on chip code in common/cmd_doc.c relies on legacy NAND, and it has also been removed. There is newer disk on chip code in drivers/mtd/nand; someone with access to hardware and sufficient time and motivation can try to get that working, but for now disk on chip is not supported. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-16nand: Change NAND_MAX_OOBSIZE to 218 as needed for some 4k page devicesStefan Roese
This is needed for the MPC512x NAND driver (fsl_nfc_nand.c) which already defines such a 4k plus 218 bytes ECC layout. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-07Coding style cleanup; update CHANGELOGWolfgang Denk
2009-06-12mtd: Update MTD infrastructure to support 64bit device sizeStefan Roese
This patch brings the U-Boot MTD infrastructure in sync with the current Linux MTD version (2.6.30-rc3). Biggest change is the 64bit device size support and a resync of the mtdpart.c file which has seen multiple fixes meanwhile. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Kyungmin Park <kmpark@infradead.org>
2009-06-12mtd: Add MTD concat support to concatenate multiple MTD NOR devicesStefan Roese
This patch adds concatenation support to the U-Boot MTD infrastructure. By enabling CONFIG_MTD_CONCAT this MTD CFI wrapper will concatenate all found NOR devices into one single MTD device. This can be used by e.g by UBI to access a partition that spans over multiple NOR chips. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-23Add wait flags to support board/chip specific delaysWolfgang Grandegger
The NAND flash on the TQM8548_BE modules requires a short delay after running the UPM pattern like the MPC8360ERDK board does. The TQM8548_BE requires a further short delay after writing out a buffer. Normally the R/B pin should be checked, but it's not connected on the TQM8548_BE. The corresponding Linux FSL UPM driver uses similar delay points at the same locations. To manage these extra delays in a more general way, I introduced the "wait_flags" field allowing the board-specific driver to specify various types of extra delay. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-23Add support for TQM-specific chip select logic to FSL-UPMWolfgang Grandegger
For the NAND chips on the TQM8548 modules, a special chip-select logic is used. It uses dedicated address lines to be set via UPM machine address register (mar). This patch adds such support to the FSL-UPM driver. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-23Add multi chip support to the FSL-UPM driverWolfgang Grandegger
This patch adds support for multi-chip NAND devices to the FSL-UPM driver. The "dev_ready" callback of the "struct fsl_upm_nand" is now called with the argument "chip_nr" to allow testing the proper chip select line. The NAND support of the MPC8360ERDK is updated as well. No other boards are currently using the FSL UPM driver. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-20UBIFS: Implement read-only UBIFS support in U-BootStefan Roese
The U-Boot UBIFS implementation is largely a direct copy from the current Linux version (2.6.29-rc6). As already done in the UBI version we have an "abstraction layer" to redefine or remove some OS calls (e.g. mutex_lock() ...). This makes it possible to use the original Linux code with very little changes. And by this we can better update to later Linux versions. I removed some of the Linux features that are not used in the U-Boot version (e.g. garbage-collection, write support). Signed-off-by: Stefan Roese <sr@denx.de> CC: Artem Bityutskiy <dedekind@infradead.org> CC: Adrian Hunter <ext-Adrian.Hunter@nokia.com>
2009-03-20Add LZO decompressor supportStefan Roese
This patch adds LZO decompression support to U-Boot. It is needed for the upcoming UBIFS support, since UBIFS uses LZO as default compressor/ decompressor. Since we only support read-only in UBIFS, only the decompressor is needed. All this is copied with minor changes from the current Linux kernel version (2.6.28-rc8). This patch only implements this LZO decompressor support for PPC. Other platforms using UBIFS will have to add the required "include/asm/unaligned.h" as well. It should be fairly easy to copy this from the Linux source tree as I have done it for PPC in this patch. Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
