path: root/include/linux/usb/musb.h
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-05Blackfin: RemoveTom Rini
The architecture is currently unmaintained, remove. Cc: Benjamin Matthews <mben12@gmail.com> Cc: Chong Huang <chuang@ucrobotics.com> Cc: Dimitar Penev <dpn@switchfin.org> Cc: Haitao Zhang <hzhang@ucrobotics.com> Cc: I-SYST Micromodule <support@i-syst.com> Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de> Cc: Marek Vasut <marex@denx.de> Cc: Martin Strubel <strubel@section5.ch> Cc: Peter Meerwald <devel@bct-electronic.com> Cc: Sonic Zhang <sonic.adi@gmail.com> Cc: Valentin Yakovenkov <yakovenkov@niistt.ru> Cc: Wojtek Skulski <info@skutek.com> Cc: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Tom Rini <trini@konsulko.com>
2014-10-23musb: fix warning in include/linux/usb/musb.hIgor Grinberg
Fix the following build warning by including linux/compat.h: include/linux/usb/musb.h:110: warning: 'struct device' declared inside parameter list include/linux/usb/musb.h:110: warning: its scope is only this definition or declaration, which is probably not what you want Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-11-20musb-new: port of Linux musb driverIlya Yanok
Existing U-Boot musb driver has no support for the new gadget framework and also seems to have other limitations. As gadget framework is ported from Linux it seems pretty natural to port musb gadget driver as well. This driver supports both host and peripheral modes. This is not a replacement for current musb driver (at least now) as there are still some consumers of the old UDC interface. No DMA operation support included, CONFIG_MUSB_PIO_ONLY should be defined. Virtual root hub device is not implemented. Known problems: with no devices connected usb_lowlevel_start() fails. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
