path: root/include/linux/stddef.h
2022-01-13stddef: Avoid warning with clang with offsetof()Simon Glass
Some bright sparks have decided that a cast on a constant cannot be a constant, so offsetof() produces this warning on clang-10: include/intel_gnvs.h:113:1: error: static_assert expression is not an integral constant expression check_member(acpi_global_nvs, unused2, GNVS_CHROMEOS_ACPI_OFFSET); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ include/linux/kernel.h:284:2: note: expanded from macro 'check_member' offsetof(struct structure, member) == (offset), \ ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ include/linux/stddef.h:20:32: note: expanded from macro 'offsetof' ^ include/intel_gnvs.h:113:1: note: cast that performs the conversions of a reinterpret_cast is ot allowed in a constant expression include/linux/stddef.h:20:33: note: expanded from macro 'offsetof' Fix it by using the compiler built-in version, if available. This syncs the function to the same implementation as Linux v5.16 in this header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-04include/linux/stddef.h: avoid 'warning: preprocessor token offsetof redefined'Kim Phillips
hack to avoid: /opt/gcc-4.6.3-nolibc/powerpc-linux/bin/../lib/gcc/powerpc-linux/4.6.3/include/stddef.h:413:9: warning: preprocessor token offsetof redefined u-boot/include/linux/stddef.h:20:9: this was the original definition tried protecting with __KERNEL__, and #including compiler.h first. Even tried include dir reordering to no avail: +++ b/config.mk @@ -194,7 +194,11 @@ OBJCFLAGS += --gap-fill=0xff gccincdir := $(shell $(CC) -print-file-name=include) CPPFLAGS := $(DBGFLAGS) $(OPTFLAGS) $(RELFLAGS) \ - -D__KERNEL__ + -D__KERNEL__ \ + -I $(gccincdir) \ + -nostdinc + +# -isystem $(gccincdir) \ # Enable garbage collection of un-used sections for SPL ifeq ($(CONFIG_SPL_BUILD),y) @@ -227,8 +231,7 @@ CPPFLAGS += -I$(OBJTREE)/include2 -I$(OBJTREE)/include endif CPPFLAGS += -I$(TOPDIR)/include -CPPFLAGS += -fno-builtin -ffreestanding -nostdinc \ - -isystem $(gccincdir) -pipe $(PLATFORM_CPPFLAGS) +CPPFLAGS += -fno-builtin -ffreestanding -pipe $(PLATFORM_CPPFLAGS) Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2002-03-31Initial revisionwdenk
