path: root/include/linux/stat.h
2010-04-02nios2: add struct stat support in linux/stat.hThomas Chou
This is needed for jffs2 support. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2008-03-28sh: Add support stat structure and stat.hNobuhiro Iwamatsu
2007-05-08Merge git://www.denx.de/git/u-bootMichal Simek
Conflicts: include/asm-microblaze/microblaze_intc.h include/linux/stat.h
2007-04-24[PATCH] MTD partition support, JFFS2 supportMichal Simek
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-avr32; code cleanup.Wolfgang Denk
2007-04-14AVR32: Provide a definition of struct statHaavard Skinnemoen
Copy the definition of struct stat from the Linux kernel. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-03-09[Blackfin][PATCH-2/2] Common files changed to support bf533 platformAubrey.Li
2006-03-12Add ADI Blackfin supportWolfgang Denk
- add support for Analog Devices Blackfin BF533 CPU - add support for the ADI BF533 Stamp uClinux board - add support for the ADI BF533 EZKit board Patches by Richard Klingler, June 11th 2005:
2005-09-25Add cramfs support for m68kWolfgang Denk
Patch by Zachary Landau, 21 Feb 2005
2003-12-12Add JFFS2 support for INCA-IP boardwdenk
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
2002-07-14Initial revisionwdenk
