path: root/include/linux/mtd/mtd.h
2017-11-29mtd: add mtd_ooblayout_xxx() helper functionsBoris Brezillon
In order to make the ecclayout definition completely dynamic we need to rework the way the OOB layout are defined and iterated. Create a few mtd_ooblayout_xxx() helpers to ease OOB bytes manipulation and hide ecclayout internals to their users. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> [Linux commit: 75eb2cec251fda33c9bb716ecc372819abb9278a] [masahiro: cherry-pick more code from adbbc3bc827eb1f43a932d783f09ba55c8ec8379] Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-23mtd: remove MTDDEBUG() and CONFIG_MTD_DEBUGMasahiro Yamada
All users of this macro have been converted. Remove MTDDEBUG and related CONFIG options. ubifs_dbg_msg_key() is kept. It is silent unless DEBUG is defined. I am not touching scripts/config_whitelist.txt. The deprecated options will be dropped by the next resync. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-04printk: collect printk stuff into <linux/printk.h> with loglevel supportMasahiro Yamada
When we import code from Linux, with regular re-sync planned, we want to use printk() and pr_*(). U-Boot does not support them in a clean way. So, people end up with local macros, or compat headers here and there, then we occasionally see build errors of definition conflicts. We have include/linux/compat.h, but putting all sorts of unrelated things into a single header is just a temporal workaround. Hence this patch, to find the best home for all printk variants. If you want to use printk() and friends, please include <linux/printk.h>. This header is self-contained, and pulls in only a few headers. When I was testing this clean-up, I noticed the image size exceeded its platform limit on some boards. This is because all pr_*() that were previously defined as no-op in include/linux/mtd/mtd.h (unless CONFIG_MTD_DEBUG is set), are now enabled. To make such boards happy, this commit also implements CONFIG_LOGLEVEL. The concept is similar to the kernel parameter "loglevel". (Actually, the Kconfig help message was taken from kernel-paremeter.txt of Linux) Messages with a loglevel smaller than console loglevel will be printed. The difference is the loglevel is build-time determined. To save the image size, lower priority pr_*() are compiled out. I set the default of CONFIG_LOGLEVEL to 6, i.e. pr_notice and higher priority messages are compiled in. I adjusted CONFIG_LOGLEVEL to avoid build error for some boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> [trini: Add in SPL_LOGLEVEL that is the same as LOGLEVEL] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-24mtd: fix compiler warningsSteve Rae
- add missing declaration - update debug output format specifiers Signed-off-by: Steve Rae <steve.rae@raedomain.com>
2016-06-03mtd: nand: Sync with Linux v4.6Scott Wood
Updates the NAND code to match Linux v4.6. The previous sync was from Linux v4.1 in commit d3963721d93fafa. Note that none of the individual NAND drivers tracked Linux closely enough to be synced themselves, other than manually applying a few cross-tree changes. Signed-off-by: Scott Wood <oss@buserror.net> Tested-by: Heiko Schocher <hs@denx.de>
2015-11-12include/linux/mtd: Update copyright noticesTom Rini
Condense these updates down to SPDX tags too while doing this. This is a port of a1452a3771c4eb85bd779790b040efdc36f4274e from the Linux Kernel. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-12dm: implement a MTD uclassThomas Chou
Implement a Memory Technology Device (MTD) uclass. It should include most flash drivers in the future. Though no uclass ops are defined yet, the MTD ops could be used. The NAND flash driver is based on MTD. The CFI flash and SPI flash support MTD, too. It should make sense to convert them to MTD uclass. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-26ubi,ubifs: sync with linux v4.2Heiko Schocher
sync with linux v4.2 commit 64291f7db5bd8150a74ad2036f1037e6a0428df2 Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Aug 30 11:34:09 2015 -0700 Linux 4.2 This update is needed, as it turned out, that fastmap was in experimental/broken state in kernel v3.15, which was the last base for U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
2015-08-25mtd: nand: Increase max sizes of OOB and Page sizeSiva Durga Prasad Paladugu
Increase max sizes for OOB, Page size and eccpos to suit for Micron MT29F32G08 part Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
2015-08-25mtd: Introduce mtd_block_isreserved()Ezequiel Garcia
In addition to mtd_block_isbad(), which checks if a block is bad or reserved, it's needed to check if a block is reserved only (but not bad). This commit adds an MTD interface for it, in a similar fashion to mtd_block_isbad(). While here, fix mtd_block_isbad() so the out-of-bounds checking is done before the callback check. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Pekon Gupta <pekon@ti.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com> [scottwood: Cherry-picked from Linux 8471bb73ba10ed67] Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-07-10mtd: fix false positive "Offset exceeds device limit" errorMasahiro Yamada
Since commit 09c3280754f8 (mtd, nand: Move common functions from cmd_nand.c to common place), NAND commands would not work at all on large devices. => nand read 80000000 10000 10000 NAND read: Offset exceeds device limit => nand erase 100000 100000 NAND erase: Offset exceeds device limit The type of the "size" of "struct mtd_info" is uint64_t, while mtd_arg_off_size() and mtd_arg_off() treat chipsize as int type. The chipsize is wrapped around if the argument is given with 2GB or larger. Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-30mtd, nand: Move common functions from cmd_nand.c to common placeHeiko Schocher
Move common functions from cmd_nand.c (for calculating offset and size from cmdline paramter) to common place, so they could used from other commands which use mtd partitions. For onenand the arg_off_size() is left in common/cmd_onenand.c. It should use now the common arg_off() function, but as I could not test onenand I let it there ... Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Jagannadh Teki <jteki@openedev.com>
2014-09-16kbuild: force to define __UBOOT__ in all the C sourcesMasahiro Yamada
U-Boot has imported various source files from other projects, mostly Linux. Something like #ifdef __UBOOT__ [ modification for U-Boot ] #else [ original code ] #endif is an often used strategy for clarification of adjusted parts, that is, easier re-sync in future. Instead of defining __UBOOT__ in each source file, passing it from the top Makefile would be easier. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-08-25mtd,ubi,ubifs: sync with linux v3.15Heiko Schocher
snyc with linux v3.15: commit 1860e379875dfe7271c649058aeddffe5afd9d0d Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Jun 8 11:19:54 2014 -0700 Linux 3.15 Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: update for the sync with linux v3.14Heiko Schocher
while playing with the new mtd/ubi/ubifs sync, found some small updates for it: - add del_mtd_partition() to include/linux/mtd/mtd - mtd: add a debug_printf - remove some not used functions Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Tom Rini <trini@ti.com>
2014-08-25mtd, ubi, ubifs: resync with Linux-3.14Heiko Schocher
resync ubi subsystem with linux: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 A nice side effect of this, is we introduce UBI Fastmap support to U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Joerg Krause <jkrause@posteo.de>
2013-11-21mtd: move & update nand_ecclayout structure (plus board changes)Prabhakar Kushwaha
nand_ecclayout is present in mtd.h at Linux. Move this structure to mtd.h to comply with Linux. Also, increase the ecc placement locations to 640 to suport device having writesize/oobsize of 8KB/640B. This means that the maximum oobsize has gone up to 640 bytes and consequently the maximum ecc placement locations have also gone up to 640. Changes from Prabhabkar's version (squashed into one patch to preserve bisectability): - Added _LARGE to MTD_MAX_*_ENTRIES This makes the names match current Linux source, and resolves a conflict between http://patchwork.ozlabs.org/patch/280488/ and http://patchwork.ozlabs.org/patch/284513/ The former was posted first and is closer to matching Linux, but unlike Linux it does not add _LARGE to the names. The second adds _LARGE to one of the names, and depends on it in a subsequent patch (http://patchwork.ozlabs.org/patch/284512/). - Made max oobfree/eccpos configurable, and used this on tricorder, alpr, ASH405, T4160QDS, and T4240QDS (these boards failed to build for me without doing so, due to a size increase). On tricorder SPL, this saves 2576 bytes (and makes the SPL build again) versus the new default of 640 eccpos and 32 oobfree, and saves 336 bytes versus the old default of 128 eccpos and 8 oobfree. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> CC: Vipin Kumar <vipin.kumar@st.com> [scottwood@freescale.com: changes as described above] Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Thomas Weber <weber@corscience.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Stefan Roese <sr@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Stefan Roese <sr@denx.de>
2013-05-31mtd: resync with Linux-3.7.1Sergey Lapin
This patch is essentially an update of u-boot MTD subsystem to the state of Linux-3.7.1 with exclusion of some bits: - the update is concentrated on NAND, no onenand or CFI/NOR/SPI flashes interfaces are updated EXCEPT for API changes. - new large NAND chips support is there, though some updates have got in Linux-3.8.-rc1, (which will follow on top of this patch). To produce this update I used tag v3.7.1 of linux-stable repository. The update was made using application of relevant patches, with changes relevant to U-Boot-only stuff sticked together to keep bisectability. Then all changes were grouped together to this patch. Signed-off-by: Sergey Lapin <slapin@ossfans.org> [scottwood@freescale.com: some eccstrength and build fixes] Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03NAND: Really ignore bad blocks when scrubbingMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> [scottwood@freescale.com: use chip instead of redundant priv_nand] Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2010-10-11mtd: add an mtd method for get_len_incl_bad()Ben Gardiner
The logic to 'spread' mtd partitions needs to calculate the length in the mtd device, including bad blocks. This patch introduces a new function, mtd_get_len_incl_bad that can return both the length including bad blocks and whether that length was truncated on the device. This new function will be used by the mtdparts spread command later in this series. The definition of the function is #ifdef'd out in configurations that do not use the new 'mtdparts spread' command. Signed-off-by: Ben Gardiner<bengardiner@nanometrics.ca> CC: Scott Wood <scottwood@freescale.com>
2010-10-11nand: remove dead code and suspend/resumeScott Wood
Get rid of the several "#if 0" sections that were keeping around Linux code that isn't relevant to U-Boot. Besides cluttering the code, these sections make tracking upstream changes harder, rather than easier. It's easy to discard obviously irrelevant diff hunks that patch rejects, but it's not as easy to notice hunks that apply cleanly to the #if 0 section, but *are* relevant to U-Boot and require modification elsewhere. Also remove suspend/resume, as this is not applicable to U-Boot. Removal saves 232 bytes on powerpc. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2009-07-07Coding style cleanup; update CHANGELOGWolfgang Denk
2009-06-12mtd: Update MTD infrastructure to support 64bit device sizeStefan Roese
This patch brings the U-Boot MTD infrastructure in sync with the current Linux MTD version (2.6.30-rc3). Biggest change is the 64bit device size support and a resync of the mtdpart.c file which has seen multiple fixes meanwhile. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Cc: Kyungmin Park <kmpark@infradead.org>
2008-10-29NAND: sync with 2.6.27Scott Wood
This brings the core NAND code up to date with the Linux kernel. Since there were several drivers in Linux as of the last update that are not in u-boot, I'm not bringing over new drivers that have been added since in the absence of an interested party. I did not update OneNAND since it was recently synced by Kyungmin Park, and I'm not sure exactly what the common ancestor is. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-14Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-08-13Fix OneNAND build breakKyungmin Park
Since page size field is changed from oobblock to writesize. But OneNAND is not updated. - fix bufferram management at erase operation This patch includes the NAND/OneNAND state filed too. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-09NAND: Rename DEBUG to MTDDEBUG to avoid namespace pollution.Scott Wood
This is particularly problematic now that non-NAND-specific code is including <nand.h>, and thus all debugging code is being compiled regardless of whether it was requested, as reported by Scott McNutt <smcnutt@psyent.com>. Signed-off-by: Scott Wood <scottwood@freescale.com>
2005-09-14Update of new NAND codeWolfgang Denk
Patch by Ladislav Michl, 13 Sep 2005
2005-08-17Rewrite of NAND code based on what is in 2.6.12 Linux kernelWolfgang Denk
Patch by Ladislav Michl, 29 Jun 2005
