path: root/include/linux/mtd/flashchip.h
2014-09-16kbuild: force to define __UBOOT__ in all the C sourcesMasahiro Yamada
U-Boot has imported various source files from other projects, mostly Linux. Something like #ifdef __UBOOT__ [ modification for U-Boot ] #else [ original code ] #endif is an often used strategy for clarification of adjusted parts, that is, easier re-sync in future. Instead of defining __UBOOT__ in each source file, passing it from the top Makefile would be easier. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-08-25mtd, ubi, ubifs: resync with Linux-3.14Heiko Schocher
resync ubi subsystem with linux: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 A nice side effect of this, is we introduce UBI Fastmap support to U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Joerg Krause <jkrause@posteo.de>
