path: root/include/linux/kconfig.h
2017-08-13spl: dm: use CONFIG_IS_ENABLED to test for the DM optionPhilipp Tomsich
Even though there's now a TPL_DM configuration option, the spl logic still checks for SPL_DM and thus does not pick up the proper config option. This introduces the use of CONFIG_IS_ENABLED(DM) in spl.c to always pick up the desired configuration option instead of having a hard-coded check for the SPL variant. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-18linux/kconfig.h: add CPP macros useful for per-image config optionsMasahiro Yamada
The previous commit introduced a useful macro used in makefiles, in order to reference to different variables (CONFIG_... or CONFIG_SPL_...) depending on the build context. Per-image config option control is a PITA in C sources, too. Here are some macros useful in C/CPP expressions. CONFIG_IS_ENABLED(FOO) can be used as a shorthand for (!defined(CONFIG_SPL_BUILD) && defined(CONFIG_FOO)) || \ (defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_FOO)) For example, it is useful to describe C code as follows, #if CONFIG_IS_ENABLED(OF_CONTROL) (device tree code) #else (board file code) #endif The ifdef conditional above is switched by CONFIG_OF_CONTROL during the U-Boot proper building (CONFIG_SPL_BUILD is not defined), and by CONFIG_SPL_OF_CONTROL during SPL building (CONFIG_SPL_BUILD is defined). The macro can be used in C context as well, so you can also write the equivalent code as follows: if (CONFIG_IS_ENABLED(OF_CONTROL)) { (device tree code) } else { (board file code) } Another useful macro is CONFIG_VALUE(). CONFIG_VALUE(FOO) is expanded into CONFIG_FOO if CONFIG_SPL_BUILD is undefined, and into CONFIG_SPL_FOO if CONFIG_SPL_BUILD is defined. You can write as follows: text_base = CONFIG_VALUE(TEXT_BASE); instead of: #ifdef CONFIG_SPL_BUILD text_base = CONFIG_SPL_TEXT_BASE; #else text_base = CONFIG_TEXT_BASE; #endif This commit also adds slight hacking on fixdep so that it can output a correct list of fixed dependencies. If the fixdep finds CONFIG_IS_ENABLED(FOO) in a source file, we want $(wildcard include/config/foo.h) in the U-boot proper building context, while we want $(wildcard include/config/spl/foo.h) in the SPL build context. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30kconfig: import Kconfig files from Linux 3.16-rc7Masahiro Yamada
Import - scripts/kconfig/* - include/linux/kconfig.h from Linux 3.16-rc7. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
