Add wait_event_timeout - sleep until a condition gets true or a
timeout elapses.
This is a stripped version of the same from Linux kernel with the
following u-boot specific modifications:
- no wait queues supported
- use u-boot timer to detect timeouts
- check for Ctrl-C pressed during wait
Signed-off-by: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
Signed-off-by: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
[trini: Drop atomic_read from gadget/ether.c as this has existed for a
while and now causes problems]
It is bad practice to include common.h in other header files since it can
bring in any number of superfluous definitions. It implies that some C
files don't include it and thus may be missing CONFIG options that are set
up by that file. The C files should include these themselves.
Update some header files in arch/arm to drop this.
Most files don't need this header and it pulls in quite of lots of stuff,
malloc() in particular. Drop it.
Currently there are two ethernet drivers (mvneta.c and mvpp2.c) that
has netdev_### (eg: netdev_dbg) log macros defined in its own driver
file. This adds these log macros in a common place linux/compat.h.
Often during debugging session it's very interesting to see
what data we were dealing with. For example what we write or read
to/from memory or peripherals.
This change introduces functions that allow to dump binary
data with one simple function invocation like:
------------------->8----------------
print_hex_dump_bytes("", DUMP_PREFIX_OFFSET, buf, len);
which gives us the following:
00000000: f2 b7 c9 88 62 61 75 64 72 61 74 65 3d 31 31 35 ....baudrate=115
00000010: 32 30 30 00 62 6f 6f 74 61 72 67 73 3d 63 6f 6e 200.bootargs=con
00000020: 73 6f 6c 65 3d 74 74 79 53 33 2c 31 31 35 32 30 sole=ttyS3,11520
00000030: 30 6e 38 00 62 6f 6f 74 64 65 6c 61 79 3d 33 00 0n8.bootdelay=3.
00000040: 62 6f 6f 74 66 69 6c 65 3d 75 49 6d 61 67 65 00 bootfile=uImage.
00000050: 66 64 74 63 6f 6e 74 72 6f 6c 61 64 64 72 3d 39 fdtcontroladdr=9
00000060: 66 66 62 31 62 61 30 00 6c 6f 61 64 61 64 64 72 ffb1ba0.loadaddr
00000070: 3d 30 78 38 32 30 30 30 30 30 30 00 73 74 64 65 =0x82000000.stde
00000080: 72 72 3d 73 65 72 69 61 6c 30 40 65 30 30 32 32 rr=serial0@e0022
00000090: 30 30 30 00 73 74 64 69 6e 3d 73 65 72 69 61 6c 000.stdin=serial
000000a0: 30 40 65 30 30 32 32 30 30 30 00 73 74 64 6f 75 0@e0022000.stdou
000000b0: 74 3d 73 65 72 69 61 6c 30 40 65 30 30 32 32 30 t=serial0@e00220
000000c0: 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00..............
Source of hexdump.c was copied from Linux kernel v4.7-rc2.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Mario Six <mario.six@gdsys.cc>
Cc: Stefan Roese <sr@denx.de>
Many drivers had started to use dev_err, dev_info, etc. for log
functions. Currently, we are relying on <linux/compat.h>, but I
guess the best home is <dm/device.h>, taking into account that
Linux defines them in <linux/device.h>.
For now, I am leaving the ones in <linux/compat.h> because lots of
Linux-originated code uses dev_*(), but the first argument is not
struct udevice, so we need to ignore the bogus argument. More
efforts are needed to iron out the issues.
Collect runtime BUG/WARN into a self-contained header <linux/bug.h>
to make these macros easier to use.
When we import code from Linux, with regular re-sync planned, we want
to use printk() and pr_*(). U-Boot does not support them in a clean
way. So, people end up with local macros, or compat headers here and
there, then we occasionally see build errors of definition conflicts.
We have include/linux/compat.h, but putting all sorts of unrelated
things into a single header is just a temporal workaround. Hence this
patch, to find the best home for all printk variants. If you want to
use printk() and friends, please include <linux/printk.h>. This header
is self-contained, and pulls in only a few headers.
When I was testing this clean-up, I noticed the image size exceeded
its platform limit on some boards. This is because all pr_*() that
were previously defined as no-op in include/linux/mtd/mtd.h (unless
CONFIG_MTD_DEBUG is set), are now enabled.
To make such boards happy, this commit also implements CONFIG_LOGLEVEL.
The concept is similar to the kernel parameter "loglevel". (Actually,
the Kconfig help message was taken from kernel-paremeter.txt of Linux)
Messages with a loglevel smaller than console loglevel will be printed.
The difference is the loglevel is build-time determined. To save the
image size, lower priority pr_*() are compiled out. I set the default
of CONFIG_LOGLEVEL to 6, i.e. pr_notice and higher priority messages
are compiled in.
I adjusted CONFIG_LOGLEVEL to avoid build error for some boards.
[trini: Add in SPL_LOGLEVEL that is the same as LOGLEVEL]
In linux v4.9 this returns a value. This saves checking the warning
condition twice in some code.
Update the U-Boot version to do this also.
Currently, mdelay() and udelay() are declared in include/common.h,
while ndelay() in include/linux/compat.h. It would be nice to
collect them into include/linux/delay.h like Linux.
While we are here, fix the ndelay() implementation; I used the
DIV_ROUND_UP() instead of (x)/1000 because it must wait *longer*
than the given period of time.
Commit c68c62 ("i2c: mvtwsi: Make delay times frequency-dependent")
extensively used the ndelay function with a calculated parameter
which is dependant on the configured frequency of the I2C bus. If
standard speed is employed, the parameter is usually 10000 (10000ns
period length for 100kHz frequency).
But, since the arm architecture does not implement a proper version of
ndelay, the fallback default from include/linux/compat.h is used,
which defines every ndelay as udelay(1). This causes problems for
slower speeds on arm, since the delay time is now 9us too short for
the desired frequency, which leads to random failures of the I2C
interface.
To remedy this, we implement a proper, parameter-aware ndelay fallback
for architectures that don't implement a real ndelay function.
Reported-By: Jason Brown <Jason.brown@apcon.com>
To: Tom Rini <trini@konsulko.com>
To: Heiko Schocher <hs@denx.de>
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Collect a couple of duplicated defines into a single place.
In order to prevent build errors for copied code from linux introduce
dev_warn().
Suggested-by: Scott Wood <oss@buserror.net>
Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
Use the is_power_of_2() definition from log2.h to align with the
kernel implementation.
Reviewed-by: Jagan Teki <jteki@openedev.com>
add missing definitions for the ubi/ubifs sync
with linux 4.2, also change "#define kfree ..."
into a static inline, so prevent ubi compile error:
CC drivers/mtd/ubi/fastmap.o
drivers/mtd/ubi/fastmap.c: In function 'scan_pool':
drivers/mtd/ubi/fastmap.c:475:3: error: called object 'free' is not a function
Currently, kzalloc() returns zero-filled memory, while kmalloc()
simply ignores the second argument and never fills the memory
area with zeros.
I want kmalloc(size, __GFP_ZERO) to behave as kzalloc() does,
which will make it easier to add more memory allocator variants.
With the introduction of __GFP_ZERO flag, going forward, kzmalloc()
variants can fall back to kmalloc() enabling the __GFP_ZERO flag.
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
The vzalloc(size) is equivalent to kzalloc(size, 0). Move it to
include/linux/compat.h as an inline function in order to avoid the
function call overhead.
The macro cpu_relax() is defined by several headers in different
ways.
arch/{arm,avr32,mips}/include/asm/processor.h defines it as follows:
#define cpu_relax() barrier()
On the other hand, include/linux/compat.h defines it as follows:
#define cpu_relax() do {} while (0)
If both headers are included from the same source file, the warning
warning: "cpu_relax" redefined [enabled by default]
is displayed.
It effectively makes it impossible to include <linux/compat.h>
from some sources. Drop the latter.
Did a bunch of things to get dwc3/gadget.c compile in u-boot without
build errors and warnings
*) Changed the included header files to that used in u-boot.
*) Used dma_alloc_coherent and dma_free_coherent APIs of u-boot
*) removed sg support
*) remove jiffies and used a simple while loop
*) removed irq support and added a function to call these interrupt handler.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
This commit is a preperation for a subsequent UBIFS commit
which needs atomic_long operations.
Therefor "include/asm-generic/atomic-long.h" is imported
from 1860e37 Linux 3.15
Signed-off-by: Anton Habegger <anton.habegger@gmail.com>
__user and __iomem are defined in include/linux/compiler.h.
MAX_ERRNO is defined in include/linux/err.h.
U-Boot has imported various utility macros from Linux
scattering them to various places without consistency.
In include/common.h are min, max, min3, max3, ARRAY_SIZE, ALIGN,
container_of, DIV_ROUND_UP, etc.
In include/linux/compat.h are min_t, max_t, round_up, round_down,
etc.
We also have duplicated defines of min_t in some *.c files.
Moreover, we are suffering from too cluttered include/common.h.
This commit moves various macros that originate in
include/linux/kernel.h of Linux to their original position.
Note:
This commit simply moves the macros; the macros roundup,
min, max, min2, max3, ARRAY_SIZE are different
from those of Linux at this point.
- move linux specific defines from usb and video code
into linux/compat.h
- move common linux specific defines from include/ubi_uboot.h
to linux/compat.h
- add for new mtd/ubi/ubifs sync new needed linux specific
defines to linux/compat.h
[trini: Add spin_lock_irqsave/spin_unlock_irqrestore dummies from
usb/lin_gadet_compat.h]
[backport from linux commit 204b885e and 218e180e7]
64 bit processors are becomming more and more popular.
lower_32_bits and upper_32_bits save our labor doing
shifts/manipulations like (u32)(n) and (u32)((n) >> 32).
They are good helpers in both little and big endian cases.
Port these two functions here from Linux:include/linux/kernel.h,
cater the comment message to little/big endian cases.
Later on, developers could include linux/compat.h if they want to
use these two functions.
Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com>
Since kernel code current use many dev_xxx() instead of using printk. To
compatible, move those dev_xxx from usb driver to linux/compat.h. Then all
driver code can use dev_err, dev_info and dev_vdbg.
This patch also removed duplicated macro definitions in usb driver.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Acked-by: Scott Wood <scottwood@freescale.com>
redefined
include/linux/compat.h:4:9: warning: preprocessor token __user redefined
include/linux/compiler.h:7:10: this was the original definition
include/linux/compat.h:5:9: warning: preprocessor token __iomem redefined
include/linux/compiler.h:12:10: this was the original definition
fixup __iomem, __user definitions in compat.h code appears to be placed
there as a cover up from a code import from linux when u-boot didn't yet
have a compiler.h, introduced by commit
932394ac43e2e778e664eeb6e456fecd0fae6e59 "Rewrite of NAND code based on
what is in 2.6.12 Linux kernel".
Merge our duplicate definitions with the common header.
Also fix drivers/usb/gadget/s3c_udc_otg_xfer_dma.c to
use min() instead of min_t() since we remove the latter
from compat.h.
Additionally use memalign() directly as the lin_gadget
specific kmalloc() macro is removed from lin_gadget_compat.h
by this patch.
Cc: Lukasz Majewski <l.majewski@samsung.com>
This lets us use it in more places than just mtd code.
