path: root/include/linux/compat.h
2012-11-04include/linux/compat.h: fix warning: preprocessor token {__iomem, __user} ↵Kim Phillips
redefined include/linux/compat.h:4:9: warning: preprocessor token __user redefined include/linux/compiler.h:7:10: this was the original definition include/linux/compat.h:5:9: warning: preprocessor token __iomem redefined include/linux/compiler.h:12:10: this was the original definition fixup __iomem, __user definitions in compat.h code appears to be placed there as a cover up from a code import from linux when u-boot didn't yet have a compiler.h, introduced by commit 932394ac43e2e778e664eeb6e456fecd0fae6e59 "Rewrite of NAND code based on what is in 2.6.12 Linux kernel". Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-04-30lin_gadget: use common linux/compat.hMike Frysinger
Merge our duplicate definitions with the common header. Also fix drivers/usb/gadget/s3c_udc_otg_xfer_dma.c to use min() instead of min_t() since we remove the latter from compat.h. Additionally use memalign() directly as the lin_gadget specific kmalloc() macro is removed from lin_gadget_compat.h by this patch. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com>
2012-04-30linux/compat.h: rename from linux/mtd/compat.hMike Frysinger
This lets us use it in more places than just mtd code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
