path: root/include/linux/arm-smccc.h
2017-04-18ARM: adjust arm-smccc code for use in U-BootMasahiro Yamada
Adjust ARM SMC Calling Convention code for U-Boot: - Replace the license block with SPDX - Change path to asm-offsets.h - Define UNWIND() as no-op - Add Kconfig entry - Add asm-offsets Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-04-18ARM: import arm-smccc code from Linux 4.11-rc6Masahiro Yamada
Imports ARM SMC Calling Convention code from Linux 4.11-rc6. The files have been copied as follows: [Linux] [U-Boot] arch/arm/kernel/smccc-call.S -> arch/arm/cpu/armv7/smccc-call.S arch/arm64/kernel/smccc-call.S -> arch/arm/cpu/armv8/smccc-call.S arch/arm/include/asm/opcodes* -> arch/arm/include/asm/opcodes* include/linux/arm-smccc.h -> include/linux/arm-smccc.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
