path: root/include/libfdt_env.h
2016-08-20libfdt: Add new headers and definesMaxime Ripard
The libfdt overlay support introduces a bunch of new includes and functions. Make sure we are able to build it by adding the needed glue. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-07-24Add LGPL-2.1+ SPDX-License-Identifier to source filesWolfgang Denk
2013-05-10Move FDT_RAMDISK_OVERHEAD from fdt.h to libfdt_env.hGerald Van Baren
The define should not have been put in fdt.h originally, libfdt_env.h is the proper place for target-specific customizations. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2013-02-07libfdt_env.h: add fdt type definitionsKim Phillips
fdt types are big endian. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2009-07-19compiler.h: unify system ifdef cruft hereMike Frysinger
Shove a lot of the HOSTCC and related #ifdef checking crap into the new compiler.h header so that we can keep all other headers nice and clean. Also introduce custom uswap functions so we don't have to rely on the non standard implementations that a host may (or may not in the case of OS X) provide. This allows mkimage to finally build cleanly on an OS X system. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-04Add support for building native win32 toolsPeter Tyser
Add support for compiling the host tools in the tools directory using the MinGW toolchain. This produces executables which can be used on standard Windows computers without requiring cygwin. One must specify the MinGW compiler and strip utilities as if they were the host toolchain in order to build win32 executables, eg: make HOSTCC=i586-mingw32msvc-gcc HOSTSTRIP=i586-mingw32msvc-strip tools Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-10libfdt: Fix redefined uintptr_t warning for USE_HOSTCCJerry Van Baren
Compiling U-Boot in an old OS environment (RedHat-7.3 :-) gives the following warnings from FDT: include/libfdt_env.h:50: warning: redefinition of 'uintptr_t' /usr/include/stdint.h:129: warning: 'uintptr_t' previously declared here Fix: Protect the definition of uintptr_t when compiling on the host system. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2008-10-21FDT: don't use private kernel header filesWolfgang Denk
On some systems (for example Fedora Core 4) U-Boot builds with the following wanrings only: ... In file included from /home/wd/git/u-boot/include/libfdt_env.h:33, from fdt.c:51: /usr/include/asm/byteorder.h:6:2: warning: #warning using private kernel header; include <endian.h> instead! This patch fixes this problem. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-08-24dtc: Enable and fix -Wpointer-arith warningsDavid Gibson
This patch turns on the -Wpointer-arith option in the dtc Makefile, and fixes the resulting warnings due to using (void *) in pointer arithmetic. While convenient, pointer arithmetic on void * is not portable, so it's better that we avoid it, particularly in libfdt. Also add necessary definition of uintptr_t needed by David Gibson's changeset "dtc: Enable and fix -Wpointer-arith warnings" (the definition comes from stdint.h, which u-boot doesn't have). -- gvb Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2008-06-10fdt: unshadow global working fdt variableKim Phillips
differentiate with local variables of the same name by renaming the global 'fdt' variable 'working_fdt'. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-27Fix host tool build breakage, take twoBartlomiej Sieka
Revert commit 87c8431f and fix build breakage so that the build continues to work on FC systems. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-02-29[new uImage] Add libfdt support to mkimageBartlomiej Sieka
2007-08-10Minor code clean up.Gerald Van Baren
Declare the variable fdt properly as extern. Call the "set_fn" function pointer the "short way" without the full dereferencing syntax. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2007-04-06libfdt: Make fdt_check_header() publicGerald Van Baren
Changed _fdt_check_header() to fdt_check_header() and made it part of the interface - it is a useful routine. Also did some asthetics cleanup to the include files (headers).
2007-03-31libfdt: Customizations for use by u-boot.Gerald Van Baren
Changes to David Gibson's original source to fit into u-boot's environment. No functionality changes.
2007-03-31libfdt: Import libfdt source (1 of 2)Gerald Van Baren
This adds the applicable libfdt source files (unmodified) and a README to explain where the source came from.
