path: root/include/libfdt.h
2008-08-24libfdt: Implement fdt_get_property_namelen() and fdt_getprop_namelen()David Gibson
As well as fdt_subnode_offset(), libfdt includes an fdt_subnode_offset_namelen() function that takes the subnode name to look up not as a NUL-terminated string, but as a string with an explicit length. This can be useful when the caller has the name as part of a longer string, such as a full path. However, we don't have corresponding 'namelen' versions for fdt_get_property() and fdt_getprop(). There are less obvious use cases for these variants on property names, but there are circumstances where they can be useful e.g. looking up property names which need to be parsed from a longer string buffer such as user input or a configuration file, or looking up an alias in a path with IEEE1275 style aliases. So, since it's very easy to implement such variants, this patch does so. The original NUL-terminated variants are, of course, implemented in terms of the namelen versions. Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2008-08-24libfdt: Improve documentation in libfdt.hWolfram Sang
Fix a few typos and mistakes. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: David Gibson <david@gibson.dropbear.id.au>
2008-08-24dtc: Enable and fix -Wcast-qual warningsDavid Gibson
Enabling -Wcast-qual warnings in dtc shows up a number of places where we are incorrectly discarding a const qualification. There are also some places where we are intentionally discarding the 'const', and we need an ugly cast through uintptr_t to suppress the warning. However, most of these are pretty well isolated with the *_w() functions. So in the interests of maximum safety with const qualifications, this patch enables the warnings and fixes the existing complaints. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2008-03-18libfdt: Add and use a node iteration helper function.David Gibson
This patch adds an fdt_next_node() function which can be used to iterate through nodes of the tree while keeping track of depth. This function is used to simplify the iteration code in a lot of other functions, and is also exported for use by library users. Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2008-03-18libfdt: Add fdt_set_name() functionDavid Gibson
This patch adds an fdt_set_name() function to libfdt, mirroring fdt_get_name(). This is a r/w function which alters the name of a given device tree node. Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2008-01-08libfdt: Add more documentation (patch the seventh)David Gibson
This patch adds more documenting comments to libfdt.h. Specifically, these document the read/write functions (not including fdt_open_into() and fdt_pack(), for now). Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2008-01-08libfdt: Add more documentation (patch the sixth)David Gibson
This patch adds some more documenting comments to libfdt.h. Specifically this documents all the write-in-place functions. Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2008-01-02Fix compile problem introduced by "cleanup" commit 3dfd708cWolfgang Denk
2008-01-02Minor coding style cleanup.Wolfgang Denk
2007-11-21Update libfdt from device tree compiler (dtc)Kumar Gala
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from the device tree compiler (dtc) project. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-21Removed some nonused fdt functions and moved fdt_find_and_setprop out of libfdtKumar Gala
Removed: fdt_node_is_compatible fdt_find_node_by_type fdt_find_compatible_node To ease merge of newer libfdt as we aren't using them anywhere at this time. Also moved fdt_find_and_setprop out of libfdt into fdt_support.c for the same reason. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-06libfdt: add convenience function fdt_find_and_setprop()Grant Likely
Given the path to a node, fdt_find_and_setprop() allows a property value to be set directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-10Add fdt_find_node_by_type() and fdt_find_compatible_node() to LIBFDTGerald Van Baren
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2007-08-10Replace fdt_node_offset() with fdt_find_node_by_path().Gerald Van Baren
The new name matches more closely the kernel's name, which is also a much better description. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2007-04-14Add some utilities to manipulate the reserved memory map.Gerald Van Baren
2007-04-06libfdt: Make fdt_check_header() publicGerald Van Baren
Changed _fdt_check_header() to fdt_check_header() and made it part of the interface - it is a useful routine. Also did some asthetics cleanup to the include files (headers).
2007-04-04Minor cleanup.Wolfgang Denk
2007-03-31libfdt: Enhanced and published fdt_next_tag()Gerald Van Baren
Enhanced the formerly private function _fdt_next_tag() to allow stepping through the tree, used to produce a human-readable dump, and made it part of the published interface. Also added some comments.
2007-03-31libfdt: Import libfdt source (1 of 2)Gerald Van Baren
This adds the applicable libfdt source files (unmodified) and a README to explain where the source came from.
