path: root/include/libfdt.h
2008-03-18libfdt: Add and use a node iteration helper function.David Gibson
This patch adds an fdt_next_node() function which can be used to iterate through nodes of the tree while keeping track of depth. This function is used to simplify the iteration code in a lot of other functions, and is also exported for use by library users. Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2008-03-18libfdt: Add fdt_set_name() functionDavid Gibson
This patch adds an fdt_set_name() function to libfdt, mirroring fdt_get_name(). This is a r/w function which alters the name of a given device tree node. Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2008-01-08libfdt: Add more documentation (patch the seventh)David Gibson
This patch adds more documenting comments to libfdt.h. Specifically, these document the read/write functions (not including fdt_open_into() and fdt_pack(), for now). Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2008-01-08libfdt: Add more documentation (patch the sixth)David Gibson
This patch adds some more documenting comments to libfdt.h. Specifically this documents all the write-in-place functions. Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
2008-01-02Fix compile problem introduced by "cleanup" commit 3dfd708cWolfgang Denk
2008-01-02Minor coding style cleanup.Wolfgang Denk
2007-11-21Update libfdt from device tree compiler (dtc)Kumar Gala
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from the device tree compiler (dtc) project. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-21Removed some nonused fdt functions and moved fdt_find_and_setprop out of libfdtKumar Gala
Removed: fdt_node_is_compatible fdt_find_node_by_type fdt_find_compatible_node To ease merge of newer libfdt as we aren't using them anywhere at this time. Also moved fdt_find_and_setprop out of libfdt into fdt_support.c for the same reason. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-06libfdt: add convenience function fdt_find_and_setprop()Grant Likely
Given the path to a node, fdt_find_and_setprop() allows a property value to be set directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-10Add fdt_find_node_by_type() and fdt_find_compatible_node() to LIBFDTGerald Van Baren
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2007-08-10Replace fdt_node_offset() with fdt_find_node_by_path().Gerald Van Baren
The new name matches more closely the kernel's name, which is also a much better description. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2007-04-14Add some utilities to manipulate the reserved memory map.Gerald Van Baren
2007-04-06libfdt: Make fdt_check_header() publicGerald Van Baren
Changed _fdt_check_header() to fdt_check_header() and made it part of the interface - it is a useful routine. Also did some asthetics cleanup to the include files (headers).
2007-04-04Minor cleanup.Wolfgang Denk
2007-03-31libfdt: Enhanced and published fdt_next_tag()Gerald Van Baren
Enhanced the formerly private function _fdt_next_tag() to allow stepping through the tree, used to produce a human-readable dump, and made it part of the published interface. Also added some comments.
2007-03-31libfdt: Import libfdt source (1 of 2)Gerald Van Baren
This adds the applicable libfdt source files (unmodified) and a README to explain where the source came from.
