path: root/include/led-display.h
2010-10-21led_display: remove unused DISPLAY_MARK defineIlya Yanok
DISPLAY_MARK subcommand of display_set() is not used anywhere so we can remove it safely. Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2010-10-12led_display: split led display support into generic and hw-dependent partsIlya Yanok
Split the display command into generic interface and hardware-specific realization for PDSP188x LED display found on hmi1001 and manroland boards. Simple interface for LED displays is defined in include/led-display.h and described in doc/README.LED_display. Driver-specific implementation was moved into drivers/misc/pdsp188x.c file (enabled with CONFIG_PDSP188x set). Signed-off-by: Ilya Yanok <yanok@emcraft.com>
