path: root/include/lcd_console.h
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-18common/lcd_console: introduce display/framebuffer rotationHannes Petermaier
Sometimes, for example if the display is mounted in portrait mode or even if it is mounted landscape but rotated by 180 degrees, we need to rotate our content of the display respectively the framebuffer, so that user can read the messages which are printed out. For this we introduce the feature called "CONFIG_LCD_ROTATION", this may be defined in the board-configuration if needed. After this the lcd_console will be initialized with a given rotation from "vl_rot" out of "vidinfo_t" which is provided by the board specific code. If CONFIG_LCD_ROTATION is not defined, the console will be initialized with 0 degrees rotation. Signed-off-by: Hannes Petermaier <hannes.petermaier@br-automation.com> Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at> Acked-by: Nikita Kiryanov <nikita@compulab.co.il> [agust: fixed 'struct vidinfo' has no member named 'vl_rot' errors] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2015-01-10lcd: refactor lcd console stuff into its own fileNikita Kiryanov
common/lcd.c is a mix of code portions that do different but related things. To improve modularity, the various code portions should be split into their own modules. Separate lcd console code into its own file. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Anatolij Gustschin <agust@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
