path: root/include/key_matrix.h
2017-06-01cros_ec: Update the cros_ec keyboard driver to livetreeSimon Glass
Update this driver and key_matrix to support a live device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-15input: Allow key ghosting filter to be disabledSimon Glass
Some keyboards will not need a key ghosting filter, so make this feature optional. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-05-15input: Add support for keyboard matrix decoding from an fdtBernie Thompson
Matrix keyboards require a key map to be set up, and must also deal with key ghosting. Create a keyboard matrix management implementation which can be leveraged by various keyboard drivers. This includes code to read the keymap from the FDT and perform debouncing. Signed-off-by: Bernie Thompson <bhthompson@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
