path: root/include/kendryte/bypass.h
2020-08-03clk: Drop dm.h header file in clk-provider.hSimon Glass
This header file should not be included in other header files. Remove it and use a forward declaration and un-inlining of dev_get_clk_ptr() instead. Fix up the kendryte header files to avoid build errors. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Sean Anderson <seanga2@gmail.com>
2020-07-01clk: Add a bypass clock for K210Sean Anderson
This is a small driver to do a software bypass of a clock if hardware bypass is not working. I have tried to write this in a generic fashion, so that it could be potentially broken out of the kendryte code at some future date. For the K210, it is used to have aclk bypass pll0 and use in0 instead so that the CPU keeps on working. Signed-off-by: Sean Anderson <seanga2@gmail.com> CC: Lukasz Majewski <lukma@denx.de>
