path: root/include/jffs2/load_kernel.h
2018-09-20cmd: mtdparts: accept spi-nand devicesMiquel Raynal
Let spi-nand devices be recognized by mtdparts. This is superfluous but a full mtdparts rework would be very time-consuming. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Acked-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> Reviewed-by: Stefan Roese <sr@denx.de>
2013-10-09cmd_mtdparts: use 64 bits for flash size, partition size & offsetPaul Burton
This matches the 64 bit size in struct mtd_info and allows the mtdparts command to function correctly with a flash >= 4GiB. Format specifiers for size & offset are given the ll length, matching its use in drivers/mtd in absence of something like inttypes.h/PRIx64. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Stefan Roese <sr@denx.de>
2010-03-21fdt_support: add partitions fixup in mtd nodeAnatolij Gustschin
Allow overwriting defined partitions in the device tree blob using partition info defined in the 'mtdparts' environment variable. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Gerald Van Baren <vanbaren@cideas.com>
2008-12-09jffs2: add sector_size field to part_info structureIlya Yanok
This patch adds sector_size field to part_info structure (used by new JFFS2 code). Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2008-11-19UBI: Add basic UBI support to U-Boot (Part 6/8)Kyungmin Park
This patch adds basic UBI (Unsorted Block Image) support to U-Boot. It's based on the Linux UBI version and basically has a "OS" translation wrapper that defines most Linux specific calls (spin_lock() etc.) into no-ops. Some source code parts have been uncommented by "#ifdef UBI_LINUX". This makes it easier to compare this version with the Linux version and simplifies future UBI ports/bug-fixes from the Linux version. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-06Add JFFS2 command support on OneNANDKyungmin Park
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
