Sphinx expects Return: and not @return to indicate a return value.
find . -name '*.c' -exec \
sed -i 's/^\(\s\)\*\(\s*\)@return\(\s\)/\1*\2Return:\3/' {} \;
find . -name '*.h' -exec \
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
The write functions do actually change the contents of memory so it is not
correct to use 'const'. Remove it.
Don't continue updating the offset when buffer is full.
When the buffer size exhausts and there's no space left to write
warn the user and update only the needed size and not both the
offset and needed size.
Add needed buffer size information in the iotrace command.
Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
The header definitions are needed for reading
record information in cmd/iotrace.c
When dealing with a lot of IO regions, sometimes
it makes sense only to trace a specific one.
This patch adds support for region limits.
If region is not set, the iotrace works the same as it was.
If region is set, the iotrace only logs io operation that falls
in the defined region.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
If an address is used with readb() and writeb() which is smaller than the
expected size (e.g. 32-bit value on a machine with 64-bit addresses), a
warning results. Fix this by adding a cast.
When debugging drivers it is useful to see what I/O accesses were done
and in what order.
Even if the individual accesses are of little interest it can be useful to
verify that the access pattern is consistent each time an operation is
performed. In this case a checksum can be used to characterise the operation
of a driver. The checksum can be compared across different runs of the
operation to verify that the driver is working properly.
In particular, when performing major refactoring of the driver, where the
access pattern should not change, the checksum provides assurance that the
refactoring work has not broken the driver.
Add an I/O tracing feature and associated commands to provide this facility.
It works by sneaking into the io.h heder for an architecture and redirecting
I/O accesses through its tracing mechanism.
For now no commands are provided to examine the trace buffer. The format is
fairly simple, so 'md' is a reasonable substitute.
Note: The checksum feature is only useful for I/O regions where the contents
do not change outside of software control. Where this is not suitable you can
fall back to manually comparing the addresses. It might be useful to enhance
tracing to only checksum the accesses and not the data read/written.
