path: root/include/iomux.h
2010-11-28stdio: constify "name" arg in public apiMike Frysinger
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-07IOMUX: Add console multiplexing support.Gary Jennejohn
Modifications to support console multiplexing. This is controlled using CONFIG_SYS_CONSOLE_MUX in the board configuration file. This allows a user to specify multiple console devices in the environment with a command like this: setenv stdin serial,nc. As a result, the user can enter text on both the serial and netconsole interfaces. All devices - stdin, stdout and stderr - can be set in this manner. 1) common/iomux.c and include/iomux.h contain the environment setting implementation. 2) doc/README.iomux contains a somewhat more detailed description. 3) The implementation in (1) is called from common/cmd_nvedit.c to handle setenv and from common/console.c to handle initialization of input/output devices at boot time. 4) common/console.c also contains the code needed to poll multiple console devices for input and send output to all devices registered for output. 5) include/common.h includes iomux.h and common/Makefile generates iomux.o when CONFIG_SYS_CONSOLE_MUX is set. Signed-off-by: Gary Jennejohn <garyj@denx.de>
