path: root/include/image.h
2020-05-18command: Remove the cmd_tbl_t typedefSimon Glass
We should not use typedefs in U-Boot. They cannot be used as forward declarations which means that header files must include the full header to access them. Drop the typedef and rename the struct to remove the _s suffix which is now not useful. This requires quite a few header-file additions. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-04-17image: Add a common compression type detection function.Atish Patra
Currently, there is no method that can detect compression types given a file. This is very useful where a compressed kernel image is loaded directly to the memory. Inspect initial few bytes to figure out compression type of the image. It will be used in booti method for now but can be reused any other function in future as well. Signed-off-by: Atish Patra <atish.patra@wdc.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-04-07Merge tag 'xilinx-for-v2020.07' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-microblaze into next Xilinx changes for v2020.07 common: - Align ENV_FAT_INTERFACE - Fix MAC address source print log - Improve based autodetection code xilinx: - Enable netconsole Microblaze: - Setup default ENV_OFFSET/ENV_SECT_SIZE Zynq: - Multiple DT updates/fixes - Use DEVICE_TREE environment variable for DTB selection - Switch to single zynq configuration - Enable NOR flash via DM - Minor SPL print removal - Enable i2c mux driver ZynqMP: - Print multiboot register - Enable cache commands in mini mtest - Multiple DT updates/fixes - Fix firmware probing when driver is not enabled - Specify 3rd backup RAM boot mode in SPL - Add SPL support for zcu102 v1.1 and zcu111 revA - Redesign debug uart enabling and psu_init delay - Enable full u-boot run from EL3 - Enable u-boot.itb generation without ATF with U-Boot in EL3 Versal: - Enable distro default - Enable others SPI flashes - Enable systems without DDR Drivers: - Gem: - Flush memory after freeing - Handle mdio bus separately - Watchdog: - Get rid of unused global data pointer - Enable window watchdog timer - Serial: - Change reinitialization logic in zynq serial driver Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-01image: Use constants for 'required' and 'key-name-hint'Simon Glass
These are used in multiple places so update them to use a shared #define. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philippe Reynes <philippe.reynes@softathome.com>
2020-04-01image: Correct comment for fit_conf_get_node()Simon Glass
This should mention that conf_uname can be NULL and should be in the header file. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-03-12include: image.h: add key info to image_sign_infoAKASHI Takahiro
For FIT verification, all the properties of a public key come from "control fdt" pointed to by fdt_blob. In UEFI secure boot, on the other hand, a public key is located and retrieved from dedicated signature database stored as UEFI variables. Added two fields may hold values of a public key if fdt_blob is NULL, and will be used in rsa_verify_with_pkey() to verify a signature in UEFI sub-system. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-03-12lib: rsa: decouple rsa from FIT image verificationAKASHI Takahiro
Introduce new configuration, CONFIG_RSA_VERIFY which will decouple building RSA functions from FIT verification and allow for adding a RSA-based signature verification for other file formats, in particular PE file for UEFI secure boot. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-03-12image.h: isolate android_image_* functions from toolingEugeniu Rosca
On Feb. 16, 2020, Tom reported [1] build failure of U-Boot in-tree tooling after applying https://patchwork.ozlabs.org/cover/1229663/ ("[v6,0/7] rsa: extend rsa_verify() for UEFI secure boot"). Later on, Heinrich stressed the urgency of the issue in https://patchwork.ozlabs.org/patch/1250858/#2379069: >>>>>>>>> We should finalize the topic as it stops EFI patches from being merged >>>>>>>>> On the surface, the problem is caused by U-Boot commits [2-3], which employed 'u32' in 'include/image.h', while historically U-Boot tooling stayed agnostic on the {u,s}{8,16,32} types. Thanks to Tom, Yamada-san and Heinrich, the following solutions have been put head-to-head ('+' pros, '-' cons): A. Use an equivalent fixed-size type, i.e. s/u32/uint32_t/ in both android function prototypes (image.h) and definitions (c file): + quick and low-line-count - creates a 'soup' of fixed-sized types in the Android C file - will confuse contributors - is going against Linux kernel best practices [4] B. Guard Android functions by '!defined(USE_HOSTCC)' in image.h: + quick and low-line-count + reflects the reality (no android function is used by tooling) + zero impact on other subsystems - ifdeffery may look annoying (pre-existing problem of image.h) C. Make {u8,u16,u32} available in U-Boot tooling: + quick and low-line-count + [Yamada-san][5]: * forbidding u32 for tools is questionable to me * Linux kernel and Barebox use {u8,u16,u32} for the tools space - breaks U-Boot tradition? - has larger impact than [A] and [B] - adds type complexity/inconsistency in the tooling space D. [Yamada-san] Refactor the headers to minimize the code shared between U-Boot space and tooling space: + probably the long-term solution - high effort - can be seen/done as an incremental update on top of [B] Looking at the above, [B] looks like the natural way to go forward. [1] https://patchwork.ozlabs.org/patch/1238245/#2363052 [2] commit 7f2531502c74c0 ("image: android: Add routine to get dtbo params") [3] commit c3bfad825a71ea ("image: android: Add functions for handling dtb field") [4] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?id=e6176fa4728fb6d ("checkpatch: add --strict warning for c99 fixed size typedefs : int<size>_t") [5] https://patchwork.ozlabs.org/patch/1238245/#2363340 Cc: Masahiro Yamada <masahiroy@kernel.org> Cc: Heinrich Schuchardt <xypron.glpk@gmx.de> Cc: Sam Protsenko <joe.skb7@gmail.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: AKASHI Takahiro <takahiro.akashi@linaro.org> Reported-by: Tom Rini <trini@konsulko.com> Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Tested-by: Heinrich Schuchardt <xpyron.glpk@gmx.de>
2020-02-04image: android: Add routine to get dtbo paramsSam Protsenko
Android Boot Image v1 adds "Recovery DTB" field in image header and associate payload in boot image itself [1]. Payload should be in Android DTB/DTBO format [2]. That "Recovery DTB" area should be only populated for non-A/B devices, and only in recovery image. Add function to get an address and size of that payload. That function can be further used e.g. in 'abootimg' command to provide the user a way to get the address of recovery dtbo from U-Boot shell, which can be further parsed using 'adtimg' command. [1] https://source.android.com/devices/bootloader/boot-image-header [2] https://source.android.com/devices/architecture/dto/partitions Signed-off-by: Sam Protsenko <joe.skb7@gmail.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-02-04image: android: Add functions for handling dtb fieldSam Protsenko
Android Boot Image v2 adds "DTB" payload (and corresponding field in the image header). Provide functions for its handling: - android_image_get_dtb_by_index(): Obtain DTB blob from "DTB" part of boot image, by blob's index - android_image_print_dtb_contents(): Iterate over all DTB blobs in "DTB" part of boot image and print those blobs info "DTB" payload might be in one of the following formats: 1. concatenated DTB blobs 2. Android DTBO format The latter requires "android-image-dt.c" functionality, so this commit selects that file for building for CONFIG_ANDROID_BOOT_IMAGE option. Right now this new functionality isn't used, but it can be used further. As it's required to apply some specific dtbo blob(s) from "dtbo" partition, we can't automate this process inside of "bootm" command. But we can do next: - come up with some new command like "abootimg" to extract dtb blob from boot image (using functions from this patch) - extract desired dtbo blobs from "dtbo" partition using "adtimg" command - merge dtbo blobs into dtb blob using "fdt apply" command - pass resulting dtb blob into bootm command in order to boot the Android kernel with Android ramdisk from boot image Signed-off-by: Sam Protsenko <joe.skb7@gmail.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2020-01-17common: Rename and move source()Simon Glass
This function has a very generic name which does not adequately describe its purpose. Rename it and move it to image.h, since it relates to reading a script from an image. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Move the image globals into image.hSimon Glass
These three globals relate to image handling. Move them to the image header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17u-boot: fit: add support to decrypt fit with aesPhilippe Reynes
This commit add to u-boot the support to decrypt fit image encrypted with aes. The FIT image contains the key name and the IV name. Then u-boot look for the key and IV in his device tree and decrypt images before moving to the next stage. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2020-01-17mkimage: fit: add support to encrypt image with aesPhilippe Reynes
This commit add the support of encrypting image with aes in mkimage. To enable the ciphering, a node cipher with a reference to a key and IV (Initialization Vector) must be added to the its file. Then mkimage add the encrypted image to the FIT and add the key and IV to the u-boot device tree. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2020-01-07image: Add IH_OS_EFI for EFI chain-load bootCristian Ciocaltea
Add a new OS type to be used for chain-loading an EFI compatible firmware or boot loader like GRUB2, possibly in a verified boot scenario. Bellow is sample ITS file that generates a FIT image supporting secure boot. Please note the presence of 'os = "efi";' line, which identifies the currently introduced OS type: / { #address-cells = <1>; images { efi-grub { description = "GRUB EFI"; data = /incbin/("bootarm.efi"); type = "kernel_noload"; arch = "arm"; os = "efi"; compression = "none"; load = <0x0>; entry = <0x0>; hash-1 { algo = "sha256"; }; }; }; configurations { default = "config-grub"; config-grub { kernel = "efi-grub"; signature-1 { algo = "sha256,rsa2048"; sign-images = "kernel"; }; }; }; }; Signed-off-by: Cristian Ciocaltea <cristian.ciocaltea@gmail.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-10-28tools: image.h: Use portable uint32_t instead of linux-specific __be32Bin Meng
__be32 has Linux kernel specific __attribute__((bitwise)) which is not portable. Use uint32_t instead. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-27image: add new "copro" image typePatrick Delaunay
Define new image type for coprocessor images. It is used in FIT to identify the files loaded with remoteproc command (elf or bin). Signed-off-by: Loic Pallardy <loic.pallardy@st.com> Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-08-26spl: support booting via RISC-V OpenSBILukas Auer
RISC-V OpenSBI is an open-source implementation of the RISC-V Supervisor Binary Interface (SBI) specification. It is required by Linux and U-Boot running in supervisor mode. This patch adds support for booting via the OpenSBI FW_DYNAMIC firmware. It supports OpenSBI version 0.4 and higher. In this configuration, U-Boot SPL starts in machine mode. After loading OpenSBI and U-Boot proper, it will start OpenSBI. All necessary parameters are generated by U-Boot SPL and are passed to OpenSBI. U-Boot proper is started in supervisor mode by OpenSBI. Support for OpenSBI is enabled with CONFIG_SPL_OPENSBI. An additional configuration entry, CONFIG_SPL_OPENSBI_LOAD_ADDR, is used to specify the load address of the OpenSBI firmware binary. It is not used directly in U-Boot and instead is intended to make the value available to scripts such as FIT configuration generators. The header file include/opensbi.h is based on header files from the OpenSBI project. They are recent, as of commit bae54f764570 ("firmware: Add fw_dynamic firmware"). Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Anup Patel <anup.patel@wdc.com>
2019-07-29common: Move bootm_decomp_image() to image.c (as image_decomp())Julius Werner
Upcoming patches want to add decompression to use cases that are no longer directly related to booting. It makes sense to retain a single decompression routine, but it should no longer be in bootm.c (which is not compiled for all configurations). This patch moves bootm_decomp_image() to image.c and renames it to image_decomp() in preparation of those upcoming patches. Signed-off-by: Julius Werner <jwerner@chromium.org> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fix warning around handle_decomp_error being unused] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-11configs: Rename CONFIG_IMAGE_FORMAT_LEGACY to CONFIG_LEGACY_IMAGE_FORMATTom Rini
The name CONFIG_LEGACY_IMAGE_FORMAT reads slightly better along with allowing us to avoid a rather nasty Kbuild/Kconfig issue down the line with CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY). In a few places outside of cmd/ switch to using CONFIG_IS_ENABLED() to test what is set. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-10ARM: socfpga: Add FPGA drivers for Arria 10 FPGA bitstream loadingTien Fong Chee
Add FPGA driver to support program FPGA with FPGA bitstream loading from filesystem. The driver are designed based on generic firmware loader framework. The driver can handle FPGA program operation from loading FPGA bitstream in flash to memory and then to program FPGA. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
2019-05-10Remove #define CONFIG_CRC32Chris Packham
There is no check for CONFIG_CRC32 so the #define in image.h does nothing. Remove it. Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2019-05-05Refactor IMAGE_ENABLE_VERIFY to handle builds without SPL verificationAlex Kiernan
If building with SPL_LOAD_FIT_FULL and FIT_SIGNATURE, but without SPL_FIT_SIGNATURE then the build fails with: common/built-in.o: In function `fit_image_verify_with_data': common/image-fit.c:1220: undefined reference to `fit_image_verify_required_sigs' common/image-fit.c:1244: undefined reference to `fit_image_check_sig' common/built-in.o: In function `fit_image_load': common/image-fit.c:1857: undefined reference to `fit_config_verify' Refactor so that host builds still depend on FIT_SIGNATURE, but target builds check FIT_SIGNATURE/SPL_FIT_SIGNATURE dependent on the build. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-04-24image: android: allow booting lz4-compressed kernelsEugeniu Rosca
According to Android image format [1], kernel image resides at 1 page offset from the boot image address. Grab the magic number from there and allow U-Boot to handle LZ4-compressed KNL binaries instead of hardcoding compression type to IH_COMP_NONE. Other compression types, if needed, can be added later. Tested on H3ULCB-KF using the image detailed in [2]. [1] Excerpt from include/android_image.h +-----------------+ | boot header | 1 page +-----------------+ | kernel | n pages +-----------------+ | ramdisk | m pages +-----------------+ | second stage | o pages +-----------------+ [2] => iminfo 4c000000 ## Checking Image at 4c000000 ... Android image found kernel size: 85b9d1 kernel address: 48080000 ramdisk size: 54ddbc ramdisk addrress: 4a180000 second size: 0 second address: 48000800 tags address: 48000100 page size: 800 os_version: 1200012a (ver: 0.9.0, level: 2018.10) name: cmdline: buildvariant=userdebug Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
2018-12-17Restore compatibility of image type IDsStefano Babic
Commit a2b96ece5be146f4995d737f047e5bbb76079b8f breaks the enumeration of the Image Types. New image types can be appended, but they cannot be inserted in the list else backward compatibility is broken. This restores the images types as before 2018.11 and move i.MX8 related images at the end. Signed-off-by: Robert Berger <robert.berger@ReliableEmbeddedSystems.com> Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <trini@konsulko.com>
2018-12-03rsa: add support of padding pssPhilippe Reynes
We add the support of the padding pss for rsa signature. This new padding is often recommended instead of pkcs-1.5. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-03rsa: add a structure for the paddingPhilippe Reynes
The rsa signature use a padding algorithm. By default, we use the padding pkcs-1.5. In order to add some new padding algorithm, we add a padding framework to manage several padding algorithm. The choice of the padding is done in the file .its. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-28tools: MediaTek: add MTK boot header generation to mkimageRyder Lee
This patch adds support for MTK boot image generation. Signed-off-by: Weijie Gao <weijie.gao@mediatek.com> Signed-off-by: Ryder Lee <ryder.lee@mediatek.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-22tools: add i.MX8/8X image supportPeng Fan
i.MX8/8X bootable image type is container type. The bootable image, containers a container set which supports two container. The 1st container is for SECO firmware, the 2nd container needs to include scfw, m4_0/1 image, ACore images per your requirement. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-07-10mkimage: fit_image: Add support for SOURCE_DATE_EPOCH in signaturesAlex Kiernan
When generating timestamps in signatures, use imagetool_get_source_date() so we can be overridden by SOURCE_DATE_EPOCH to generate reproducible images. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromum.org>
2018-06-19ARM: image: Add option for ignoring ep bit 3Marek Vasut
Add option to the booti_setup() which indicates to it that the caller requires the image to be relocated to the beginning of the RAM and that the information whether the image can be located anywhere in RAM at 2 MiB aligned boundary or not is to be ignored. This is useful ie. in case the Image is wrapped in another envelope, ie. fitImage and not relocating it but moving it would corrupt the envelope. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Bin Chen <bin.chen@linaro.org> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-By: Bin Chen <bin.chen@linaro.org>
2018-05-26add FIT data-position & data-offset property supportKelvin Cheung
Add FIT data-position & data-offset property support for bootm, which were already supported in SPL. Signed-off-by: Kelvin Cheung <keguang.zhang@gmail.com>
2018-05-23fit: Add standalone image type handlingMarek Vasut
Just add IH_TYPE_STANDALONE to fit_get_image_type_property(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-23FIT: Make fit_conf_print() be a static functionTom Rini
We only call fit_conf_print from one place in the code, so mark it as static and move it up to where we call it. This in turn has us move a few other already static functions up further as well. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-11Merge tag 'xilinx-for-v2018.07' of git://www.denx.de/git/u-boot-microblazeTom Rini
Xilinx changes for v2018.07 microblaze: - Align defconfig zynq: - Rework fpga initialization and cpuinfo handling zynqmp: - Add ZynqMP R5 support - Wire and enable watchdog on zcu100-revC - Setup MMU map for DDR at run time - Show board info based on DT and cleanup IDENT_STRING zynqmp tools: - Add read partition support - Add initial support for Xilinx bif format for boot.bin generation mmc: - Fix get_timer usage on 64bit cpus - Add support for SD3.0 UHS mode nand-zynq: - Add support for 16bit buswidth - Use address cycles from onfi params scsi: - convert ceva sata to UCLASS_AHCI timer: - Add Cadence TTC for ZynqMP r5 watchdog: - Minor cadence driver cleanup
2018-05-11tools: zynqmpimage: Add bif supportAlexander Graf
The officially described way to generate boot.bin files for ZynqMP is to describe the contents of the target binary using a file of the "bif" format. This file then links to other files that all get packed into a bootable image. This patch adds support to read such a .bif file and generate a respective ZynqMP boot.bin file that can include the normal image and pmu files, but also supports image partitions now. This makes it a handy replacement for the proprietary "bootgen" utility that is currently used to generate boot.bin files with FSBL. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-05-08image: socfpga: Add SFP image version 1 definitionMarek Vasut
Add support for the SoCFPGA header v1, which is used on Arria 10. The layout of the v0 and v1 header is similar, yet there are a few differences which make it incompatible with previous v0 header, so add a new entry. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@kernel.org> Cc: Chin Liang See <chin.liang.see@intel.com>
2018-04-06image: fit: Show firmware configuration property if presentMichal Simek
SPL ATF support requires to have firmware property which should be also listed by mkimage -l when images is created. The patch is also using this macro in spl_fit to match keyword. When image is created: Default Configuration: 'config' Configuration 0 (config) Description: ATF with full u-boot Kernel: unavailable Firmware: atf FDT: dtb Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jun Nie <jun.nie@linaro.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-04-01image.h: add forward declaration of struct fdt_regionMasahiro Yamada
This header needs to know 'fdt_region' is a struct for the fit_region_make_list() prototype. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-03-19image: Add IH_OS_TEE for TEE chain-load bootBryan O'Donoghue
This patch adds a new type IH_OS_TEE. This new OS type will be used for chain-loading to Linux via a TEE. With this patch in-place you can generate a bootable OPTEE image like this: mkimage -A arm -T kernel -O tee -C none -d tee.bin uTee.optee where "tee.bin" is the input binary prefixed with an OPTEE header and uTee.optee is the output prefixed with a u-boot wrapper header. This image type "-T kernel -O tee" is differentiated from the existing IH_TYPE_TEE "-T tee" in that the IH_TYPE is installed by u-boot (flow control returns to u-boot) whereas for the new IH_OS_TEE control passes to the OPTEE firmware and the firmware chainloads onto Linux. Andrew Davis gave the following ASCII diagram: IH_OS_TEE: (mkimage -T kernel -O tee) Non-Secure Secure BootROM | ------------- | v SPL | v U-Boot ------> <----- OP-TEE | V Linux IH_TYPE_TEE: (mkimage -T tee) Non-Secure Secure BootROM | ------------- | v SPL -------> <----- OP-TEE | v U-Boot | V Linux Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Suggested-by: Andrew F. Davis <afd@ti.com> Cc: Harinarayan Bhatta <harinarayan@ti.com> Cc: Andrew F. Davis <afd@ti.com> Cc: Tom Rini <trini@konsulko.com> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Peng Fan <peng.fan@nxp.com> Link: http://mrvan.github.io/optee-imx6ul
2018-03-19tools/mkimage: add support for STM32 image formatPatrick Delaunay
STM32MP157 bootrom needs a specific header for first boot stage. This patch adds support of this header in mkimage. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-03-19SPL: Add signature verification when loading imageJun Nie
U-boot proper signature is not verified by SPL on most platforms even config SPL_FIT_SIGNATURE is enabled. Only fsl-layerscape platform support secure boot in platform specific code. So verified boot cannot be achieved if u-boot proper is loaded by SPL. This patch add signature verification to u-boot proper images when loading FIT image in SPL. It is tested on Allwinner bananapi zero board with H2+ SoC. Signed-off-by: Jun Nie <jun.nie@linaro.org>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-07move booti_setup to arch/arm/lig/image.cBin Chen
Follow bootz's pattern by moving the booti_setup to arch/arm/lib. This allows to use booti_setup in other paths, e.g booting an Android image containing Image format. Note that kernel relocation is move out of booti_setup and it is the caller's responsibility to do it and allows them do it differently. say, cmd/booti.c just do a manually, while in the bootm path, we can use bootm_load_os(with some changes). Signed-off-by: Bin Chen <bin.chen@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-02-07parse the second area of android imageBin Chen
The second area of android image was intended to put a 2nd stage bootloader but in practice were rarely used (in my knowledge). An proposal was made to the AOSP to (re)use the second area as the dtb[1], This patch itself doesn't depend on that proposal being accepted but it won't be that helpful as well if that proposal won't be accepted. But don't do any harm as well. [1] https://android-review.googlesource.com/#/c/417447/ Signed-off-by: Bin Chen <bin.chen@linaro.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2018-01-15fix incorrect usage of DT node unit address in commentsAndre Przywara
The DT spec demands a unit-address in a node name to match the "reg" property in that node. Newer dtc versions will throw warnings if this is not the case. Fix all occurences in the tree where node names were mentioned in comments, to not give bad examples to the reader. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2018-01-12riscv: Modify generic codes to support RISC-VRick Chen
Support common commands bdinfo and image format, also modify common generic flow for RISC-V. Signed-off-by: Rick Chen <rick@andestech.com> Signed-off-by: Rick Chen <rickchen36@gmail.com> Signed-off-by: Greentime Hu <green.hu@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-12-12SPL: Add FIT data-position property supportPeng Fan
For external data, FIT has a optional property "data-position" which can set the external data to a fixed offset to FIT beginning. Add the support for this property in SPL FIT. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tomas Melin <tomas.melin@vaisala.com> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: "tomas.melin@vaisala.com" <tomas.melin@vaisala.com> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: York Sun <york.sun@nxp.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: "Cooper Jr., Franklin" <fcooper@ti.com> Cc: George McCollister <george.mccollister@gmail.com> Cc: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Cc: Jean-Jacques Hiblot <jjhiblot@ti.com> Cc: Rick Altherr <raltherr@google.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-11-26image: add IH_OS_ARM_TRUSTED_FIRMWARE for ARM Trusted FirmwarePhilipp Tomsich
To boot on ARMv8 systems with ARM Trusted Firmware, we need to assemble an ATF-specific parameter structure and also provide the address of the images started by ATF (e.g. BL3-3, which may be the full U-Boot). To allow us to identify an ARM Trusted Firmware contained in a FIT image, this adds the necessary definitions. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
