path: root/include/image.h
2013-08-31ARM: mxs: tools: Add mkimage support for MXS bootstreamMarek Vasut
Add mkimage support for generating and verifying MXS bootstream. The implementation here is mostly a glue code between MXSSB v0.4 and mkimage, but the long-term goal is to rectify this and merge MXSSB with mkimage more tightly. Once this code is properly in U-Boot, MXSSB shall be deprecated in favor of mkimage-mxsimage support. Note that the mxsimage generator needs libcrypto from OpenSSL, I therefore enabled the libcrypto/libssl unconditionally. MXSSB: http://git.denx.de/?p=mxssb.git;a=summary The code is based on research presented at: http://www.rockbox.org/wiki/SbFileFormat Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br>
2013-07-12bootm: Use selected configuration for ramdisk and fdtSimon Glass
If a specific configuraion is selected by the bootm command, e.g. with 'bootm 84000000#recoveryconf' we must honour this for not just the kernel, but also the ramdisk and FDT. In the conversion to using a common fit_image_load() function for loading images from FITs (commits a51ec63 and 53f375f) this feature was lost. Reinstate it by passing the selected configuration back from fit_image_load() to boot_get_kernel(), then use this configuration (which is stored in images->fit_uname_cfg) in both boot_get_ramdisk() and boot_get_fdt(). Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-10bootm: Clean up bootz_setup() functionSimon Glass
This function has no prototype in the headers and passes void * around, thus requiring several casts. Tidy this up. - Add new patch to clean up bootz_setup() function Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-28mkimage: Build signing only if board has CONFIG_FIT_SIGNATURESimon Glass
At present mkimage is set up to always build with image signing support. This means that the SSL libraries (e.g. libssl-dev) are always required. Adjust things so that mkimage can be built with and without image signing, controlled by the presence of CONFIG_FIT_SIGNATURE in the board config file. If CONFIG_FIT_SIGNATURE is not enabled, then mkimage will report a warning that signing is not supported. If the option is enabled, but libraries are not available, then a build error similar to this will be shown: lib/rsa/rsa-sign.c:26:25: fatal error: openssl/rsa.h: No such file or directory Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add support for signing of FIT configurationsSimon Glass
While signing images is useful, it does not provide complete protection against several types of attack. For example, it it possible to create a FIT with the same signed images, but with the configuration changed such that a different one is selected (mix and match attack). It is also possible to substitute a signed image from an older FIT version into a newer FIT (roll-back attack). Add support for signing of FIT configurations using the libfdt's region support. Please see doc/uImage.FIT/signature.txt for more information. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Support signing of imagesSimon Glass
Add support for signing images using a new signature node. The process is handled by fdt_add_verification_data() which now takes parameters to provide the keys and related information. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add signing infrastructureSimon Glass
Add a structure to describe an algorithm which can sign and (later) verify images. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Add a 'fake' go command to the bootm commandSimon Glass
For tracing it is useful to run as much of U-Boot as possible so as to get a complete picture. Quite a bit of work happens in bootm, and we don't want to have to stop tracing before bootm starts. Add a way of doing a 'fake' boot of the OS - which does everything up to the point where U-Boot is about to jump to the OS image. This allows tracing to record right until the end. This requires arch support to work. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Refactor the bootm command to reduce code duplicationSimon Glass
At present the bootm code is mostly duplicated for the plain 'bootm' command and its sub-command variant. This makes the code harder to maintain and means that changes must be made to several places. Introduce do_bootm_states() which performs selected portions of the bootm work, so that both plain 'bootm' and 'bootm <sub_command>' can use the same code. Additional duplication exists in bootz, so tidy that up as well. This is not intended to change behaviour, apart from minor fixes where the previously-duplicated code missed some chunks of code. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-04image: Use fit_image_load() to load kernelSimon Glass
Use the new common code to load a kernel. The functionality should not change. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-04image: Use fit_image_load() to load FDTSimon Glass
Use the new common code to load a flat device tree. Also fix up a few casts so that this code works with sandbox. Other than that the functionality should not change. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-04image: Use fit_image_load() to load ramdiskSimon Glass
Use the new common code to load a ramdisk. The functionality should not change. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-04image: Introduce fit_image_load() to load images from FITsSimon Glass
At present code to load an image from a FIT is duplicated in the three places where it is needed (kernel, fdt, ramdisk). The differences between these different code copies is fairly minor. Create a new function in the fit code which can handle any of the requirements of those cases. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14image: Add device tree setup to image librarySimon Glass
This seems to be a common function for several architectures, so create a common function rather than duplicating the code in each arch. Also make an attempt to avoid introducing #ifdefs in the new code, partly by removing useless #ifdefs around function declarations in the image.h header. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14image: Add CONFIG_FIT_SPL_PRINT to control FIT image printing in SPLSimon Glass
This code is very large, and in SPL it isn't always useful to print out image information (in fact there might not even be a console active). So disable this feature unless this option is set. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14image: Remove remaining #ifdefs in image-fit.cSimon Glass
There are only two left. One is unnecessary and the other can be moved to the header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14sandbox: image: Add support for booting images in sandboxSimon Glass
Much of the image code uses addresses as ulongs and pointers interchangeably, casting between the two forms as needed. This doesn't work with sandbox, which has a U-Boot RAM buffer which is separate from the host machine's memory. Adjust the cost so that translating from a U-Boot address to a pointer uses map_sysmem(). This allows bootm to work correctly on sandbox. Note that there are no exhaustive tests for this code on sandbox, so it is possible that some dark corners remain. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de> (v1)
2013-05-14image: Rename hash printing to fit_image_print_verification_data()Simon Glass
This function will be used to print signatures as well as hashes, so rename it. Also make it static since it is not used outside this file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-05-14image: Rename fit_add_hashes() to fit_add_verification_data()Simon Glass
We intend to add signatures to FITs also, so rename this function so that it is not specific to hashing. Also rename fit_image_set_hashes() and make it static since it is not used outside this file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-05-14image: Export fit_conf_get_prop_node()Simon Glass
This function will be needed by signature checking code, so export it, and also add docs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-14image: Move hash checking into its own functionSimon Glass
The existing function is long and most of the code is indented a long way. Before adding yet more code, split this out into its own function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de> (v1)
2013-05-14image: Rename fit_image_check_hashes() to fit_image_verify()Simon Glass
This is the main entry point to the FIT image verification code. We will be using it to handle image verification with signatures, so rename the function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-05-14image: Convert fit_image_hash_set_value() to static, and renameSimon Glass
This function doesn't need to be exported, and with verification we want to use it for setting the 'value' property in any node, so rename it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-05-14image: Move HOSTCC image code to tools/Simon Glass
This code is never compiled into U-Boot, so move it into a separate file in tools/ to avoid the large #ifdef. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-05-14image: Export fit_check_ramdisk()Simon Glass
One we split out the FIT code from image.c we will need this function. Export it in the header. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2013-05-14image: Move timestamp #ifdefs to header fileSimon Glass
Rather than repeat the line #if defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) || \ defined(USE_HOSTCC) everywhere, put this in a header file and #define IMAGE_ENABLE_TIMESTAMP to either 1 or 0. Then we can use a plain if() in most code and avoid the #ifdefs. The compiler's dead code elimination ensures that the result is the same. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2013-03-27image: Add support for Plan 9Steven Stallion
Signed-off-by: Steven Stallion <sstallion@gmail.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-07treewide: include libfdt_env.h before fdt.hKim Phillips
and, if including libfdt.h which includes libfdt_env.h in the correct order, don't include fdt.h before libfdt.h. this is needed to get the fdt type definitions set from the project environment before fdt.h uses them. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2013-01-08Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-01-05tools: imximage: Load a size that is multiple of 512Fabio Estevam
In order to mx53 ROM to properly load the U-boot image, its header size should be multiple of 512 bytes. This issue was observed with gcc 4.6.2/4.7.3, which caused data aborts: U-Boot 2013.01-rc2-00172-gf8cfcf1-dirty (Dec 26 2012 - 13:13:28) Board: MX53 LOCO I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial Out: serial Err: serial CPU: Freescale i.MX53 family rev2.1 at 1000 MHz Reset cause: WDOG Net: FEC Warning: FEC using MAC address from net device Hit any key to stop autoboot: 0 data abort MAYBE you should read doc/README.arm-unaligned-accesses pc : [<aff72220>] lr : [<aff721fc>] sp : af565e20 ip : af566918 fp : 00000000 r10: 00000003 r9 : affabb5b r8 : af565f58 r7 : 00000000 r6 : 36747fff r5 : af5668e8 r4 : 36747fff r3 : af5668ec r2 : af5668eb r1 : 00000000 r0 : af5668e8 Flags: NzcV IRQs off FIQs off Mode SVC_32 Resetting CPU ... resetting ... ,and this patch fixes it. Also, even though the ROUND macro is already defined in common.h, the reason for redefining it in image.h is explained by Stefano Babic: "I will remark a previous comment - even if including common.h seems a good idea to avoid duplications, it makes tools like mkimage to depend on the selected board, because <board>_config must run. Even if this is not a problem for us u-boot developers, it becomes an issue when these tools are included in distros (like u-boot-tools in Ubuntu) and cannot be packaged." Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-12-13env: Use getenv_yesno() more generallyJoe Hershberger
Move the getenv_yesno() to env_common.c and change most checks for 'y' or 'n' to use this helper. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-11-12fdt: Add option to default to most compatible conf in a fit imageGabe Black
When booting a fit image with multiple configurations, the user either has to specify which configuration to use explicitly, or there has to be a default defined which is chosen automatically. This change adds an option to change that behavior so that a configuration can be selected explicitly, or the configuration which has the device tree that claims to be compatible with the earliest item in U-Boot's device tree. In other words, if U-Boot claimed to be compatible with A, B, and then C, and the configurations claimed to be compatible with A, D and B, D and D, E, the first configuration, A, D, would be chosen. Both the first and second configurations match, but the first one matches a more specific entry in U-Boot's device tree. The order in the kernel's device tree is ignored. Signed-off-by: Gabe Black <gabeblack@google.com> Commit-Ready: Gabe Black <gabeblack@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-11-04include/image.h: sparse fixesKim Phillips
include/image.h:378:1: warning: cast to restricted __be32 include/image.h:381:1: warning: cast to restricted __be32 include/image.h:382:1: warning: cast to restricted __be32 include/image.h:383:1: warning: cast to restricted __be32 fix by annotating image header integers big endian. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-10-15fdt: Check for a token to skip auto-hash validationJoe Hershberger
Allow the itb file to declare to u-boot that its hash should not be checked automatically on bootm or iminfo. This allows an image to either be checked automatically or to include a script which may check it otherwise (such as after part of the itb has been relocated to RAM by the script). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-08-23powerpc/CoreNet: add tool to support pbl image build.Shaohui Xie
Provides a tool to build boot Image for PBL(Pre boot loader) which is used on Freescale CoreNet SoCs, PBL can be used to load some instructions and/or data for pre-initialization. The default output image is u-boot.pbl, for more details please refer to doc/README.pblimage. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-04-30image/fit: drop inline markings on parser codeMike Frysinger
Putting "inline" on extern funcs makes no sense, so drop them. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-27Add cmd_spl commandSimon Schwarz
This adds a spl command to the u-boot. Related config: CONFIG_CMD_SPL activate/deactivate the command CONFIG_CMD_SPL_NAND_OFS Offset in NAND to use Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> CC: Wolfgang Denk <wd@denx.de>
2012-01-13openrisc: Add architecture image supportStefan Kristiansson
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2011-12-01image: Implement IH_TYPE_KERNEL_NOLOADStephen Warren
The legacy uImage format includes an absolute load and entry-point address. When bootm operates on a kernel uImage in memory that isn't loaded at the address in the image's load address, U-Boot will copy the image to its address in the header. Some kernel images can actually be loaded and used at any arbitrary address. An example is an ARM Linux kernel zImage file. To represent this capability, IH_TYPE_KERNEL_NOLOAD is implemented, which operates just like IH_TYPE_KERNEL, except that the load address header is ignored, and U-Boot does not copy the image to its load address, but rather uses it in-place. This is useful when sharing a single (uImage-wrapped) zImage across multiple boards with different memory layouts; in this case, a specific load address need not be picked when creating the uImage, but instead is selected by the board-specific U-Boot environment used to load and boot that image. v2: Rename from IH_TYPE_KERNEL_ANYLOAD to IH_TYPE_KERNEL_NOLOAD. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-23Fix clash between IH_ARCH_NDS32 and IH_ARCH_SANDBOXStefan Kristiansson
NDS32 and SANDBOX architecture were sharing the same IH_ARCH number Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Acked-by: Macpaul Lin <macpaul@andestech.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-10-27image: Fix inverted logic in architecture check.Thierry Reding
Commit 476af29 broke this check when the ifdef lists we consolidated. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-23mkimage: adding support for Davinci AIS imageStefano Babic
Some Davinci processors supports the Application Image Script (AIS) boot process. The patch adds the generation of the AIS image inside the mkimage tool to make possible to generate a bootable U-boot without external tools (TI Davinci AIS Generator). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-10-22checkpatch whitespace cleanupsStephen Warren
This avoids the following checkpatch warning in later patches: ERROR: "(foo*)" should be "(foo *)" ERROR: space required before the open brace '{' ERROR: space prohibited before that close parenthesis ')' ERROR: spaces required around that '||' (ctx:WxV) WARNING: space prohibited between function name and open parenthesis '(' WARNING: line over 80 characters This fixes all the white-space warnings/errors in my subsequent patch, and within this current patch. A number of other checkpatch warnings and errors are still present in this patch itself, but are beyond simple whitespace fixes, so are not solved by this patch. v2: New patch Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-10-22nds32: common bdinfo, bootm, image supportMacpaul Lin
Add support of NDS32 to common commands bdinfo, bootm, and image format. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-17sandbox: Add architecture image supportSimon Glass
We won't actually load an image with this architecture, but we still need to define it. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-05image: push default arch values to arch headersMike Frysinger
This pushes the ugly duplicated arch ifdef lists we maintain in various image related files out to the arch headers themselves. Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-08-03mkimage: Add OMAP boot image supportJohn Rigby
- Add mkimage support for OMAP boot image - Add support for OMAP boot image(MLO) generation in the new SPL framework Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-07-28mkimage: add UBL header support for booting davinci cpusHeiko Schocher
creating an u-boot.ubl file, which contains the UBL Header needed for booting from NAND with the RBL from TI. For more information read doc/README.ublimage. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-04-25Respect memreserve regions specified in the device treeGrant Likely
If a regions is reserved in the fdt, then it should not be used. Add the memreserve regions to the lmb so that u-boot doesn't use them to store the initrd. Signed-off-by: Grant Likely <grant.likely@linaro.org>
