This function will be used to print signatures as well as hashes, so rename
it. Also make it static since it is not used outside this file.
We intend to add signatures to FITs also, so rename this function so that
it is not specific to hashing. Also rename fit_image_set_hashes() and
This function will be needed by signature checking code, so export it,
and also add docs.
The existing function is long and most of the code is indented a long
way. Before adding yet more code, split this out into its own function.
Reviewed-by: Marek Vasut <marex@denx.de> (v1)
This is the main entry point to the FIT image verification code. We will
be using it to handle image verification with signatures, so rename the
function.
This function doesn't need to be exported, and with verification
we want to use it for setting the 'value' property in any node,
so rename it.
This code is never compiled into U-Boot, so move it into a separate
file in tools/ to avoid the large #ifdef.
One we split out the FIT code from image.c we will need this function.
Export it in the header.
Rather than repeat the line
#if defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) || \
defined(USE_HOSTCC)
everywhere, put this in a header file and #define IMAGE_ENABLE_TIMESTAMP
to either 1 or 0. Then we can use a plain if() in most code and avoid
the #ifdefs.
The compiler's dead code elimination ensures that the result is the same.
Signed-off-by: Steven Stallion <sstallion@gmail.com>
Cc: Tom Rini <trini@ti.com>
Reviewed-by: Tom Rini <trini@ti.com>
and, if including libfdt.h which includes libfdt_env.h in
the correct order, don't include fdt.h before libfdt.h.
this is needed to get the fdt type definitions set from
the project environment before fdt.h uses them.
Cc: Jerry Van Baren <gvb.uboot@gmail.com>
In order to mx53 ROM to properly load the U-boot image, its header size should
be multiple of 512 bytes.
This issue was observed with gcc 4.6.2/4.7.3, which caused data aborts:
U-Boot 2013.01-rc2-00172-gf8cfcf1-dirty (Dec 26 2012 - 13:13:28)
Board: MX53 LOCO
I2C: ready
DRAM: 1 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
In: serial
Out: serial
Err: serial
CPU: Freescale i.MX53 family rev2.1 at 1000 MHz
Reset cause: WDOG
Net: FEC
Warning: FEC using MAC address from net device
Hit any key to stop autoboot: 0
data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<aff72220>] lr : [<aff721fc>]
sp : af565e20 ip : af566918 fp : 00000000
r10: 00000003 r9 : affabb5b r8 : af565f58
r7 : 00000000 r6 : 36747fff r5 : af5668e8 r4 : 36747fff
r3 : af5668ec r2 : af5668eb r1 : 00000000 r0 : af5668e8
Flags: NzcV IRQs off FIQs off Mode SVC_32
Resetting CPU ...
resetting ...
,and this patch fixes it.
Also, even though the ROUND macro is already defined in common.h,
the reason for redefining it in image.h is explained by Stefano Babic:
"I will remark a previous comment - even if including common.h seems a
good idea to avoid duplications, it makes tools like mkimage to depend
on the selected board, because <board>_config must run. Even if this is
not a problem for us u-boot developers, it becomes an issue when these
tools are included in distros (like u-boot-tools in Ubuntu) and cannot
be packaged."
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Move the getenv_yesno() to env_common.c and change most checks for
'y' or 'n' to use this helper.
When booting a fit image with multiple configurations, the user either has to
specify which configuration to use explicitly, or there has to be a default
defined which is chosen automatically. This change adds an option to change
that behavior so that a configuration can be selected explicitly, or the
configuration which has the device tree that claims to be compatible with the
earliest item in U-Boot's device tree.
In other words, if U-Boot claimed to be compatible with A, B, and then C, and
the configurations claimed to be compatible with A, D and B, D and D, E, the
first configuration, A, D, would be chosen. Both the first and second
configurations match, but the first one matches a more specific entry in
U-Boot's device tree. The order in the kernel's device tree is ignored.
Signed-off-by: Gabe Black <gabeblack@google.com>
Commit-Ready: Gabe Black <gabeblack@chromium.org>
include/image.h:378:1: warning: cast to restricted __be32
include/image.h:381:1: warning: cast to restricted __be32
include/image.h:382:1: warning: cast to restricted __be32
include/image.h:383:1: warning: cast to restricted __be32
fix by annotating image header integers big endian.
Allow the itb file to declare to u-boot that its hash should not be
checked automatically on bootm or iminfo. This allows an image to
either be checked automatically or to include a script which may
check it otherwise (such as after part of the itb has been relocated
to RAM by the script).
Provides a tool to build boot Image for PBL(Pre boot loader) which is
used on Freescale CoreNet SoCs, PBL can be used to load some instructions
and/or data for pre-initialization. The default output image is u-boot.pbl,
for more details please refer to doc/README.pblimage.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
Putting "inline" on extern funcs makes no sense, so drop them.
This adds a spl command to the u-boot.
Related config:
CONFIG_CMD_SPL
activate/deactivate the command
CONFIG_CMD_SPL_NAND_OFS
Offset in NAND to use
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
CC: Tom Rini <tom.rini@gmail.com>
CC: Wolfgang Denk <wd@denx.de>
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
The legacy uImage format includes an absolute load and entry-point
address. When bootm operates on a kernel uImage in memory that isn't
loaded at the address in the image's load address, U-Boot will copy
the image to its address in the header.
Some kernel images can actually be loaded and used at any arbitrary
address. An example is an ARM Linux kernel zImage file. To represent
this capability, IH_TYPE_KERNEL_NOLOAD is implemented, which operates
just like IH_TYPE_KERNEL, except that the load address header is
ignored, and U-Boot does not copy the image to its load address, but
rather uses it in-place.
This is useful when sharing a single (uImage-wrapped) zImage across
multiple boards with different memory layouts; in this case, a specific
load address need not be picked when creating the uImage, but instead
is selected by the board-specific U-Boot environment used to load and
boot that image.
v2: Rename from IH_TYPE_KERNEL_ANYLOAD to IH_TYPE_KERNEL_NOLOAD.
NDS32 and SANDBOX architecture were sharing the same IH_ARCH number
Acked-by: Macpaul Lin <macpaul@andestech.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Commit 476af29 broke this check when the ifdef lists we consolidated.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Some Davinci processors supports the Application
Image Script (AIS) boot process. The patch adds the generation
of the AIS image inside the mkimage tool to make possible
to generate a bootable U-boot without external tools
(TI Davinci AIS Generator).
This avoids the following checkpatch warning in later patches:
ERROR: "(foo*)" should be "(foo *)"
ERROR: space required before the open brace '{'
ERROR: space prohibited before that close parenthesis ')'
ERROR: spaces required around that '||' (ctx:WxV)
WARNING: space prohibited between function name and open parenthesis '('
WARNING: line over 80 characters
This fixes all the white-space warnings/errors in my subsequent patch,
and within this current patch. A number of other checkpatch warnings
and errors are still present in this patch itself, but are beyond simple
whitespace fixes, so are not solved by this patch.
v2: New patch
Add support of NDS32 to common commands bdinfo, bootm, and image format.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
We won't actually load an image with this architecture, but we still need to
define it.
This pushes the ugly duplicated arch ifdef lists we maintain in various
image related files out to the arch headers themselves.
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Tested-by: Thomas Chou <thomas@wytron.com.tw>
- Add mkimage support for OMAP boot image
- Add support for OMAP boot image(MLO) generation in the new
SPL framework
Signed-off-by: John Rigby <john.rigby@linaro.org>
Signed-off-by: Aneesh V <aneesh@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
creating an u-boot.ubl file, which contains the UBL Header
needed for booting from NAND with the RBL from TI. For more
information read doc/README.ublimage.
If a regions is reserved in the fdt, then it should not be used. Add
the memreserve regions to the lmb so that u-boot doesn't use them to
store the initrd.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
This patch adds a function getenv_bootm_mapsize() for obtaining the
size of the early mapped region accessible by the kernel during early
boot. It defaults to CONFIG_SYS_BOOTMAPSZ, or if not defined,
defaults to getenv_bootm_size(), which in turn defaults to the size of
RAM.
getenv_bootm_mapsize() can also be overridden with a "bootm_mapsize"
environmental variable.
For the calls to boot_relocate_fdt(), boot_get_cmdline(), and
boot_get_kbd(), the value of bootmem_base is always obtained by
calling getenv_bootm_low(). Since the value always comes from the
same source, the calling signature for those functions can be
simplified by making them call getenv_bootm_low() directly.
These are pure lookup tables -- no need to be writable.
The routines boot_ramdisk_high, boot_get_cmdline and boot_get_kbd
are currently enabled by various combinations of CONFIG_M68K,
CONFIG_POWERPC and CONFIG_SPARC.
Use CONFIG_SYS_BOOT_<FEATURE> defines instead.
CONFIG_SYS_BOOT_RAMDISK_HIGH
CONFIG_SYS_BOOT_GET_CMDLINE
CONFIG_SYS_BOOT_GET_KBD
Define these as appropriate in arch/include/asm/config.h files.
Acked-by: Wolfgang Denk <wd@denx.de>
Add OSE as operating system for mkimage and bootm.
Signed-off-by: Torkel Lundgren <torkel.lundgren@enea.com>
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
ISO C does not allow extra ';' outside of a function
The nios-32 arch is obsolete and broken. So it is removed.
This patch adds support for "imximage" (MX Boot Image)
to the mkimage utility. The imximage is used on the Freescales's
MX.25, MX.35 and MX.51 processors.
Further details under doc/README.imximage.
This patch was tested on a Freescale mx51evk board.
The u-boot command structures don't get used with host systems, so don't
bother including it when building host code. This avoids an implicit need
on config.h in the process.
The sha1 code is currently compiled for everyone, but in reality, it's
only used by the FIT code. So make it optional just like MD5.
board/esd/plu405/plu405.c
drivers/rtc/ftrtc010.c
Add lzop decompression support to the existing lzo bitstream handling
(think gzip versus zlib), and support it for uImage decompression if
CONFIG_LZO is enabled.
Lzop doesn't compress as good as gzip (~10% worse), but decompression
is very fast (~0.7s faster here on a slow ppc). The lzop decompression
code is based on Albin Tonnerre's recent ARM Linux lzo support patch.
Cc: albin.tonnerre@free-electrons.com
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
This patch adds support for "kwbimage" (Kirkwood Boot Image)
image types to the mkimage code.
For details refer to docs/README.kwbimage
This patch is tested with Sheevaplug board
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Acked-by: Ron Lee <ron@debian.org>
- make get_table_entry_id() global
- make get_table_entry_name() global
- move struct table_entry to image.h
Currently this code is used by image.c only.
This patch makes this API global so it can be used by other parts of
code, too.
Acked-by: Ron Lee <ron.debian.org>
Edit comments and commit message.
Currently it is used by image.c only, but the the function can be
used to support additional mkimage types like for example kwbimage,
so make this function globally visible.
Edited commit message.
