path: root/include/i8042.h
2012-10-19input: i8042: Provide feature to disable keyboard before booting kernelLouis Yung-Chieh Lo
The BIOS leaves the keyboard enabled during boot time so that any keystroke would interfere kernel driver initialization. Add a way to disable the keyboard to make sure no scancode will be generated during the boot time. Note that the keyboard will be re-enabled again after the kernel driver is up. This code can be called from the board functions. Signed-off-by: Louis Yung-Chieh Lo <yjlou@chromium.org> Signed-off-by: Louis Yung-Chieh Lo <yjlou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-19input: Use finer grain udelays while waitng for the i8042 keyboard buffer to ā†µGabe Black
empty On x86, the i8042 keyboard controller driver frequently waits for the keyboard input buffer to be empty to make sure the controller has had a chance to process the data it was given. The way the delay loop was structured, if the controller hadn't cleared the corresponding status bit immediately, it would wait 1ms before checking again. If the keyboard responded quickly but not instantly, the driver would still wait a full 1ms when perhaps 1us would have been sufficient. Because udelay is a busy wait anyway, this change decreases the delay between checks to 1us. Also, this change gets rid of a hardcoded 250ms delay. On Stumpy, this saves 100-150ms during boot. Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
2002-09-17Initial revisionwdenk
