path: root/include/gt64120.h
2022-01-12pci: gt64120: Use PCI_CONF1_ADDRESS() macroPali Rohár
PCI gt64120 driver uses standard format of Config Address for PCI Configuration Mechanism #1. So use new U-Boot macro PCI_CONF1_ADDRESS() and remove old custom driver address macros. Signed-off-by: Pali Rohár <pali@kernel.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-07-25qemu-malta: Update for SPDX license identifiersTom Rini
2013-07-24MIPS: import gt64120.h header from LinuxGabor Juhos
The Linux specific register access macros, the extern function declarations and the UL suffixes has been removed. The header file will be used for the qemu-malta board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
