path: root/include/gdsys_fpga.h
2021-04-10ppc: Remove gdsys hrcon boardsTom Rini
These boards have not been converted to CONFIG_DM_MMC, along with other DM conversions, by the deadline. Remove them. Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-04-10ppc: Remove gdsys strider boardsTom Rini
2019-05-21gdsys: Introduce GDSYS_LEGACY_DRIVERSMario Six
Future gdsys boards will switch from the legacy drivers in board/gdsys/common to DM-based drivers. Define a Kconfig option that disables the legacy drivers. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21gdsys: Post ppc4xx removal cleanupMario Six
The ppc4xx architecture was removed, and with it several old gdsys 44x boards, but some "debris" from these purged boards was left over. This patch removes these remnants (mostly entries in Makefiles, some now superfluous data structures and some now obsolete config variables from the whitelist). Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21hrcon: Migrate to CONFIG_TARGET_HRCONMario Six
Use the proper CONFIG_TARGET_HRCON Kconfig option to replace the CONFIG_HRCON ad-hoc config option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-03-09treewide: Fix gdsys mail addressesMario Six
The @gdsys.cc addresses are supposed to be used for mailing lists. Switch all occurrences of @gdsys.de mail addresses to their @gdsys.cc equivalent. Also, Dirk's address was wrong in one place; fix that as well. Signed-off-by: Mario Six <six@gdsys.cc>
2016-07-22gdsys: Drop print_fpga_state functionTom Rini
On most platforms the print_fpga_state function is never called. Only on dlvision-10g do we, so in that case inline it. Drop it from everywhere else to avoid extra strings. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Acked-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2016-06-06strider: Support con-dp flavorDirk Eibach
There is a new strider console flavor with DisplayPort video. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-12hrcon: Add support for the DH variantDirk Eibach
hrcon DH(dual head) has two video outputs per FPGA. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12mpc83xx: Add strider boardDirk Eibach
The gdsys strider board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card. On board peripherals include: - 1x 10/100 Mbit/s Ethernet (optional) - Lattice ECP3 FPGA connected via eLBC Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> [trini: Drop setting CONFIG_SYS_GENERIC_BOARD, this is always true now] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-12i2c: ihs_i2c: Dual channel supportDirk Eibach
Support two i2c masters per FPGA. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-19mpc83xx: Add gdsys hrcon boardDirk Eibach
The gdsys hrcon board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card. On board peripherals include: - 1x GbE (optional) - Lattice ECP3 FPGA connected via eLBC and PCIe Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2014-07-07i2c: IHS I2C master driverDirk Eibach
IHS I2C master support was merely a hack in the osd driver. Now it is a proper u-boot I2C framework driver, supporting the v2.00 master features. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2013-07-25powerpc/ppc4xx: Support gdsys multichannel iocon hardwareDirk Eibach
2013-07-25powerpc/ppc4xx: Use generic accessor functions for gdsys FPGADirk Eibach
A set of accessor functions was added to be able to access not only memory mapped FPGA in a generic way. Thanks to Wolfgang Denk for getting this sorted properly. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Remove typedefs for gdsys FPGADirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Fix typo in gdsys_fpga.hDirk Eibach
2012-04-30powerpc/ppc4xx: Make gdsys 405ep boards reset more genericDirk Eibach
In order to add boards that have different hardware for fpga reset, any 405ep gdsys board now provides these functions: void gd405ep_init(void); void gd405ep_set_fpga_reset(unsigned state); void gd405ep_setup_hw(void); int gd405ep_get_fpga_done(unsigned fpga); Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-01-09ppc4xx: Setup HICB on Io64Dirk Eibach
The FPGA High-Speed Interconnect Bus (HICB) is now setup by u-boot. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-12-01ppc4xx: Add Io64 board supportDirk Eibach
Board support for the Guntermann & Drunck Io64. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-04-21ppc4xx: Enable MPC92469AC on DLVision 10GDirk Eibach
2011-04-21ppc4xx: Set DLVision 10G osd position to linux defaultsDirk Eibach
2011-04-21ppc4xx: Adapt DLVision 10G to new FPGA firmwareDirk Eibach
2011-02-07ppc4xx: Add DLVision-10G board supportDirk Eibach
Board support for the Guntermann & Drunck DLVision-10G. Adds support for multiple FPGAs per board for gdsys 405ep architecture. Adds support for dual link osd hardware for gdsys 405ep. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
