path: root/include/fuse.h
2013-04-28Add fuse API and commandsBenoît Thébaudeau
This can be useful for fuse-like hardware, OTP SoC options, etc. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
