path: root/include/fsl_usb.h
2018-10-29fsl/usb: Workaround for USB erratum-A005275Chris Packham
Workaround makes FS as default mode on all affected socs. Add support to check erratum-A005275 validity for an soc. This info is required to determine whether a given soc is affected by this erratum. Add quirk for this erratum "has_fsl_erratum_a005275" . This quirk is used to enable workaround for the errata Force FS mode as default by: - making EPS as FS - setting PFSC bit to disable HS chirping This workaround can be disabled by mentioning "no_erratum_a005275" in hwconfig string Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-27drivers: usb: xhci-fsl: Implement Erratum A-010151 for FSL USB3 controllerSriram Dash
Currently the controller by default enables the Receive Detect feature in P3 mode in USB 3.0 PHY. However, USB 3.0 PHY does not reliably support receive detection in P3 mode. Enabling the USB3 controller to configure USB in P2 mode whenever the Receive Detect feature is required. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2016-06-13usb: xhci: fsl: Add workaround for USB erratum A008751Sriram Dash
This patch is doing the following: 1. Implementing the errata for LS2080. 2. Adding fixup for fdt for LS2080. Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2016-06-13fsl: usb: make errata function common for PPC and ARMSriram Dash
This patch does the following things: 1. Makes the errata checking code common for PPC and ARM 2. Moves all these static inline functions into a dedicated C file Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
2015-12-07drivers:usb:fsl: Add T4080 as affected soc for Erratum A007792 sw workaroundRajesh Bhagat
Apply Erratum A007792 sw workaround for T4080 Signed-off-by: Sriram Dash <sriram.dash@freescale.com> Signed-off-by: Rajesh Bhagat <rajesh.bhagat@freescale.com> Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2015-05-04drivers: usb: fsl: Workaround for Erratum A004477Nikhil Badola
Add a delay of 1 microsecond before issuing soft reset to the controller to let ongoing ULPI transaction complete. This prevents corruption of ULPI Function Control Register which eventually prevents phy clock from entering to low power mode Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-21drivers:usb: Check if USB Erratum A005697 is applicable on BSC913xNikhil Badola
Check if USB Erratum A005697 is applicable on BSC913x and add corresponding property in the device tree via device tree fixup which is used by linux driver Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-21drivers:usb:fsl: Add affected SOCs for USB Erratum A007792Nikhil Badola
Add following affected SOCs and their personalities for USB Erratum A007792 : T1040 Rev 1.1 T1024 Rev 1.0 Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-21drivers:usb: Add device-tree fixup to identify socs having dual phyNikhil Badola
Identify soc(s) having dual phy so as to add "utmi_dual" as phy_mode for all these socs. This is required for supporting deel-sleep feature in linux for usb driver Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-11drivers: usb: fsl: Check USB Erratum A007792 applicabilityNikhil Badola
Check USB Erratum A007792 applicability. If applicable, add corresponding property in the device tree via device tree fixup Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-24drivers : usb: fsl: Implement usb Erratum A007798 workaroundNikhil Badola
Set TXFIFOTHRESH to adjust ddr pipeline delay for successful large usb writes Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-11-21drivers: usb: fsl: Move USB Errata checking codeNikhil Badola
Move USB Errata checking code from "arch/powerpc" to architecture independent file "fsl_usb.h" so that errata(s) become independent of the architecture. For each erratum checking function for PPC arch, define a nop function for non PPC arch for successful compilation in either case Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc/mpc85xx: Add Differential SYSCLK config support T1040Nikhil Badola
Adds support for clock sourcing from sysclk(100MHz) for usb on T104xRDB and T1040QDS. This requires changing reference divisor and multiplication factor to derive usb clock from sysclk. Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-07powerpc/usb: Workaround for erratum-A006261Suresh Gupta
USB spec says that the minimum disconnect threshold should be over 525 mV. However, internal USB PHY threshold value is below this specified value. Due to this some devices disconnect at run-time. Hence, phy settings are tweaked to increased disconnect threshold to be above 525mV by using this workaround. Signed-off-by: Suresh Gupta <suresh.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2013-08-14include/fsl_usb.h: Cleanup license headerYork Sun
Replace license header with SPDX license identifier. Replace GPL-2.0 with GPL-2.0+. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2013-08-14fsl/usb: Move USB internal phy definitions to fsl_usb.hramneek mehresh
fsl_usb.h file created to share data bewteen usb platform code and usb ip driver. Internal phy structure definitions moved to this file Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
