path: root/include/fsl_usb.h
2014-03-07powerpc/usb: Workaround for erratum-A006261Suresh Gupta
USB spec says that the minimum disconnect threshold should be over 525 mV. However, internal USB PHY threshold value is below this specified value. Due to this some devices disconnect at run-time. Hence, phy settings are tweaked to increased disconnect threshold to be above 525mV by using this workaround. Signed-off-by: Suresh Gupta <suresh.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2013-08-14include/fsl_usb.h: Cleanup license headerYork Sun
Replace license header with SPDX license identifier. Replace GPL-2.0 with GPL-2.0+. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2013-08-14fsl/usb: Move USB internal phy definitions to fsl_usb.hramneek mehresh
fsl_usb.h file created to share data bewteen usb platform code and usb ip driver. Internal phy structure definitions moved to this file Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
