path: root/include/fsl_sfp.h
2016-10-06fsl_sfp : Modify macros as per changes in SFP v3.4Sumit Garg
SFP v3.4 supports 8 keys in SRK table which leads to corresponding changes in OSPR key revocation field. So modify OSPR_KEY_REVOC_XXX macros accordingly. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: ls2080: Add SFP Configs for LS2080Saksham Jain
In LS2080, SFP has version 3.4. It is in little endian. The base address is 0x01e80200. SFP is used in Secure Boot to read fuses. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-03-05fsl_sfp : Move ccsr_sfp_regs definition to common includegaurav rana
Freescale sfp has been used for mpc8xxx. It will be used for ARM-based SoC as well. This patch moves the CCSR defintion of sfp_regs to common include. This patch also defines ccsr_sfp_regs definition for newer versions of SFP. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
