path: root/include/fsl_esdhc.h
2019-01-26drivers: esdhc: add support for ColdFire mcf5441x familyAngelo Dureghello
This patch has been tested on the mcf54415-based stmark2 board. The eSDHC driver works reliably using DMA mode. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2018-02-04mmc: fsl_esdhc: support SDR104 and HS200Peng Fan
Introduce SDR104 and HS200 support The implementation takes linux kernel sdhci.c and sdhci-esdhc-imx.c as reference. - Implement esdhc_change_pinstate to dynamically change pad settings - Implement esdhc_set_timing - Implement esdhc_set_voltage to switch voltage - Implement fsl_esdhc_execute_tuning to execute time process - Enlarge the cfg->f_max to 200MHz. - Parse fsl,tuning-step, fsl,tuning-start-tap and fsl,strobe-dll-delay-target from device tree. - Parse no-1-8-v property - Introduce esdhc_soc_data to indicate the flags and caps Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2017-11-07mmc: fsl_esdhc: Fix PIO timeoutBenoît Thébaudeau
The following error has been observed on i.MX25 with a high-speed SDSC card: Data Write Failed in PIO Mode. It was caused by the timeout set on PRSSTAT.BWEN, which was triggered because this bit takes 15 ms to be set after writing the first block to DATPORT with this card. Without this timeout, all the blocks are properly written. This timeout was implemented by decrementing a variable, so it was depending on the CPU frequency. Fix this issue by setting this timeout to a long enough absolute duration (500 ms). Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-07-12mmc: fsl_esdhc: introduce vs18_enable for 1.8V fix I/OPeng Fan
When using eMMC with 1.8V I/O, the VSELECT bit need to be set in the USDHC controller when init. This patch adds a parameter "vs18_enable" in fsl_esdhc_cfg structure and priv data, so each controller can have different settings. We could not use CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT, it has problem that it will apply to all USDHC controllers and it only set the 1.8V at init phase. So if user does not select to the eMMC device, the voltage on the I/O pins are not correct. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: York Sun <york.sun@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-07-12mmc: fsl_esdhc: correct type of wp_enablePeng Fan
The type should be int, not u8. cfg->wp_enable will finally be assigned to priv->wp_enable whose type is int. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2016-06-28mmc: fsl: introduce wp_enablePeng Fan
Introudce wp_enable. To check WPSPL, wp_enable needs to be set to 1 in board code. Take i.MX6UL for example, for some boards, they do not use WP singal, so they does not configure USDHC1_WP_SELECT_INPUT, and its default value is 0(GPIO1_IO02). However GPIO1_IO02 is muxed for i2c usage and SION bit set. So USDHC controller can always get wp signal and WPSPL shows write protect and blocks driver continuing. This is not what we want to see, so add wp_enable, and if set to 0, just omit the WPSPL checking and this does not effect normal working of usdhc controller. If wp-gpios is provided in dts, wp_enable is set to 1, otherwise 0. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: York Sun <york.sun@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-06-28mmc: fsl: reset to normal boot mode when eMMC fast bootPeng Fan
When booting in eMMC fast boot, MMC host does not exit from boot mode after bootrom loading image. So the first command 'CMD0' sent in uboot will pull down the CMD line to low and cause errors. This patch cleans the MMC boot register in "mmc_init" to put the MMC host back to normal mode. Also clear DLL_CTRL delay line settings at USDHC initialization to eliminate the pre-settings from boot rom. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: York Sun <york.sun@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-04-06fsl: esdhc: consolidate fsl_esdhc_cfg structurePeng Fan
We can use phys_addr_to for esdhc_base to discard the #ifdef. Signed-off-by: Peng Fan <van.freenix@gmail.com> Cc: York Sun <york.sun@nxp.com> Cc: Yangbo Lu <yangbo.lu@nxp.com> Cc: Eric Nelson <eric@nelint.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-03ARM: imx: fsl_esdhc: fix usage of low 4 bits of sysctl registerEric Nelson
The low four bits of the SYSCTL register are reserved on the USDHC controller on i.MX6 and i.MX7 processors, but are used for clocking operations on earlier models. Guard against their usage by hiding the bit mask macros on those processors. These bits are used to prevent glitches when changing clocks on i.MX35 et al. Use the RSTA bit instead for i.MX6 and i.MX7. >From the i.MX6DQ RM: To prevent possible glitch on the card clock, clear the FRC_SDCLK_ON bit when changing clock divisor value(SDCLKFS or DVS in System Control Register) or setting RSTA bit. Signed-off-by: Eric Nelson <eric@nelint.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Hector Palacios <hector.palacios@digi.com>
2015-10-29armv8/ls1043ardb: esdhc: Add esdhc support for ls1043ardbYangbo Lu
This patch adds esdhc support for ls1043ardb. Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-05-04mmc: fsl_esdhc: Add peripheral clock supportYangbo Lu
The SD clock could be generated by platform clock or peripheral clock for some platforms. This patch adds peripheral clock support for T1024/T1040/T2080. To enable it, define CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK. Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com> Cc: York Sun <yorksun@freescale.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-05-04mmc: fsl_esdhc: Add adapter card type identification supportYangbo Lu
Add adapter card type identification support by reading FPGA STAT_PRES1 register SDHC Card ID[0:2] bits. To use this function, define CONFIG_FSL_ESDHC_ADAPTER_IDENT. Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com> Cc: York Sun <yorksun@freescale.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> [York Sun: resolve conflicts in README.fsl-esdhc] Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-23ls2085a: esdhc: Add esdhc support for ls2085aYangbo Lu
This patch adds esdhc support for ls2085a. Signed-off-by: Yangbo Lu <yangbo.lu@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com>
2015-03-02Merge branch 'master' of git://git.denx.de/u-bootStefano Babic
2015-02-24mmc: fsl_esdhc: Add support for DDR modeVolodymyr Riazantsev
Add support of the DDR mode for eSDHC driver. Enable it for i.MX6 SoC family only. Signed-off-by: Volodymyr Riazantsev <volodymyr.riazantsev@globallogic.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-23mmc: fsl_esdhc: Add CMD11 support to switch to 1.8VOtavio Salvador
This adds support to switch to 1.8V in case CMD11 succeeds. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Marek Vasut <marex@denx.de>
2014-09-08esdhc: Add CONFIG_SYS_FSL_ESDHC_LE and CONFIG_SYS_FSL_ESDHC_BE macrosWang Huan
For LS102xA, the processor is in little-endian mode, while esdhc IP is in big-endian mode. CONFIG_SYS_FSL_ESDHC_LE and CONFIG_SYS_FSL_ESDHC_BE are added. So accessing ESDHC registers can be determined by ESDHC IP's endian mode. Signed-off-by: Alison Wang <alison.wang@freescale.com>
2014-04-22driver: Add support of image load for MMC & SPI in SPLPrabhakar Kushwaha
Add support of loading image, binary for MMC and SPI during SPL boot. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-24mmc: Split mmc struct, rework mmc initialization (v2)Pantelis Antoniou
The way that struct mmc was implemented was a bit of a mess; configuration and internal state all jumbled up in a single structure. On top of that the way initialization is done with mmc_register leads to a lot of duplicated code in drivers. Typically the initialization got something like this in every driver. struct mmc *mmc = malloc(sizeof(struct mmc)); memset(mmc, 0, sizeof(struct mmc); /* fill in fields of mmc struct */ /* store private data pointer */ mmc_register(mmc); By using the new mmc_create call one just passes an mmc config struct and an optional private data pointer like this: struct mmc = mmc_create(&cfg, priv); All in tree drivers have been updated to the new form, and expect mmc_register to go away before long. Changes since v1: * Use calloc instead of manually calling memset. * Mark mmc_register as deprecated. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2013-08-20powerpc: mpc85xx: Support booting from SD Card with SPLYing Zhang
The code from the internal on-chip ROM. It loads the final uboot image into DDR, then jump to it to begin execution. The SPL's size is sizeable, the maximum size must not exceed the size of L2 SRAM. It initializes the DDR through SPD code, and copys final uboot image to DDR. So there are two stage uboot images: * spl_boot, 96KB size. The env variables are copied to L2 SRAM, so that ddr spd code can get the interleaving mode setting in env. It loads final uboot image from offset 96KB. * final uboot image, size is variable depends on the functions enabled. Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-04-14fsl_esdhc: Fix DMA transfer completion waiting loopAndrew Gabbasov
Rework the waiting for transfer completion loop condition to continue waiting until both Transfer Complete and DMA End interrupts occur. Checking of DLA bit in Present State register looks not needed in addition to interrupts status checking, so it can be removed from the condition. Also, DMA Error condition is added to the list of data errors, checked in the loop. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
2013-04-03mmc: i.MX6: fsl_esdhc: Define maximum bus width supported by a boardAbbas Raza
Maximum bus width supported by some i.MX6 boards is not 8bit like others. In case where both host controller and card support 8bit transfers, they agree to communicate on 8bit interface while some boards support only 4bit interface. Due to this reason the mmc 8bit default mode fails on these boards. To rectify this, define maximum bus width supported by these boards (4bit). If max_bus_width is not defined, it is 0 by default and 8bit width support will be enabled in host capabilities otherwise host capabilities are modified accordingly. It is tested with a MMCplus card. Signed-off-by: Abbas Raza <Abbas_Raza@mentor.com> cc: stefano Babic <sbabic@denx.de> cc: Andy Fleming <afleming@gmail.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
2012-10-16mxc: Fix SDHC multi-instance clockBenoît Thébaudeau
On mxc, each SDHC instance has a dedicated clock, so gd->sdhc_clk is not suitable for the multi-instance use case (initialization made directly with fsl_esdhc_initialize()). This patch fixes this issue by adding a configuration field for the SDHC input clock frequency. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Eric Bénard <eric@eukrea.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Jason Liu <r64343@freescale.com> Cc: Matt Sealey <matt@genesi-usa.com> Cc: Andy Fleming <afleming@gmail.com>
2012-09-01fsl_esdhc: Remove cache snooping for i.MXBenoît Thébaudeau
The cache snooping feature of Freescale's eSDHC IP is not available on i.MX, so disable it globally for this architecture. This avoids setting no_snoop for all i.MX boards, and it prevents setting a reserved bit of a reserved register if fsl_esdhc_mmc_init() is used on i.MX, like in arch/arm/cpu/armv7/imx-common/cpu.c/cpu_mmc_init(). Since no_snoop was only used on i.MX, get rid of it BTW. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com>
2012-05-08mmc: fsl_esdhc: Poll until card is not busy anymoreDirk Behme
This patch imports parts of two patches from the Freescale U-Boot with the following commit messages: ENGR00156405 ESDHC: Add workaround for auto-clock gate errata ENGcm03648 http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/commit/drivers/mmc/imx_esdhc.c?h=imx_v2009.08_12.01.01&id=e436525a70fe47623d346bc7d9f08f12ff8ad787 The errata, not applicable to USDHC, causes ESDHC to shut off clock to the card when auto-clock gating is enabled for commands with busy signalling and no data phase. The card might require the clock to exit the busy state, so the workaround is to disable the auto-clock gate bits in SYSCTL register for such commands. The workaround also entails polling on DAT0 bit in the PRSSTAT register to learn when busy state is complete. Auto-clock gating is re-enabled at the end of busy state. ENGR00156670-1 ESDHC/USDHC: Remove delay before each cmd and some bug fixes http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/commit/drivers/mmc/imx_esdhc.c?h=imx_v2009.08_12.01.01&id=a77c6fec8596891be96b2cdbc742c9824844b92a Removed delay of 10 ms before each command. There should not be a need to have this delay after the ENGR00156405 patch that polls until card is not busy anymore before proceeding to next cmd. This patch imports the polling part of both patches. The auto-clock gating code don't apply for i.MX6 as implemented in these two patches. SYSCTL_RSTA was defined twice. Remove one definition. Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> CC: Andy Fleming <afleming@freescale.com> CC: Fabio Estevam <fabio.estevam@freescale.com> CC: Stefano Babic <sbabic@denx.de>
2011-04-10fsl_esdhc: Deal with watermark level register related changesPriyanka Jain
P1010 and P1014 has v2.3 version of FSL eSDHC controller in which watermark level register description has been changed: 9-15 bits represent WR_WML[0:6], Max value = 128 represented by 0x00 25-31 bits represent RD_WML[0:6], Max value = 128 represented by 0x00 Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Poonam Aggrwal <Poonam.Aggrwal@freescale.com> Tested-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-23ppc/85xx: PIO Support for FSL eSDHC Controller DriverDipen Dudhat
On some Freescale SoC Internal DMA of eSDHC controller has bug. So PIO Mode has been introduced to do data transfer using CPU. Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com>
2010-04-07fsl_esdhc: Only modify the field we are changing in WMLRoy Zang
When we set the read or write watermark in WML we should maintain the rest of the register as is, rather than using some hard coded value. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-07fsl_esdhc: Add function to reset the eSDHC controllerJerry Huang
To support multiple block read command we must set abort or use auto CMD12. If we booted from eSDHC controller neither of these are used and thus we need to reset the controller to allow multiple block read to function. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-07fsl_esdhc: Always stop clock before changing frequencyKumar Gala
We need to stop the clocks on 83xx/85xx as well as imx. No need to make this code conditional to just imx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefano Babic <sbabic@denx.de>
2010-03-07fsl_esdhc: add support for mx51 processorStefano Babic
The esdhc controller in the mx51 processor is quite the same as the one in some powerpc processors (MPC83xx, MPC85xx). This patches adapts the driver to support the arm mx51. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-01-25fsl_esdhc: fix wrong clock maskLi Yang
Fix typo in SYSCTL_CLOCK_MASK, which caused residual in high bits of SDCLKFS. Signed-off-by: Jin Qing <B24347@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-16fsl_esdhc: Add device tree fixupsAnton Vorontsov
This patch implements fdt_fixup_esdhc() function that is used to fixup the device tree. The function adds status = "disabled" propery if esdhc pins muxed away, otherwise it fixups clock-frequency for esdhc nodes. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-16Add support for the Freescale eSDHC found on 8379 and 8536 SoCsAndy Fleming
This uses the new MMC framework Some contributions by Dave Liu <daveliu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
