path: root/include/fsl_diu_fb.h
2011-08-04video: Add SHARP LQ084S3LG01 LCD support on P1022DSTimur Tabi
The SHARP LQ084S3LG01 is a TFT LCD used on the P1022DS (revision "C") board. This device only supports 800x600 resolution, so if that resolution is selected, assume that this is the device. The device is attached to the LVDS port on the P1022DS board. The existing 800x600 entry (for the PDM360NG board) is actually 800x480, so we fix that. To support two different 800x resolutions, the Y-resolution is now passed to fsl_diu_init() and both values are used to pick the proper fb_videomode structure. The data for the 800x600 video mode is originally from Jiang Yutang. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Jiang Yutang <b14898@freescale.com>
2011-04-28powerpc: use 'video-mode' environment variable to configure DIUTimur Tabi
Use the 'video-mode' environment variable (for Freescale chips that have a DIU display controller) to designate the full video configuration. Previously, the DIU driver used the 'monitor' variable, and it was used only to determine the output video port. The old definition of the "monitor" environment variable only determines which video port to use for output. This variable was set to a number (0, 1, or sometimes 2) to specify a DVI, LVDS, or Dual-LVDS port. The resolution was hard-coded into board-specific code. The Linux command-line arguments needed to be hard-coded to the proper video definition string. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-09-25fsl_diu_fb: further refactoring of FSL DIU codeAnatolij Gustschin
Move common code to the fsl_diu_fb.c file and remove obsolete code from board files (aria, mpc8610hpcd and pdm360ng). Move fsl_diu_fb.h file to the include directory. Signed-off-by: Anatolij Gustschin <agust@denx.de>
