path: root/include/fsl_devdis.h
2015-09-01arm/ls102xa:add hwconfig setting to support disable unused devicesZhuoyu Zhang
DEVDISRn registers provides a mechanism for gating clocks of IP blocks that are not used. Here we implement hwconfig option to allow users to disable unused peripherals on the board. For ex. If eSDHC/qDMA/eDMA are unused and with disabled status in dts, User can enable CONFIG_FSL_DEVICE_DISABLE and set "devdis:esdhc,qdma,edma" in hwconfig, thus ESDHC controller & eDMA/qDMA will be clock gated to save more power. Signed-off-by: Zhuoyu Zhang <Zhuoyu.Zhang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
