path: root/include/fsl_ddr_sdram.h
2014-09-25driver/ddr/fsl: Fix tXP and tCKEYork Sun
The driver was written using old DDR3 spec which only covers low speeds. The value would be suboptimal for higher speeds. Fix both timing according to latest DDR3 spec, remove tCKE as an config option. Signed-off-by: York Sun <yorksun@freescale.com>
2014-09-25driver/ddr: Restruct driver to allow standalone memory spaceYork Sun
U-boot has been initializing DDR for the main memory. The presumption is the memory stays as a big continuous block, either linear or interleaved. This change is to support putting some DDR controllers to separated space without counting into main memory. The standalone memory controller could use different number of DIMM slots. Signed-off-by: York Sun <yorksun@freescale.com>
2014-09-08driver/ddr/fsl: Add support of overriding chip select write levelingYork Sun
JEDEC spec allows DRAM vendors to use prime DQ for write leveling. This is not an issue unless some DQ pins are not connected. If a platform uses regular DIMMs but with reduced DDR ECC pins, the prime DQ may end up on those floating pins for the second rank. The workaround is to use a known good chip select for this purpose. Signed-off-by: York Sun <yorksun@freescale.com>
2014-04-22mpc85xx/t104x: Add deep sleep framework supportTang Yuantian
When T104x soc wakes up from deep sleep, control is passed to the primary core that starts executing uboot. After re-initialized some IP blocks, like DDRC, kernel will take responsibility to continue to restore environment it leaves before. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22driver/ddr/fsl: Add DDR4 support to Freescale DDR driverYork Sun
Mostly reusing DDR3 driver, this patch adds DDR4 SPD handling, register calculation and programming. Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-21driver/ddr: Add 256 byte interleaving supportYork Sun
Freescale LayerScape SoCs support controller interleaving on 256 byte size. This interleaving is mandoratory. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
