path: root/include/fsl-mc
2017-09-11armv8: fsl-layerscape: Support to add RGMII for ls1088aqdsAshish Kumar
This patch adds support for RGMII protocol NXP's LDPAA2 support RGMII protocol. LS1088A is the first Soc supporting both RGMII and SGMII. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Amrita Kumari <amrita.kumari@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-06-01drivers: net: fsl-mc: Link MC boot to PHY_RESET_RBogdan Purcareata
DPAA2 platforms boot the Management Complex based on the u-boot env variable "mcinitcmd". Instead of doing this step on each platform individually, define a single mc_env_boot function in the MC driver, since it's semantically tied to it. Call the function in a per-board reset_phy hook, as it gets called at a later moment, when all board PHY devices have been initialized. Signed-off-by: Bogdan Purcareata <bogdan.purcareata@nxp.com> Signed-off-by: Heinz Wrobel <heinz.wrobel@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-03-28arm: fsl-layerscape: Move QSGMII wriop_init to SoC filePrabhakar Kushwaha
MAC number used per QSGMII is not fixed. It may wary from SoC to SoC. So move QSGMII wriop_init_dpmac() to SoC file. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-01-27driver: net: fsl-mc: flib changes for MC FW 9.0.0Prabhakar Kushwaha
MC firmware version 9.0.0 contains - Support of new APIs - Update in existing APIs - Change in Major and minor version of DPAA2 objects This patch contains modifications in FLIB files to support new MC firmware version. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-11-30driver: net: ldpaa: Use DPMAC as net devicePrabhakar Kushwaha
As per current implementation of DPAA2 ethernet driver DPNI is used as net device. DPNI is tangible objects can be multiple connected to same physical lane. Use DPMAC as net device where it represents physical lane. Below modification done in driver - Use global DPNI object - Connect DPMAC to DPNI - Create and destroy DPMAC Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30driver: net: fsl-mc: Create DPAA2 object at run-timePrabhakar Kushwaha
Freescale's DPAA2 ethernet driver depends upon the static DPL for the DPRC, DPNI, DPBP, DPIO objects. Instead of static objects, Create DPNI, DPBP, DPIO objects at run-time. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30driver: net: fsl-mc: Add DPAA2 commands to manage MCPrabhakar Kushwaha
Management complex Firmware, DPL and DPC are depolyed during u-boot boot sequence. Add new DPAA2 commands to manage Management Complex (MC) i.e. start mc, aiop and apply DPL from u-boot command prompt. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30driver: ldpaa: Add api to return linked PHY ID of DPMACPrabhakar Kushwaha
DPMAC represents physical line on the board. This physical line eventually asscociate with on-board PHY. So Add an api to return linked PHY ID of DPMAC object. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30driver: net: fsl-mc: Add APIs for DPMAC objects in FLIBPrabhakar Kushwaha
DPMAC object of Management complex controls Physical MAC and MDIO controller. It provides APIs for MDIO and link state updates. It also provides APIs for PHY/link configuration. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-11-30driver: net: fsl-mc: Add create, destroy APIs in flibsPrabhakar Kushwaha
Current Management Complex Flibs does not support APIs for adding and destroying the objects. Add APIs to create and destroy objects for DPBP, DPIO, DPNI and DPRC. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-09-11bitops: introduce BIT() definitionHeiko Schocher
introduce BIT() definition, used in at91_udc gadget driver. Signed-off-by: Heiko Schocher <hs@denx.de> [remove all other occurrences of BIT(x) definition] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-08-03drivers/fsl-mc: flib changes for mc 8.0.0Prabhakar Kushwaha
MC firware version 8.0.0 contains new command flags. This patch contains modifications in FLIB files to support the new command flags. Signed-off-by: Itai Katz <itai.katz@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-20armv8/fsl-lsch3: partition stream IDsStuart Yoder
Stream IDs on ls2085a devices are not hardwired and are programmed by sw. There are a limited number of stream IDs available, and the partitioning of them is scenario dependent. This header defines the partitioning between legacy, PCI, and DPAA2 devices. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-20drivers: fsl-mc: Update flibs to mc-0.6.0.1Prabhakar Kushwaha
Update flibs changes to mc-0.6.0.1 for dpmang, dprc, dpni and dpio objects Also rename qbman_portal_ce/ci_paddr to qbman_portal_ce/ci_offset in dpio_attr. These are now offsets from the SoC QBMan portals base. Signed-off-by: J. German Rivera <German.Rivera@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-23driver/ldpaa: Add support of WRIOP static data structurePrabhakar Kushwaha
Wire rate IO Processor (WRIOP) provide support of receive and transmit ethernet frames from the ethernet MAC. Here Each WRIOP block supports upto 64 DPMACs. Create a house keeping data structure to support upto 16 DPMACs and store external phy related information. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com>
2015-04-23driver/ldpaa_eth: Add LDPAA Ethernet driverPrabhakar Kushwaha
LDPAA Ethernet driver is a freescale's new ethernet driver based on Layerscape architecture. Every ethernet driver controls on DPNI object. Where all DPNIs share one common DPBP and DPIO object to support Rx and Tx flows. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> CC: Cristian Sovaiala <cristian.sovaiala@freescale.com> CC: Bogdan Hamciuc <bogdan.hamciuc@freescale.com> CC: J. German Rivera <German.Rivera@freescale.com> [York Sun: s/NetReceive/net_process_received_packet] Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-21driver/fsl-mc: Add support of MC FlibsPrabhakar Kushwaha
Freescale's Layerscape Management Complex (MC) provide support various objects like DPRC, DPNI, DPBP and DPIO. Where: DPRC: Place holdes for other MC objectes like DPNI, DPBP, DPIO DPBP: Management of buffer pool DPIO: Used for used to QBMan portal DPNI: Represents standard network interface These objects are used for DPAA ethernet drivers. Signed-off-by: J. German Rivera <German.Rivera@freescale.com> Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com> Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Geoff Thorpe <Geoff.Thorpe@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Cristian Sovaiala <cristian.sovaiala@freescale.com> Signed-off-by: pankaj chauhan <pankaj.chauhan@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-21armv8/fsl-lsch3: Add Freescale Debug Server driverBhupesh Sharma
The Debug Server driver is responsible for loading the Debug server FW on the Service Processor (Cortex-A5 core) on LS2085A like SoCs and then polling for the successful initialization of the same. TOP MEM HIDE is adjusted to ensure the space required by Debug Server FW is accounted for. MC uses the DDR area which is calculated as: MC DDR region start = Top of DDR - area reserved by Debug Server FW Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-24drivers/mc: Migrated MC Flibs to 0.5.2J. German Rivera
Upgrade Manage Complex (MC) flib API to 0.5.2. Rename directory fsl_mc to fsl-mc. Change the fsl-mc node in Linux device tree from "fsl,dprcr" to "fsl-mc". Print MC version info when appropriate. Signed-off-by: J. German Rivera <German.Rivera@freescale.com> Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
